Cut-Weld-Drive Forums (http://volksrods.com/forum/index.php)
-   The Cutting Board (http://volksrods.com/forum/forumdisplay.php?f=5)
-   -   Crank Pulley Bolt (http://volksrods.com/forum/showthread.php?t=37754)
Jon February 22nd, 2014 03:30 AM
Crank Pulley Bolt
So there is this one. Empi $10
http://ecx.images-amazon.com/images/...GL._SX466_.jpg
And this one. Empi $10
http://ecx.images-amazon.com/images/...iL._SY300_.jpg
I have never used either one of these before, only the stock one.
I like the idea of them but not sure if they are crap or not.
I saw one post once on the Samba where some guy said his kept loosening up and someone said the bolt was bad others said the problem may be the washer or his flywheel.
I am fine swapping out the washer, have no problems with my Flywheel... I need a bolt to hold the pulley on as the old one has been lost during Rebuild, I don't care about Chrome...
Any thoughts or experiences ?
I just found this one for $26.95
http://www.socalautoparts.com/images...BP_4525-11.jpg
http://www.socalautoparts.com/produc...-black-p-13272
Might be a better one, its BugPack not Empi. :Idunno:
Timbo February 22nd, 2014 06:38 PM
Re: Crank Pulley Bolt
I have ran a couple of crank bolts from JayCee like the top one. Handy to have the 3/8 hole for the ratchet when adjusting valves. The top Empi bolt and original washer should be good.
hotsauce February 23rd, 2014 06:27 PM
I'm using a crank start pulley nut on my car... Looks evil on the pulley.
