Cut-Weld-Drive Forums (http://volksrods.com/forum/index.php)
-   SH*T For Sale (http://volksrods.com/forum/forumdisplay.php?f=31)
-   -   '71 volksrod (http://volksrods.com/forum/showthread.php?t=38607)
cliff November 6th, 2017 02:57 AM
'71 volksrod
5 Attachment(s)
UPDATE: I have had a lot of calls on could it be a daily driver. YES, YES, YES. I use the trailer for out of town shows. here's a nonprofessional video clip. https://youtu.be/rUMzl62Ibsc
1971 volksrod, custom purple metal flake, chopped top, after market pop up tinted glass sun roof, shaved trunk/deck lid, doors, gas door lid, suicide doors with 4" peep mirrors, remote door poppers(doors are glass rollup), skull on front hood lights up, vintage '30s dietz buckets with parking/running lights, 7" maltese cross headlights with 55/60 H4 skull bulbs, vintage '30s 5 1/4" fog/turn indicators, amber skull parking/running lights, '67 custom green paint gas tank/detailed trunk, 12v a-ooga horn and duel air horn, custom green paint motor with weber progressive 2 barrel with heat risers(I was told when bought as a beetle it was a 1641 but my mechanic thinks it's 1776), aluminum bolt on finned valve covers, competition merged exhaust with racing stinger, heater boxes(yes the heater does work), new throw out bearing, clutch and pressure plate, adjustable front beam with 8"extension, front dis brakes, drum back brakes, 4" maltese cross tail/brake lights with skull running lights, third tail/brake led lights in rear air intake vent with amber led turn indicators, one of a kind custom skull license plate holder with purple led lights(led backup lights are mounted in eye sockets), spikes on wheel well are screwed in fender bolt holes(fenders can be put back on), 15"x 4 3/4" lug pattern weld pro star wheels(I have center caps) 4"x165/r15 front tires, 15"x10" comp t/a drag radial back tires, custom interior, after market power front seats(not wired in), custom upholstery/headliner/side panels, 2 front custom embroidered floor mats, 2 back mats, 4 black-lite interior lights, fiberglass dash with after market speedometer(center mounted that reads MPH right), custom steel dash console with second interior light, 2" sunpro fuel, volt, oil gauges, 5" sunpro super tach III with shift lite, custom turned switch knobs, faceted lenses and cog metal bezel indicator lights, detachable face sony am/fm cd player with aux port, 2 way 4" front speakers, 1 1/2" front tweeters, 6x9 3 way rear speakers, 14" back lit(black-lite) custom vw cog emblem between back speakers, pro t quick shifter, vintage 13" rosewood formula france steering wheel with custom purple horn button with custom vw cog emblem(pewter), matching vintage rosewood e-brake handle, vw symbol courtesy projector light mounted under the pans. battery box with new battery, mounted in the back kick board is a 1000 amp master cut off switch(2 keys), jumper/charge post so you don't have to raise the back seat, push start button(just in-case key doesn't work). trailer goes with car, custom independent suspension with coil springs and shocks(no axles), 2" hitch, hydraulic drum brake actuator hitch, 5 newish 15" X 5", 5 lug 4.5" lug pattern, white spoke trailer wheel, 3.195" center bore(with center caps), tire size: ST20575D15, six ply, 1820 lbs capacity(per tire), 65 max psi, locking lug nut set, trimax tcl65 wheel chock lock includes 3 keys. 3 way tail lights(blinker, tail/brake, back up), side and rear clearance lights, 5000# hitch-mounted winch, hand held remote control and 6ft' hand power cord. i'm sure i forgot somethings. if pics don't load i'm listed at Dallas, tx craigslist type in search bar: volksrod
if your reading this add i still have it.
214 398 5447
