| Stuff to check out... |
| Forum Stats |
Members: 14,778
Threads: 30,822
Total Online: 71
Newest Member: VWWalt
August 2nd, 2006, 08:51 AM
#226
Re: O/T computer help desk thread
Some people turn off the Automatic Updates option to avoid this problem.
System Restore should make it's own Restore Points every few days,so you can go back a week or two,instead of going back to day 1.But it's kinda late for that in your case.
August 2nd, 2006, 11:40 AM
#227
have you tried updating the motherboad's software (BIOS)? The BIOS may not be able to handle teh newer patches for some reason. Are you on the interent all the time on that PC? If not then you don't really need the updates much, most are security pathes but if it doesn't get the the interent that doesn't matter much. Or if it's stable w/o the patches then just run it as is.
August 2nd, 2006, 12:00 PM
#228
Are there any "Must Have" patches for XP ?
I've got Automatic Updates turned off on both computers.
August 2nd, 2006, 12:05 PM
#229
I guess I'll try it without the patches........ It was stable for at least 4 years.
August 5th, 2006, 05:20 PM
#230
Can anyone suggest a good tutorail for using Excel ?
Thanks.
Ian
August 5th, 2006, 05:59 PM
#231
My old computer is running Windows 98SE. It has a CD burner using Roxio 5 ( I think) but I can never get it to format a CD correctly. I have successfully burned CDs (CD-RW and CD-R) with it but can't get it to do it now. I want to get all my pics (and some software) off this computer and then set it up for my son to use. Any ideas on what might be wrong (with it or me)?
Also, I was using AOL with my old computer and switched to DSL through Bellsouth when I got my new computer. I cancelled AOL. How do I go about getting online with my old computer so I can download the drivers for a flash drive? I tried downloading them to my new computer, putting them on disc and then loading them in the old computer but it didn't work for some reason. I have Windows 2000 Professional on my new computer, BTW.
Also, can someone explain the differances in discs for me? What's the differance between DVD-R & DVD+R, etc?
Thanks.
August 15th, 2006, 07:22 PM
#232
My laptop got hit by a couple Trojans today.AVG identified them,
but I think they managed to do some damage before I could remove them.
I had the Windows Firewall turned on,obviously that didn't work very well.
Now it's turned off,and I can't turn it back on.
Trying System Restore,it doesn't want to restore to previous dates.
Any suggestions ?
August 28th, 2006, 07:28 PM
#233
Most of the Fonts I've got suck.I figured out how to download
some decent ones to my desktop,now how do I get them to
where they need to be ?
Tried dragging and dropping into the font folder,didn't work.
Any suggestions ?
Thanks.
August 28th, 2006, 08:53 PM
#234
- Choose Start > Settings > Control Panel
Note: In Windows XP, choose Start > Control Panel
- Double-click the Fonts folder.
- Choose File > Install New Font.
- Locate the fonts you want to install.
- In the Drives list, select the drive and the folder containing the fonts you want to install.
- In the Folders list, select a folder that contains the fonts you want to install. (Make sure you have unzipped them first.) The fonts in the folder appear under List of Fonts.
- Select the fonts to install. To select more than one font, hold down the CTRL key and click each font.
- To copy the fonts to the Fonts folder, make sure the Copy fonts to the Fonts folder check box is selected.
Note: If installing fonts from a floppy disk or a CD-ROM, you should make sure this check box is selected. Otherwise, to use the fonts in your applications, you must always keep the disk in the disk drive.
- Click OK to install the fonts.
Also Windows Firewall is not a true firewall program. I personally wouldn't worry about it IMO but that's just me, I never turn my built in Windows firewall for any of my personal PCs. If you're behind a router that's a firewall in itself technically. Or I use Norton Systemworks if I really want one.
October 16th, 2006, 11:27 AM
#235
Got nailed by a "system32-???" worn.
'Puter crashed. If I wipe the hard drive and reinstall, will that do the trick, or do I need to do more?
October 17th, 2006, 05:53 AM
#236
hey dean. thats your last resort type of thing. have you tried the latest
"hijack this" software? if you don't want to "clean" the system or go to a restore point then wiping the drive will pretty much take care of most
system problems. just my .002 cents.
October 17th, 2006, 09:07 AM
#237
Have you tried System Restore,to put your computer back
to the way it was ?
Hijack This is good,IF you know for sure what to delete.
Otherwise,you could delete some stuff you need,
and make the problem worse.
Can you start the computer in Safe Mode,
then run your Anti-virus software ?
Hopefully Nick will have a clever solution.
October 17th, 2006, 10:16 AM
#238
I can run my anti virus and it will catch everything as long as the internet is unplugged. As soon as it gets plugged in I get hit again. My "security"  system is catching all the things going on, but can not "fix" the problems. It will only quarentine (sp) them. System restore points are no longer there. It says that the only restore point was the day before. If I check it tonight it will say yesterday and have no other restore points listed. This is one of the things that has been created by this *@#$&%^*!
The guy how loaded the programming (as I now find out) used a boot leg version of Xp and I have a feeling that is where a portion of the problem started.
Any way, thanks for the info.
October 17th, 2006, 10:26 AM
#239
I had a similar Quaranteen(sp?) problem,in regular mode,using AVG.
But when I tried it in Safe Mode,I was able to get rid of the problems.
Try it again in Safe Mode.
October 17th, 2006, 10:28 AM
#240
Will try again tonight. I'm also using AVG so maybe it will work. Thanks Unk.
October 17th, 2006, 10:44 AM
#241
run the anti-virus program in safe mode, will catch/delete more stuff that way. Make sure it's up to date first. But most problems are NOT virus but spyware, so an anti-virus program won't help much. Run a anti-spyware program like Lavasoft Adaware. Sounds like that's what you have, spyware and not a virus
October 17th, 2006, 10:50 AM
#242
I agree, but the two anti-spy programms I am running don't catch it. Only the virus software does. That's where I got concerned. Thanks again. I'll run both virus and spy wear while I'm in safe mode tonight. And all three are up to date. I was able to get that done before it went crazy last night.
October 17th, 2006, 11:07 AM
#243
Windoze won't let you delete anything that is running.
So if a Virus,Spyware,Malware,etc automatically starts
when you turn the machine on,you can't get rid of it;
unless you use Safe Mode.
Then run all your Antivirus,Anti Spyware,AntiBlablabla.
Delete all Temp files.
We have Spybot,Adaware,CCleaner,and Winpatrol,on both machines here.
Norton Antivirus on the PC,and AVG on the Laptop.
WHEN YOU UPDATE SPYBOT,MAKE SURE YOU "IMMUNIZE".
Don't know why it doesn't do that automatically.
October 17th, 2006, 03:28 PM
#244
If you have a 'clean' computer with a good connection to the internets, go up to Symantec/Norton or TrendMicro and look for a cleaning tool. A lot of times when a new virus comes out the anti-virus companies will come up with a cleaning tool to wipe it out without having to reload the machine.
http://www.symantec.com/enterprise/s...movaltools.jsp
http://housecall.trendmicro.com/
October 18th, 2006, 04:38 PM
#245
Found some of the problem... Did as memtioned and ran programs in safe mode and was able to remove 80 of 84 infections. Turns out the the "spyware blaster" program was actually causing alot of the problem. I got rid of it finally and everything is checking out normally for now.
I'll keep up to date on any further developments.
October 18th, 2006, 04:45 PM
#246
I had some problems with Spyware Blaster as well.
October 18th, 2006, 04:55 PM
#247
Any thoughts on another good one? I'm still running spybot, and AVG. They actually cought the Blaster issue. Thinking about trying to find another anti-virus progran also. Any thoughts on a GOOD one?
October 18th, 2006, 05:16 PM
#248
Ad Aware is definately worth having,with Spybot.
CCleaner is also good for on going maintainance.
I also like MRU Blaster.
You can get them free from Download.com
October 18th, 2006, 05:22 PM
#249
Spybot and Ad Aware are a must.
And I like Norton anti-virus/firewall.
October 18th, 2006, 05:28 PM
#250
I'm happy with TrendMicro's PC-cillin (anti-virus+) and Webroot's SpySweeper with ZoneAlarm (firewall). I also use Firefox instead of IE or Netscrape, and we occasionally run AdAware.
| Thread Tools |
| Display Modes |
Linear Mode
