The VolksRodders Forum
Go Back   The VolksRodders Forum > The VolksRodders Forum > The Tech Bin
Our Pals...
VolksRods STUFF...
Members: 9,262
Threads: 27,113
Total Online: 72
Newest Member: Nico
- by DANJC
- by Timbo
Old August 4th, 2009, 01:49 PM   #1
denkeeper & guard dragon
Default Engine threads
Some past threads on engines. These cover most major topics and questions. Please feel free to bring these up and add more info or ask questions. These will come up in the cutting board, not here in the tech bin, so look for replies there. These are LINKS only. This thread is for links only, any questions you have and not provided in one of these links, please ask in the Cutting forum.
You will find lots of info in shoptalkforum.com
what drivetrain/combo are you running?
http://www.volksrods.com/forum/showthread.php?t=21449
what's you mpg?
http://www.volksrods.com/forum/showthread.php?t=8470
performance, can't drive 55
http://www.volksrods.com/forum/showthread.php?t=14140
what are you running?
http://www.volksrods.com/forum/showthread.php?t=24885
what engine should I get?
http://www.volksrods.com/forum/showthread.php?t=12098
show off your engine compartments
http://www.volksrods.com/forum/showthread.php?t=10674
engine companies
http://www.volksrods.com/forum/showthread.php?t=16578
biggest engine displacement
http://www.volksrods.com/forum/showthread.php?t=26737
painted engine case/block
http://www.volksrods.com/forum/showthread.php?t=24626
engine cleaning
http://www.volksrods.com/forum/showthread.php?t=24510
engine building 101 (tips tricks etc)
http://www.volksrods.com/forum/showthread.php?t=23319
engine tins
http://www.volksrods.com/forum/showthread.php?t=10345
cooling
http://www.volksrods.com/forum/showthread.php?t=14968
http://www.volksrods.com/forum/showthread.php?t=11911
DaBoss says~"READ more... post LESS."
O/T popular threads artists group cave garage art for sale
caution, changes mood hourly
Help support the best site on the web.
Originally Posted by erminger
If you own both a bug and a bus, does that make you Volksdextrous or Bi-wagonal?
purplemyth is offline
Old September 26th, 2009, 06:40 AM   #2
Default outside links
torque specs that may not be listed in all manuals
Courtesy of chirico site
http://chircoestore.com/wordpress/?page_id=23
Torque Specifications for type 1 – 3
Type 1 – 3
Part —- ft-lb — size (dia x pitch)
Connecting rod nut – 24 – m 9×1
Connecting rod capscrew – 32 – m 9×1
Crankcase nut – 14 – m 8
Crankcase nut – 25 – m 12×1.5
Cylinder head nut 8mm – 18 – m 8
Cylinder head nut 10mm – 23 – m 10
Rockershaft nut – 18 – m 8
Heat Exchanger at head – 14 – m 8
Muffler Clamp bolts – 7 – m 6
Intake manifold nut – 14 – m 8
Preheat-flange bolt – 7 – m 6
Oil Pump nut – 14 – m 8
Oil Pump nut – 9 – m 6
Oil Drain plug – 25 – m 14×1.5
Oil Strainer nut – 5 – m 6
Oil cooler nut – 5 – m 6
Oil filler gland nut – 40
Flywheel Gland nut – 235 – m 28×1.5
Clutch bolt – 18 – m 8×1.5
Sparkplug – 25 – m 14×1.25
Engine to trans nut – 22 – m 10
Crossmember bolt – 18 – m 8
Crossmember bolt – 29 – m 10
Generator pulley nut – 43 – m 12×1.5
Fan nut – 43 – m 12×1.5
Crankshaft pulley nut – 32 – m 20×1.5
Crossmember to body – 18 – m 8
Fan/Crankshaft pulley – 94-108 – m 20×1.5
interested in engine displacement?
http://www.msgulfcoastvwclub.org/TechPages/Tech6.html
engine, engine help
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
ALL text, images, graphics and content herein are Copyright ©2002 - 2010 Volksrods.com
