Members: 17,715
Threads: 32,304
Total Online: 458
Newest Member: Jcowen
Old July 14th, 2011, 12:33 PM   #1
sallyandsean
Default White wall tyre paint
I have seen online White wall tyre paint, can this be painted onto regular tyres for a White wall look or is it not that easy?
sallyandsean is offline   Reply With Quote
Old July 14th, 2011, 01:23 PM   #2
big daddy chuck
Default Re: White wall tyre paint
http://youtu.be/xkcm3rh60p0
big daddy chuck is offline   Reply With Quote
Old July 14th, 2011, 01:24 PM   #3
big daddy chuck
I'm not saying this is the best way, but it is an option.
Old July 14th, 2011, 02:20 PM   #4
The search function turns up lot of info on this, but being across the pond, this post/thread, may help you better.
http://www.volksrods.com/forum/showt...ite#post259444
But there are many others over here that have done it, scott76 for 1, with krylon fusion~
1,2,.............. .
Old July 14th, 2011, 05:46 PM   #5
oneeyedgoat
oneeyedgoat's Avatar
stuff works and looks good if you spend the time to clean tap and lay it down right.. its not and afternoon job..took me 3 days and about 4 hurs prep, and thats not being anel..laid thin coats with small paint roller..and tape edge to help with the real look..very tuff stuff when all done
oneeyedgoat is offline   Reply With Quote
Old July 15th, 2011, 03:04 AM   #6
sallyandsean
Think this is the way to go then!!!
Old July 15th, 2011, 03:12 AM   #7
Scott76
Scott76's Avatar
I don't know. The Krylon Fusion paint holds up VERY well. I run my car year round through the hottest days to the ice/slush roads of PA. It still looks good to me but its WAY cheaper that ordering that tire paint. Plus you can have the tires back on your car within the same day you prep & paint them.
Take a look:
http://www.volksrods.com/forum/showt...ite+wall+paint
Bugger Off
Fleetwing Camper
Going to the Basement
Old July 15th, 2011, 08:59 PM   #8
oneeyedgoat
hit up some buddys..for 40 bucks you can do at least 4 sets of tires. thats one quart...good luck..and when its dry its like a rubber white wall,you can dig at it with your thumb nail
Old July 17th, 2011, 12:24 AM   #9
Al Low Ha
Al Low Ha's Avatar
either method is better than those damn porta walls!
Aloha
Old July 17th, 2011, 02:25 AM   #10
big daddy chuck
2 cans of Krylon fusion paint in hand... Going to give Scott's idea a try. first i want to smooth the slight raised lettering on the sidewalls. Better get started cause with the humidex today is going to feel like 40 C / 105 F.
Old July 17th, 2011, 05:49 AM   #11
sallyandsean
Let me know how you get on with it!!
Old July 17th, 2011, 06:59 AM   #12
big daddy chuck
Wife and kids left for a few days to a friends cottage, Guess who has the camera
I'm not going to start any prep for paint, just sand the tires and waight till the wife gets home, Already 30 C outside.
I'll add pictures in a few days.
Old July 24th, 2011, 04:54 AM   #13
big daddy chuck
Family is back from a few days vacation and the camera has sumehow not made the 3 hour trip home... I will however say that I have had some pretty good success with the KRYLON FUSION PAINT method.
I did venture off the cleaning process buy first lightly sanding the tires lettering and my first cleaning came with a spray brake cleaner thats safe for rubber and then a warm water and scrub with a MR. CLEAN magic eraser pad.
It got the tire very clean... Follow the instructions on the can and applied 3 coats of paint very light. I'm going to let this set up and dry as the can states for 7 days, give them a second light sand with maybe a 240 grit dry sand and repeat the warm water and Mr. Clean pad.
I repeat this for cautionary measures, the brake clean i use is a RUBBER SAFE type cleaner, read the can before you decide to use it. Some contain chemicals that swell rubber...
And the first tire I am using is a spare that I had laying around, so the cleaning methods may change a bit.
I will say this The tire I am working on is inflated about 5 lbs over the suggested pressure, I'll reset the pressure and hopefully the stretch/flexability in the paint keeps the wide white from CHECKING.
I am going to try and do one more tire with just the front bead broken and see what happens when i inflate the tire. My guess is the paint will check ( crack ) when I inflate it
I'm trying this to simulate road pressure movements while you drive.
Stay tuned...
Old July 24th, 2011, 05:23 AM   #14
binaryxy
binaryxy's Avatar
Im at that point now, here in vegas there are a ton of used tire places, to try both methods.... Im going to sand all the lettering and what ever first and use the KRYLON FUSION PAINT method......but, question. is there somethng I can spray over the tire once I paint them, too help protect them......since Im sand blasting the rims and clean them up first before I do anything with the tire,, I may try both methods to see what looks better.....as the above post was talking about tire pressure and cracking...wait, I recall a paint (now Im giving up my age) didnt JCW sell a white wall paint that was a rubber base?.......Ill look into it...
binaryxy is offline   Reply With Quote
Old July 24th, 2011, 05:36 AM   #15
big daddy chuck
The KRYLON FUSION paint is flexible and with a stiff bias ply sidewall type tire would likely stand the test of time very well. I'm trying the overinflated radial tire method to give the paint a bit of relax to stretch out if needed. SCOTT76 has had alot of success with the paint , and like me living in a colder climate the weather has alot of temperature change that you may not see. He reports that the paint is now 2 years old and is holding its own..
As for any special treatment. I think the Mr. Clean jobby will keep the wheels lookin purdy for some time. just use a sponge to apply your tire dressings on the rest of the black to keep better control of the coverage.
Old July 24th, 2011, 05:38 AM   #16
binaryxy
binaryxy's Avatar
I found a few links,
http://www.mbzponton.org/valueadded/other/tirepaint.htm
http://www.therustshop.com/shop/inde...d&productId=99
this is my biggest fear (read this link)
http://rod-your-ride.com/whitewalls.aspx
They do have inserts, I purchased a set for a car I did a few years ago, which goes for about 70.00 a set.... however look at the pictures what they look like after a few years
Old July 24th, 2011, 05:42 AM   #17
big daddy chuck
Krylon Fusion... $6 a can... covers 2 tires complete with several light coats over about 15=20 minutes setup time.
Old July 24th, 2011, 05:49 AM   #18
binaryxy
binaryxy's Avatar
well then thats the trick.....Ill give it a try... if all else fails, theres the grider LOL
Old July 24th, 2011, 09:39 AM   #19
big daddy chuck
