Members: 17,688
Threads: 32,298
Total Online: 95
Newest Member: gstong
- by Harold
- by Frank3
Old June 28th, 2014, 10:41 AM   #1
Default thread cleaning
Hey gang,
I just chased some 3/8-24 threads on my trailing arms (aftermarket, American made) but they are only open one side. (Welded into 2x3 arms) Any thoughts on how to clean them out? Don't want to use air as I don't need eye shrapnel. And I think a magnet might not reach down inside. Thanks!
Old June 28th, 2014, 11:09 AM   #2
Default Re: thread cleaning
Flush with water, then use air to dry them out.
Old June 28th, 2014, 11:42 AM   #3
Paperweightnate
Paperweightnate's Avatar
goggles. and air. maybe a shield.
"There was a time when you would have been burned at the stake for asking "where do I get..." instead of asking "how do I build..." -Ray-Dean
Paperweightnate is offline   Reply With Quote
Old June 28th, 2014, 12:46 PM   #4
WD40 or Brake Cleen, with the long nozzle.
Old June 28th, 2014, 05:39 PM   #5
misterrfixit
Q tips. The shavings get tangled in the cotton. chase it with a Q tip dipped in grease. it will lubricate as well as pick up any small pieces you missed.
misterrfixit is offline   Reply With Quote
Old June 28th, 2014, 06:04 PM   #6
misterrfixit
Don't mix those up with the Q tips you are going to use on your ears however.
Old June 28th, 2014, 06:28 PM   #7
Could I use ear wax to get the shavings out?
Appreciate the tips guys!
Old June 28th, 2014, 06:31 PM   #8
The threaded holes should be deeper than the bolt engagement.
A small amount of chips won't be a problem.
Old June 28th, 2014, 07:53 PM   #9
rodderdan
wire bore brush.Thread it in and out.Carb cleaner,blow it out.Wear a shield.
Old June 28th, 2014, 08:26 PM   #10
If you have enough ear wax, make sure it's been pasteurized using (since you have fractional threads) the SAE process.
Old June 28th, 2014, 09:24 PM   #11
Gun cleaning kit? cut up some rags into small squares and run them through it! Thats what I did with my mosin nagant to get the cosmoline out of it... cut up some cheapy dollar store mircofibers into 1.5 inch squares and just ran it through the barrel. Since a guns bore is pretty much just a thread it should work I think
Also PS I didn't know how to my gun's cleaning kit that came with it (guns a soviet battle rifle.. just used the rod...) So you could use screwdriver just cut the towel so its snug and just run it through!
Old June 28th, 2014, 09:55 PM   #12
The only reason I asked was that the threads are only open from one side.
Old June 28th, 2014, 09:57 PM   #13
Well the rag gets caught on the rod pushed down and pull through! I think i've done it before on stuff that wasn't a gun...
Old July 2nd, 2014, 02:55 AM   #14
Old machinists trick, a good pair of safety goggles/glasses & an air hose, get's em out every time
