Members: 17,527
Threads: 32,242
Total Online: 518
Newest Member: lds8c33c
- by Rich B.
- by cretin
Old June 29th, 2014, 09:09 PM   #1
Default Need some help with figuring out an issue.
Okay heres a problem my mum has been experiencing with her bug Its been happening for a few months now to her 2001 Mexican bug.
(I've searched the samba for answers and have come up empty handed)
When she turns on the light switch the gen light pops up and the car surges and the engine actually slows down.. its a total power surge. I thought it was the belt.. replaced it. it helped.. because the old belt was quite worn down.. However the problem is still there. it only occurs if the lights are turned on, and while they're on the gen light is on. Very annoying
SO I got a multimeter and tested the car while I ran.. Sometimes I got nothing from the thing or sometimes I got 22-27 volts coming from the terminals.. Once again sometimes I got nothing but I know there was electricity going through it.
The only four things I can think it is.. is A) Alternator in the car is going.. its the original 2001 mexican alternator from the factory. B) Its the four year old battery in the car... modern shit doesn't seem to last long C) Wiring issue! D) leprechauns are fucking with the motor when its in the pull barn...
Sooo maybe its not D , but I also doubt its C that leaves A or B since I Was getting over 20 volts from the alternator at times Not sure if i'm an idiot when using the multimeter Anybody have anything similar happen to you in the past.. I have a few generators and a alternator lying around.. its just replacing it is gonna be a bitch... I'm hoping its something other then the Alternator.. like the battery.. or a fuse or something retardedly simple.
Old June 29th, 2014, 09:18 PM   #2
BugTower
BugTower's Avatar
Default Re: Need some help with figuring out an issue.
not 100% sure, but usually if it is the alternator going out your lights will brighten with the revs. Just make sure if you swap it out you replace an alternator with an alternator, the gens had an external regulator under the backseat.
"I used ta do drugs... I mean I still do drugs, but I used ta to." Ricky, Trailer Park Boys
BugTower is offline   Reply With Quote
Old June 29th, 2014, 09:20 PM   #3
BugTower
BugTower's Avatar
And if the battery tested weak that wont helpmatters either! Probably wouldnt hurt to change both!
Old June 29th, 2014, 09:45 PM   #4
I'm voting for leprechauns. I can hardly get any of my VWs to run and I'm sure that is the problem.
Old June 30th, 2014, 12:11 AM   #5
Would also explain where my wallet and my work name tag went
wait if I catch them that means I get gold!
Old June 30th, 2014, 12:16 AM   #6
Always was wondering wtf that thing was under the rear seat... Now I know! Good thing... Gonna have to see how to hook that sucker up for the rebel wiring harness in my 1966... Also What size is the bolt to get off of the fan part of a generater.. I have a spare alternator that came with the 1966.. its a motorola one.. with a built in regulator. .soo I have one! I just need to get parts off of a generator to put on it... I don't know what size the sucker is.
Sorry if I'm seeming quite nooby.. it's because I am.
Hey atleast I admit I'm young and stupid!
Old June 30th, 2014, 11:53 AM   #7
Admitting you're "young and stupid" is a good thing. Then, when you're older, it's easier to admit that you're old and, um...Jeff, help me out here.
Old June 30th, 2014, 01:24 PM   #8
Stupid is the word you're looking for Kim. I'll go out and send you your walker and Depends via Fed Ex......
Old June 30th, 2014, 02:01 PM   #9
I'll have you know that my walker is in great shape! I've even added the Extra Traction Turbo Omnidirectional High Speed foot pads.
Old June 30th, 2014, 02:45 PM   #10
Slit tennis balls?
Old June 30th, 2014, 03:52 PM   #11
Oh sure, give away my speed secrets.
Old June 30th, 2014, 09:57 PM   #12
Nobody corrected me before on the pull barn.. thing Its suppose to be DC!? I thought alternator.. alternating... God damnit.. (wheres the face palm smiley)
I know it was running because it was sparking.. I accidently slipped and had the black cable touch a screw on the alternator ZAP. theres a little black dot on the screw... and sharp tip on the terminal of the meter is slightly more rounded..... Whoops... Hope that didn't kill it
Also today we did the headlight test thing with the reving the motor.. and no change in brightness.. granted its a 2001 mexi bug so who knows... Its a different evolutionary branch of the bug tree... Still getting the battery tested is a priority.. or maybe just straight up replacing it.. .Its been dead mutiple times over the winter and I know for a fact my mom bought it on sale from the local autostore in st.paul before we moved. Yeah.. their own name brand... so needless to say its not the highest quality thing out there
Old June 30th, 2014, 09:59 PM   #13
I thought you welded a pair of these to the bottom of it.
Old July 1st, 2014, 10:53 AM   #14
A 'PULL' barn is what you pull your projects into...Um, you don't have four (4) of those skates, do you?
Old July 1st, 2014, 12:21 PM   #15
Wish I did... that'd make a great youtube video.. especially if bottle model rocket engines were attached to a set.
Old July 1st, 2014, 02:27 PM   #16
Paperweightnate
Paperweightnate's Avatar
You need a pull out barn. and I second the leprechauns.
"There was a time when you would have been burned at the stake for asking "where do I get..." instead of asking "how do I build..." -Ray-Dean
Paperweightnate is offline   Reply With Quote
Old July 9th, 2014, 04:47 PM   #17
lunatic_magnet
lunatic_magnet's Avatar
if you're getting 24 volts, that says to me that the voltage regulator is junk...
volksrods member #39
forget wd-40 and duct tape... i have a sawzall and a welder.
lunatic_magnet is offline   Reply With Quote
Old July 9th, 2014, 08:01 PM   #18
Its obvious the alt is going.. its 13 years old.. original to the mexibug. I have a motorola alternator.. and we replaced the battery.... yeah when the car drive the gen light goe mental... Looks like strobe light.
