Members: 17,514
Threads: 32,311
Total Online: 424
Newest Member: jacks8x4bp4
- by Zee
- by horshak
Old October 9th, 2009, 04:34 PM   #101
stnkbg1
Default Re: Building the new SFR shop
How are you insulating it?
It's got 4" of fiberglass insulation throughout. You can see it on the inside of the roof in the last pics. The walls have interior metal sheeting covering it up, but if you go back through the pics you'll see it in there.
stnkbg1 is offline   Reply With Quote
Old October 24th, 2009, 10:30 PM   #102
stnkbg1
Not a lot of progress lately as I've been way too busy working over in the old shop since this one still doesn't have electricity. About a week ago we did get the floors all done up though. After talking to Danny about my goals for the floor I took his suggestion to buff out the concrete and use a clear sealer. This should keep oil from soaking in and staining the floor, and wont get damaged by welding sparks like an epoxy would. It was also pretty cheap.
As you can see there were a lot of tire marks on the floor from the various fork, and boom lifts we used to erect the building.
A few hours with a floor buffer and a garden hose and they all disappeared. Plus the floor is smooooooooth now.
Here is a shot of the floor with 3/4 of the sealer done. you can see the obvious difference in shine.
Old October 24th, 2009, 10:40 PM   #103
stnkbg1
The new doors showed up this week and today we took the original (incorrect) ones back down and put the new ones up. In the process we also found a new use for a set of 39" red label BFG Krawlers.
When we put the doors up the first time we had a smaller warehouse style forklift....and it wasn't tall enough. We had to get creative by stacking some stuff on the forks to get the door up high enough, and it was quite sketchy. This time I made sure to get a taller forklift, but discovered a new problem. As the forks go up, the carriage goes up MUCH higher. Too high for the inside of my roof. The only way to get the forks up high was to lift the door from the outside, but since the drum sits higher than the door frame we once again needed something to rest it on. It just so happened that I had these tires around for a customer project. Worked like a charm, and much less sketchy than last time.
For those that aren't familiar with those tires, they are a specially built competition tire that BFG makes for rockcrawling, and are only sold to racers.....and guys that need to install doors.
Old October 25th, 2009, 06:42 AM   #104
Pop
Very nice building, I know that you will love it. Bring back a lot of menories of when I was building my building. I built a 50' X 60' with a 44' bi-fold door, heated and cooled. I live on an air-park and restore old airplanes and build homebuilt airplanes along with my love of VW's ( Have owned every year bug from 1956-1974) and building a V8 VW truck. One thing that you will find-out , no matter how big you build it , it will not be big enough. Sending pictures of my building, and my daughter's building( green trim). We work together. Dan R.
Pop is offline   Reply With Quote
Old October 25th, 2009, 06:46 AM   #105
Pop
The picture of my building did not work, will try again. Dan R.
Old October 25th, 2009, 06:56 AM   #106
Pop
Do not move into your new building until it is finished. As you can see my sheetrock is not finished. ( R-19 insulation).
Looks like you are doing it right. Keep up the good work. Dan R.
Old October 26th, 2009, 11:22 PM   #107
stnkbg1
WOOOO HOOOOO at last, I finally have doors!
Got em all finished up on sunday, and even had enough time to anchor the 2-post lift.
Old October 27th, 2009, 05:06 AM   #108
Man this thing is coming right along! I'm very envious!
Old October 27th, 2009, 05:34 AM   #109
UVT_Mike
UVT_Mike's Avatar
Very nice!! When do you plan on moving in?
Mike Nixon
Universal Vintage Tire
Hershey PA
1-800-233-3827
http://www.universaltire.com
UVT_Mike is offline   Reply With Quote
Old October 28th, 2009, 12:15 AM   #110
stnkbg1
Unfortunately I probably wont be moving in at least until december. I have a large project with a deadline on it that I have to get done, so I really dont have time to finish up the shop just yet. I would have liked to get in to do this project there, but I wanna make sure the shop gets done right the first time so I'm not gonna rush it.
Old March 31st, 2016, 07:12 PM   #111
stnkbg1
Man, I didn't realize how long it had been since I'd been on here. Sadly, that's because I still haven't gotten around to tackling my VW project. The shop has definitely changed and filled up a lot. I'm finally getting around to the bug again and took a browse through my old threads and figured I should post an update. It's only been 6+ years, why not?
The yard has filled in around the building and it doesn't seem to stick out as much anymore, or maybe I'm just used to it. I also ended up building a shed to keep the lawn mower and other junk in. Yes, I built a 144sq ft shed next to my 1600sq ft shop and my 900sq ft garage because I didn't want junk cluttering up the place.
Old March 31st, 2016, 07:15 PM   #112
stnkbg1
You'll notice that I also built a fence. In the last 6 years a gained a girlfriend, then a dog, then lost the girlfriend but kept the dog. The dog spends most of her time either in the yard or on her shop bed when I'm working.
Old March 31st, 2016, 07:37 PM   #113
Love the building, love the puppy! So want to give scratches!!!!!
Old March 31st, 2016, 09:29 PM   #114
stnkbg1
The inside has gotten a little more filled in as well. I currently have a couple Ultra4 stock class Jeeps in getting prepped for a race, and my bug is on the chassis table waiting patiently.
Still haven't put walls up for the "office" upstairs, but the rest of the shop is pretty functional and mostly finished the way I want.
Old March 31st, 2016, 10:03 PM   #115
Animals are better than people
Old April 1st, 2016, 10:35 AM   #116
Love your canine assistant, who's name escapes me. IMHO, I think adding office walls would spoil the view.
Old April 1st, 2016, 06:51 PM   #117
stnkbg1
I don't think I ever mentioned her name, so don't burn too many brain cells trying to remember. Her name is Chassis.
Old April 3rd, 2016, 04:45 AM   #118
Good to see you back hanging in here !
