Members: 17,490
Threads: 32,307
Total Online: 739
Newest Member: Mutt Customs
- by Zee
- by horshak
Old September 17th, 2016, 07:18 PM   #1
Default fabrication skills needed
Hey gang,
Got a winter project I'm going to attempt. I have this set of Porsche 356 seats that have been eaten away a bit. I'd like to recreate the lip around there.
Measured the metal, it's right around .042 thick. I'm thinking of going with 18ga as it's .048 and I'll need some working thickness. What I need to make is basically a J shape like this
I just need suggestions on how to roll the metal into that shape. I was thinking I could just use a sheet of .25 thick steel, round one edge of it, clamp the metal to it and hammerform it over. Any thoughts? Thanks!
Old September 18th, 2016, 07:12 AM   #2
Default Re: fabrication skills needed
yes, hammerform.
Old September 18th, 2016, 07:19 AM   #3
gitcha some 1/4" round stock and a hammer and git-r-dunn... A vice and a hammer would be helpful as well... To make it look as pretty as possible maybe use some wood between your hammer and metal, or use a plastic mallet (Harbor freight has some light weight ones) or if you're already a metal ace, and have them, some slappers. The corner areas will make you scratch your head a while, but I think you can work that out once you see how the metal acts when formed and shaped.
since you can weld, the idea is to make a Dolly out of the 1/4" round stock, by welding a length of it ont some plate (Thinner than 1/4" but close) and chuck it up in a vise and hammer over the round... Tool like this with round stock instead of a teardrop - Length determined by yo to fit your needs
Old September 25th, 2016, 09:59 AM   #4
patina my ass!
Old September 27th, 2016, 06:57 PM   #5
Jogyver
Jogyver's Avatar
I have slotted some ridged conduit axially and used it like a roll break. Corners hammerform.
Jogyver is offline   Reply With Quote
Old September 27th, 2016, 07:16 PM   #6
Joe, ya got a picture? I'm perplexed at what you said. (Remember; I have a very small brain.)
Old September 28th, 2016, 06:39 AM   #7
My interpretation, procure a piece of steel tubing the diameter you need for your J bend, cut a thin slot in it that will accommodate the material you want shaped. Insert material to be bent into the slot and proceed to bend/wrap material around the steel tubing. I would think the steel tubing would need to be a bit longer than what you're forming to add strength to the "tool".
I may be completely wrong, so just in case, I will not bill you for this brilliant interpretation! Hahahaha
Old September 28th, 2016, 05:06 PM   #8
Jogyver
Jogyver's Avatar
Mk ... You got it
