Members: 17,624
Threads: 32,327
Total Online: 444
Newest Member: carriehharding
Old October 16th, 2017, 10:11 AM   #1
Amber 74
Default Brake system rebuild
Getting ready to rebuild the drum brake system on my 74 Super.Plans are for new rubber brake hoses,new shoes ,new wheel cylinders,turned drums ,flushed lines with new brake fluid and a new master cylinder if needed. Will NAPA parts be OK or should I spend the extra $ and go with OEM if possible ?
Old October 16th, 2017, 11:04 AM   #2
vinayak
vinayak's Avatar
Default Re: Brake system rebuild
I went with Autozone stuff. Worked good just get good fluid.
Responding to that email does not magically take your response, sign into the forum for you and miraculously place your message into the recipients PM inbox. Nor does it magically place your response into a thread you have subscribed to on the Cutting Board, etc.
vinayak is offline   Reply With Quote
Old October 16th, 2017, 12:42 PM   #3
marnat3
marnat3's Avatar
Autozone X2
Old October 16th, 2017, 01:23 PM   #4
^x 3
Old October 16th, 2017, 03:15 PM   #5
Getting everything all new is probably a waste of money & work.
just replace the worn outparts
the important trick with these old school drum brakes is knowing how to properly adjust them.
IDK the superbeetle. My '61 has separate adjusters for each shoe.
8 shoes + 8 adjusters
it takes real time and patience to get them all adjusted properly
once the system is bled & adjusted these brakes are great
BTW I bought the cheap chineese drums and shoes at appletree & they are fine
