Members: 17,342
Threads: 32,253
Total Online: 546
Newest Member: Weld
- by AMMO22
- by Harold
Old August 17th, 2017, 11:49 AM   #1
PairsNPaint
Lightbulb A REALLY stupid question?
Ok, it's summer here in Texas. Bugs are HOT! A/C is nice but expensive and complicated.
How about putting a small (5000 BTU) electric window-style A/C unit in the back seat area, with a 12v to 120v power inverter? Hang the highest output alternator you can find on the engine. Do whatever duct/shrouding work is necessary (no back seat but who cares?), put in an appropriate drain, seal it off to blow cold air into the main interior and off you go!
I admit to not knowing much about the power requirements, but even the smallest window A/C unit would chill a bug down.
Anyone tried this? Results?
PairsNPaint is offline   Reply With Quote
Old August 17th, 2017, 12:22 PM   #2
vinayak
vinayak's Avatar
Default Re: A REALLY stupid question?
I'm not an AC expert but they blow a lot of hot air out the back. Just sitting it in the car without venting the back out would be pretty counter productive. Plus I don't even know if there is a strong enough Alt/Gen that would work. Probably have to get one custom made which I think is pretty expensive. I know there are some aftermarket under the dash "retro" units on the market but I've never looked them up. Good luck!!
Responding to that email does not magically take your response, sign into the forum for you and miraculously place your message into the recipients PM inbox. Nor does it magically place your response into a thread you have subscribed to on the Cutting Board, etc.
vinayak is offline   Reply With Quote
Old August 17th, 2017, 01:01 PM   #3
Get a roof mount AC unit, like they use on trailers,
with a gas generator in the back seat.
Old August 17th, 2017, 01:29 PM   #4
Not a stupid question, but not a good solution either. Try google for DIY Portable air conditioner, lots of cheap, semi effective ideas.
You can also google putting a window unit in a car and see that's it's a really bad idea.
Old August 17th, 2017, 05:16 PM   #5
PairsNPaint
Venting the hot air out under the chassis wouldn't be a problem. I'm wondering more about powering it electrically. Does an inverter place a heavy load that one would feel? Back in the day I had some aircraft landing lights wired as my brights in my Corvair. When you hit the dimmer switch, the car would noticeably slow down! (Also burned the paint off the trunk of the car in front of me.)
Old August 17th, 2017, 05:44 PM   #6
vinayak
vinayak's Avatar
You would have to look at the amperage of the inverter and go from there. I've only used an inverter when I used to drive Semi. I looked at Autozone and the VW alternators they sell are 30 amp. My Subaru has an 85 Amp alternator. I'm not sure how to figure it all out but I really have a lot of doubt a VW alt will run a inverter and if it would I doubt for very long.
I just looked and I am not sure if the Autozone is a generator or an alternator. It says alt but idk
Old August 18th, 2017, 09:41 AM   #7
vinayak
vinayak's Avatar
If you really are interested in an AC take a look here. I know a VW will run a 12v fan.
http://www.thegoodsurvivalist.com/ho...-easy-to-make/
I see ice machines for pretty cheap on Craigslist and a bag of ice is well under $3 a bag. Probably cheaper to do one of these then run the AC on most cars.
Old September 1st, 2017, 08:46 PM   #8
no such thing a s a stupid question.. only stupid answers and THAT is MY job!
forget trying to cool the entire interior
just cool your self
I have two blue ice bricks
When I sit down in my car I put one at the small of my back and one between my thighs right up against my family jewells
it definatly makes driving a non A/C car easier even stop & go traffic summertime in Tucson AZ
\also look at this also there are lots of homebrew variations of this theme
https://www.amazon.com/Ice-Water-Cir.../dp/B071ZNW6L5
Old September 2nd, 2017, 10:19 AM   #9
A damp towel around your neck helps.
Old September 2nd, 2017, 10:31 AM   #10
marnat3
marnat3's Avatar
I hang my head out the D/S window like I see dogs do.
marnat3 is online now   Reply With Quote
Old September 2nd, 2017, 02:41 PM   #11
Which explains a lot.
Old September 2nd, 2017, 10:09 PM   #12
marnat3
marnat3's Avatar
At least I wear the hockey helmet.
Old September 3rd, 2017, 08:37 AM   #13
And 'doggles?'
