Go Back   Cut-Weld-Drive Forums > The VolksRodders Forum > SH*T For Sale/Wanted > SH*T For Sale
Threads: 32,346
Total Online: 566
Old March 1st, 2013, 01:18 PM   #1
andk5591
andk5591's Avatar
Default Long list of Misc VW stuff
Price: depends   Location: State College PA area
We bought out a small shop - a bunch of assorted stuff. Wont ship large sheet metal or body parts. Prices negotiable, but plan on a reasonable price - not giving this stuff away. I don't need to....Parts are located near State College PA. Email preferred andy@aceansweringservice.com, but can text or call 8A-8P EST 814-360-7651.
4 sets new empi 9536 chrome lug nuts $5 set
4 sets new empi 9537 " $5 set
4 New empi 9567 black wheel centers 5 or 8 spoke $3 ea.
2 new bug CV joint boots - about 4 bolt sets for same
1/2 doz asst carb gaskets
new Empi 3160 Roller pedal $3
1 new, 1 used dual circuit master cyl reservoirs BObo
1 used single " BO
1 New set empi 8868 valve cover gaskets (Fits 8852) $3 set.
2 new 1316110551 65-67 rear wheel cylinders $6 ea.
1 rear wheel cylinder late $6
Bosch NOS 07124 vac can
2 New empi 4569 early rear wheel bearings
about 4 asst wheel bearing seals
1 new king pin trailing arm seal set
1 new front brake backing plate and 4 or 5 used (not sure if front or back)
1 New Chirco air intake screen CPR 119106 $5
1 used fresh air box (late) BO
1 used washer reservoir BO
2 used late glove box doors BO
1 used header with stinger - looks like basic empi or bug pack - pretty rusty
2 or 3 pulley tins - 1 is chrome BO
Box of late hood latches and assorted exterior door handles *No cool old ones*
some used pushrods and 2 used stock rocker assys
4 asst used vent windows
box of asst tail lights - most are so-so BO
box of assorted distributor - all are pretty ugly BO
1 box asst late headlight assys, a couple parts for an early headlight BO
2 wide 5 to 4 5/8" 5 lug adapters
2 wide 5 to 4 1/2" 5 lug adapters - 1 is missing the studs
1 box asst wiper assys BO
2 sets of high back seats Not real bad - bottoms so-so $50 pair.
New Late front apron assy $75
New early front apron assy $75 *one of these had been installed, then removed*
1 new late front apron assy parts not assembled $75
4 rocker panel bottoms (2 are cut off some) BO
1 pr top rocker covers $20 pr
3 outer rocker panels to attach runnig boards $10 ea
1 rear pass bumper bracket panel ww 11809022bx $10
7 jack brackets
Late drivers rear fender has diamond bumper cut out $20
Pair of used rear fenders from a 73 standard - good - one has some filler. $25each
NEW Pair new late (69ish) aftermarket front fenders. $50 each
61ish Passenger Front fender so-so $25
65ish drivers rear fender so-so $25
Pair late doors gutted - decent shape $75 pair
Pair late doors w/1 piece windows $120 pair
2 late hoods 1 with raised circle for VW $50 ea
1 early hood some rot front bottom BO
1 super hood BO
1 glass baja hood BO
Asst dash grills BO
2 no name aluminum valve covers w bales 1 chipped in corner
4 rusty chrome valve covers
6 ugly shifters
Asst ugly exterior mirrors BO
Used and asst patch panels. BO
1 43-1111-5 bottom cushion $10
2 43-1106 73-74 bug high back seat back cushions $15 each
Used e-brake handle BO
73ish partial steering column w ignition and TS switch BO
1 15x4.5 4 bolt aluminum wheel BO
Billstein jack - Type 2??? Good shape $30
DP intake
6 aluminum used crank pulley
5 asst used coils
1 gen and 1 alt stand. 113 101 211 E and G (g is alt or gen) $10 ea.
1 late upper front shock mount, 1 rubber bumper for same
4 Bosch 0339-019-456-000 relays
Mahle partial main bearing set.
2 late throwout bearings $20 each
2 fiberglass late front venders
[SIGPIC][/SIGPIC], 61 Cal look, "stock" 65 Bug, 69 VW woodie, 70s vintage Manx clone, 73 bug based hearse project, 67 "T" project and a 66 with probable Suby transplant.
andk5591 is offline   Reply With Quote
