Members: 17,576
Threads: 32,321
Total Online: 232
Newest Member: Wozza
- by bigguy
Old January 29th, 2010, 07:26 PM   #1
Dbug41
Dbug41's Avatar
Default BEAM EXTENDER "FAQ" THE BASICS 101
Re:: ask your Questions here! so everyone can learn
Newbies Ask your Qestions here
Well the title says it all
I would like to call on all the Veteran Volksrodders out there to assist me in answering the many and wide variety of questions out there
The new people coming in Volksrodding are deserving of our knowledge and this will help keep the other threads clean as well when it gets moved to the tech bin
so newbies please ask away
and guys...um please play nice
Read this thread
Beam Extender Install Walkthrough
http://www.volksrods.com/forum/showthread.php?t=29832
and this one too
How to build a volksrod..OFFICIAL NEWBIE GUIDE!!!
http://www.volksrods.com/forum/showthread.php?t=5617
I can't make it "idiot proof" the universe will just make a better idiot and send them my way
life is short make fun of it!
Dbug41 is offline   Reply With Quote
Old January 29th, 2010, 07:48 PM   #2
Default Re: BEAM EXTENDER "FAQ" THE BASICS 101
Lets start with the obvious:
#1 click on the link and read everything. Twice.
http://www.volksrods.com/beamextensions.htm
Old January 30th, 2010, 09:38 AM   #3
Site says:
"**Mounting & steering shaft extension hardware NOT included.***"
Question: Exactly what hardware is required, and who sells it ?
Old January 30th, 2010, 12:49 PM   #4
Dbug41
Dbug41's Avatar
the hardware required to mount the beam extender depends on how your going to do it.
I would drill out the threads in the frame head and double nut it with thick washers on the back side
This is the way Tequila did his and it works pretty well
he also extended the steering shaft
Palepainter did it this way
1. (4) 4 in 1/2 inch grade 8 bolts.
2. (8) Thick grade 8 washers.
3. (4) Split lock washers.
4. (4) Grade 8 nuts.
5. You will reuse the stock bolts that mount the beam to the frame head. Use these bolts to attach the extender.
as you can see there are many ways to do this
check these guys out they have everything you need
http://www.berrienbuggy.com/id121.htm
http://www.appletreeauto.com/u-joints-c-85.html
you can pick up the hardware at any nut and bolt supplier, I recommend grade 8 and locking fasteners
Old January 30th, 2010, 01:14 PM   #5
penono2
penono2's Avatar
Im a little confused on the options offered. ie bj/bj bj/lp etc. it that referring to the type front end its mounting to? or tie rods? is one way better than another? for example i have a 1974 standard, plan on replacing with an adjustable front end and 10" extender. by the looks of it they all mount the same or am i missing something. being that im basically starting from scratch i wanna make sure i continue to move in the right direction, as i dont have the money to be ordering incorrectly! im am a newbie with volks so the more info the better. thanks in advanced!
penono2 is offline   Reply With Quote
Old January 30th, 2010, 01:49 PM   #6
Someone will know what years were what
BJ= Ball Joint
LP = Link Pin
The spacing on the tubes is different, so you can't bolt a bj beam onto a lp pan.
Old January 30th, 2010, 02:00 PM   #7
bug was l/p through 65, b/j 66 and up
Old January 30th, 2010, 02:11 PM   #8
Link Pin was preferred by the Baja guys, because it allowed more wheel travel.
Some people prefer the look of the Link Pin shock towers.
Both work basically the same.
Old January 30th, 2010, 02:14 PM   #9
Originally Posted by Dbug41 View Post
...and double nut it ...
Personal preference, I would rather use
Nyloc nuts where ever possible.
Old January 30th, 2010, 03:20 PM   #10
zuez
Ok, heres the questions,
1. On the 10" ball joint / ball joint - 2 1/2" drop, corrected for castor. Would I need to cut a notch in the hood/trunk/lid up front?
2. And would drop spindles, put the frontend dragging the ground?
3. Do you make a reverse hood hinge that mounts to the beam extender.
zuez is offline   Reply With Quote
Old January 30th, 2010, 03:36 PM   #11
Al Low Ha
Al Low Ha's Avatar
I'd totally agree with Uncle's statement, "Some people prefer the look of the Link Pin shock towers"....you betcha!
Link pin suspension was favored by us old offroads because it was much sturdier than the ball joint version! Stock ball joints themselves would fail under the strain of offroading. The boots would rip and before long 'blamo' apart comes the ball joint and race over!
Kinda the same when lowering the frontend excessivly....(even with lowering ball joints). The ball joints just don't hold as well as the good ol' king/link pin suspensions.
I just installed my 8" extender today...My tips would be to: 1st disco the battery,drain and remove the gas tank. Disco to steering column and remove the shaft for later. Then only unbolt the body from the pan(Loosen the 2 rear shock tower bolts to the max-remove the rest.)...do not remove it completely. Jack up the front of the body till you have enough clearance Clarence to roll the front beam out(leave the tires/rims on!). Bolt up the extender and lower the body down to see exactly where you want to chop/hack/grind/torch/cut the inner quarter panels and spare tire well. Mark it and raise it back up & start cutting. Once you have enough removed (you think) roll your beam back in and loosely bolt it to your extender to see what more you want to cut away.. AND remember to allow enough clearance for your tie rods when the suspension is bottomed out! Took me less than 30 mins. Still have to deal with brake lines and the steering shaft mods..
Aloha
Old January 30th, 2010, 03:43 PM   #12
Dbug41
Dbug41's Avatar
1. yes, unless you go center steer or rack and pinon
2. no if you use stock sized tires
3. no i do not and i don't plan on it
Old January 30th, 2010, 03:53 PM   #13
zuez
Thanks,Dbug41
Old January 30th, 2010, 05:12 PM   #14
AirheadZim
AirheadZim's Avatar
Now we're talking!!! The previous posts to this thread hellp me SO much. Ended some of the mystery of the build. Good to know we can use common hardware for at least bolting the extender up to our current frame head. The nyloc idea of Unk's seems like a good one to me. A trip to Lowes should solve that problem. The more I read, the more I want to do this to my T1/T4. As I said in a previous post, If a VR brother in FL wants to make a few extra $$ on a weekend and you have a small portable welder and skillz to help an ol' pegleg VR do this in a couple in months, please contact me.
Zim
Old January 30th, 2010, 05:16 PM   #15
I went the double nut route only because I purchased grade 8 bolts, washers and nuts. Although a standard nyloc nut after a grade 8 nut would be good. Do they make Nyloc nuts in grade 8?
VW INC.
'67 Baja
'63 T-Bird
Devils Plaything
Old January 30th, 2010, 05:47 PM   #16
dt113
dt113's Avatar
I tapped the threads all the way thru, and used double nuts. I also added red loc-tite to everything.
My 2 cents
dt113 is offline   Reply With Quote
Old January 30th, 2010, 08:42 PM   #17
Dbug41
Dbug41's Avatar
Whozawhat your are correct, good call
A beam extension brace is a must have
see speedfreak thread (search, beam extension thread)
it's pretty much a step buy step guide on how to do it
everyone has a different way of doing it so it would be in someones best interest to learn the search function.
~and now a word to the wise about the search function~
Seriously if you are new here please use it. It is your absolute best friend, it will not judge you, it will not call you an idiot, or lazy all the info is here already for you to make that discovery of knowledge to empower yourself and get to it!
I will do my best to explain everything so that it will be "idiot proof" but I know for a fact that it is an impossible task. Just when I think I got it handled, the universe will make a better idiot and send him our way
Old February 1st, 2010, 05:36 PM   #18
ssleeper
ssleeper's Avatar
I noticed it your picture of the mounted extender that there is a brake master cylinder with a resivour on top. What is that from and will it fit on my 63?
Also I plan on using 1/4 plate for this extender, is that too thick? I don't mind adding some weight to the front end.
If you extend more than 8 inches to you need to add more than 8 degrees of caster to the front end? I want to extend the front end initially 10 inches on my first version but may want to go 12 inches. Do you need to add a degree of caster per inch of stretch?
63 Ragtop Baja
Think Slow Drive Fast.
It's not the size of the shop it's what you do with the tools inside.
ssleeper is offline   Reply With Quote
Old February 1st, 2010, 05:40 PM   #19
volvo 240 i believe reservoir but i am sure i will be corrected if i am wrong.
Old February 1st, 2010, 05:53 PM   #20
Dbug41
Dbug41's Avatar
Originally Posted by ssleeper View Post
1. I noticed it your picture of the mounted extender that there is a brake master cylinder with a resivour on top. What is that from and will it fit on my 63?
2. Also I plan on using 1/4 plate for this extender, is that too thick?
3. If you extend more than 8 inches to you need to add more than 8 degrees of caster to the front end? I want to extend the front end initially 10 inches on my first version but may want to go 12 inches. Do you need to add a degree of caster per inch of stretch?
1. Thats tequila's build ask him
2. no thats what I use
3. its all about the rake and the stance you want to run the higher the rear in relationship to the front, the more caster you will need, if you want to run it Gasser style the less caster you will need
Old February 1st, 2010, 05:59 PM   #21
I used 6mm (1/4") plate for the last extension I built, too.
Old February 1st, 2010, 06:12 PM   #22
ssleeper
ssleeper's Avatar
Yes I want a combo of the gasser long wheelbase and the hot rod look. I am thinking of adding an old short tractor style grill like off an old ford 8N or something.
63 Ragtop Baja
Old February 2nd, 2010, 02:43 PM   #23
Dbug41
Dbug41's Avatar
I've been asked several times about steering shaft modification
here are some pic's of one I did for Al Low Ha
cut 7" out of the middle
Used an inner sleeve of 5/8" 18 ga tubing about 6" long
to help with alignment
leave a 3/32 gap to pound the weld in deep
that way the weld deserves minimal sanding to become flush
easy peasy qiuck sand blast and done
enjoy A Low Ha ! sent it today "priority"
Old February 11th, 2010, 03:13 PM   #24
Dbug41
Dbug41's Avatar
For faster service please reply at my e-mail address:
doug_fuller@comcast.net
apparently I'm not logging onto the web site in my replies(Fucking Iphone with it's little fakeass buttons)
and I'm blowing up Steve's Blackberry like a dumbass
so please assist me in not being a dumbass
Hit my e-mail
too funny I just thought i would share that with you all
Peace!
Dbug41
Old February 11th, 2010, 04:07 PM   #25
PureC4
PureC4's Avatar
Answer to
#3
Tilting the hood foreword is easy. I had some 1/4 plate from pieces of my original straight axle set up. Hard part was for a beginner welder to weld plate to sheet metal hood. Used a couple of grade 8 bolts. drilled a couple of holes in the beam uprights and done............. after a bunch of work fixing the burn through and warping of the hood!. But on the good side I don't hit my head any more working on stuff... like wiring or putting gas in! Oh, and did I say I love Dbug's 10" extender.......
It's life, and you just got to play the Game.
We lust for what we want, and weep for what we need!
PureC4 is offline   Reply With Quote
