Threads: 32,380
Total Online: 238
Old July 2nd, 2005, 07:33 PM   #26
Ya, I'm 90% certain of adding thick metal stock as impact bars, probably right under the window area
Nick is offline
Old July 2nd, 2005, 08:30 PM   #27
Flipper_1938
Flipper_1938's Avatar
In the past, I had been thinking about putting the reinforcement inside the door, but what about integrating a substantial piece in the design of the door panel?
Flipper_1938 is offline
Old July 2nd, 2005, 09:11 PM   #28
Beetles from '74-up have impact beams in the doors.
Although, as narrow as Beetles are and with the thin doors, even with the impact beam I wouldn't want to be hit from the side.
Scott H is offline
Old July 3rd, 2005, 05:12 AM   #29
Side impact bars is only good for slow speed impacts (for the most part). I'm not makin a big deal putting one in on early cars. My doors just has alot less inner structural support so putting the bars in should even it out a bit just in case. I personally wouldn't read too much into making any early vintage car into the morden safety era.
Nick is offline
Old July 3rd, 2005, 07:36 AM   #30
Flipper_1938
Whatever I do to it, I don't think it will turn into a VOLVO (thank god!).
It's just that I know that they were beer cans when they were new.
50 years of rust and then me going after it with a sawsall, jigsaw, dremel, cut-off wheel, hacksaw or anything else that will cut.........adding some heavier gage sheetmetal or tube in a few critical areas couldn't hurt.
* EDIT * I guess there is a better thread for this to go in.....sorry for the sidetrack
Old July 3rd, 2005, 02:23 PM   #31
57Drag
57Drag's Avatar
How not to do it [img]style_emoticons/<#EMO_DIR#>/Idunno.gif[/img] .....Donald
57Drag is offline
Old July 3rd, 2005, 02:30 PM   #32
Maxx
okay...beyond being woefully inefficient, that just looks totally wrong.
Maxx is offline
Old July 6th, 2005, 08:27 PM   #33
Just ran into this hinge kit so just adding for future reference. It doesn't seem to have a deep hinge pocket like Rocky's kits so maybe a good setup for VW pillars?? and comes pre-alligned as well
http://www.ballsrodandkustom.com/hidden.htm
Also some places that sells safety latches (highly recommended on all suicide doors) for a good prices (seen other places that's closer to $100).
http://www.springfieldstreetrods.com/HTML_...esDoor-Vent.htm
https://host258.ipowerweb.com/~rockyhin/cgi...n&product=Locks
Emergency pull cable (if you go with power door locks and run out of battery)
https://host258.ipowerweb.com/~rockyhin/cgi...uct=Pull-Cables
Nick is offline
Old July 18th, 2005, 07:21 PM   #34
Probably the last update for this thread as the hinge part is pretty much done. Actually I'll eventually hook up a solenoid to these lock to unlock them from outside the car
I installed the safety door locks. These are REALLY easy to install. Drill 3 holes, bolt in the lock, drill 1 more hole on the door pillar for the pin to penetrate. Cut the knob rod to length and attach the handle. Done. Took about 5 minutes to install. Actually I'll probably be welding in a thin tube that's closed off at 1 end to the pin-hole to make it lok more finished and complete. The kit does come with a plastic grommet though but I prefer the internal tube [img]style_emoticons/<#EMO_DIR#>/Sawzallsmiley.gif[/img]
I highly recommend running this safety lock on anyone doing suicide doors to prevent the door from accidentally opening while driving. They have a built in sensor you can hook up a light or a buzzer if desired. They also have auto-closing locks close while driving.
Nick is offline
Old July 19th, 2005, 05:12 AM   #35
57Drag
57Drag's Avatar
I'm going to install them on mine....And going to use the pass side to lock the door and the stock icepick handle to lock the other.Yours is safer than mine because you have a Nader pin and I have a VW latch.......Donald
57Drag is offline
Old July 19th, 2005, 05:26 PM   #36
I have been contemplating the safety pin thing. I will definetly do it, I am just waiting to see if I come with any other options or cheaper Ideas.....
Nice work there Nick. I have had alot of problems with mine. [img]style_emoticons/<#EMO_DIR#>/Idunno.gif[/img] Finally got it where I feel comfortable with it but I have no Idea how well it will work with the door rubber in . [img]style_emoticons/<#EMO_DIR#>/unsure.gif[/img]
I was talking with a friend of mine about the problems I had had with it . He said the best way to do it is to reinforce the arears where the hinges and pocket will go first then add the hinges and pockets... this way they are attached to the stronger metal and will stay in place while the rest of the work goes on. Makes sense to me. He has done alot of this stuff and runs a custom body shop now with special VW discounts. [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
Jon is offline
Old July 19th, 2005, 06:38 PM   #37
I have safety pins on mine. They were there when I bought it of course [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] They look just like Nick's, have a little knob on them. They just go into a hole in the A-pillar on mine, no tube or anything fancy. They work great and keep the door from rattling so much since I don't have rubber in the doors right now. [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
I will get rid of the stock VW latches if I ever redo the car.
Nice work, Nick. [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
bugdust is offline
