Members: 17,720
Threads: 32,305
Total Online: 418
Newest Member: Harry66
Old November 15th, 2013, 03:16 PM   #1
noxided
Default V8 Volksrod Truck
It's a 1970 vw body I got for free
The frame is a Model T
1948 Ford Bed
1983 302 with 5 speed std
Thats all Ive got for now.
I need to channel it a few inches to sit level with the frame. The heater channels are rotted and I've heard of channeling it by removing the heater channels, but I've found nothing while searching.
noxided is offline   Reply With Quote
Old November 15th, 2013, 04:19 PM   #2
Default Re: V8 Volksrod Truck
Cool start, I'd suggest boxing the frame to handle the V8
Old November 15th, 2013, 08:44 PM   #3
Yeah, and the front wheels have too much camber....
Old November 16th, 2013, 11:26 AM   #4
noxided
Same with the back wheels, it's called stance. The tuners love it!
Old November 18th, 2013, 03:19 PM   #5
I like it!!
Old November 18th, 2013, 03:24 PM   #6
noxided
Before I can even get started on it, I need to find a front beam and doors.
I want to get the motor and trans. in place and then build the floor and the firewall before I do anything, but I cant without doors or a front axle to set the ride height.
Old November 18th, 2013, 09:56 PM   #7
RatRansom68
RatRansom68's Avatar
hello friend!! i know a guy we call the volkswagen wizard. his shop is @ 17598 FM 1485 Rd. New Caney, TX 77357 (281) 689 0061 ive known him for a while and he has every part you could ever want.
KDF-1
RatRansom68 is offline   Reply With Quote
Old December 10th, 2013, 03:20 PM   #8
"Kid Casey"
"Kid Casey"'s Avatar
finish this i would like to seee!
"2 Bits ta' Look N' a lil More ta' touch"
"Kid Casey" is offline   Reply With Quote
Old December 10th, 2013, 04:46 PM   #9
noxided
Ive got a little work done.
Found doors and a hood.
Cut out all the metal from under the hood to make room for a V8.
And thats about it for now.
Old December 10th, 2013, 05:37 PM   #10
The stock T frame is not real robust.
I would suggest some reinforcements,
like Lil' John Buttera used to do:
Old December 10th, 2013, 07:21 PM   #11
vdubbles24
Here ya go. V8 VW volksrod truck. Don't ask me the history "lol" this is the 3rd owners take on build I started.
http://westky.craigslist.org/cto/4225260728.html
The pile I'm building.
http://volksrods.com/forum/showthread.php?t=34796
vdubbles24 is offline   Reply With Quote
Old December 10th, 2013, 07:39 PM   #12
That 302 should really make your ride move right out. I like that you're keeping the stick shift and it's nice to see another Ford powered VR. What are you planning for a rear end? The 01/14 issue of Hot Rod has a good article on upgrading the cooling system on a pretty conventional '65 El Camino, but there are some really good ideas.
Old December 10th, 2013, 08:31 PM   #13
noxided
I have a rear axle from a Fox body mustang, its an 8.8. I plan on using the Mustangs 4 link and and coil springs.
Old December 20th, 2013, 07:24 AM   #14
I think the wheels have just the right amount of camber, it's the tires I'm worried about
I have a SBF in my other VW project, AKA the "BitchN Bug", the engine was in my wife's 12 second 1981 Mustang until Ohio started their long ago failed E-Check Program back in the late 90's, had to park the car, then it rusted away to nothing, the Mustang that is
Here's my V8 Bug http://www.volksrods.com/forum/showthread.php?t=17593
Old February 8th, 2014, 03:37 PM   #15
noxided
New progress. I got a boxed model a frame and droped front axle for free.
I also started on the rear of the cab. I used a tailgate that Ive had laying around. It works great, its structural and looks like it belongs there.
Old February 8th, 2014, 06:03 PM   #16
The boxed Model A frame looks good,. and the bed blends nicely. What's your plan for a radiator? I run an oil cooler which kicks in via an adapter between the block and oil filter. (I run a shorter filter for frame clearance : a Fram PH16 which is slightly larger in diameter to keep the filter volume the same as the longer stocker. There's a bi-metallic spring that allows oil to flow at 200 degrees or so. It works out really well when pulling or carrying a heavy load on hot days.
Old February 9th, 2014, 11:07 AM   #17
psychopork
psychopork's Avatar
i'm diggin it man, looks good. keep it up
Thanx psycopiglet,
Old February 13th, 2014, 09:00 PM   #18
Fir3ma5t3r
Sickie looking rod. Keep it up
Fir3ma5t3r is offline   Reply With Quote
