Threads: 32,384
Total Online: 679
Old February 26th, 2007, 01:16 PM   #76
bswilly
bswilly's Avatar
Default Re: The Southeast Corner
I always feel like I'm evesdropping when I come in here.You guys better share those pictures or I'm Tellin!!
1965 hard top...under heavy construction
1971 super vert/roadster...daily driver
2002 GTI...new car
www.ccvw.org <----my local club
http://images.dr3vil.com//files3/9/d...ns-animate.gif
bswilly is offline   Reply With Quote
Old February 26th, 2007, 02:55 PM   #77
I got my meter can in and the service/breaker panel in. I'll pick up the wire for it tomorrow that goes from the meter can to the service panel and then I can call the electric company. Before they get out here in 7-10 days I'll pput in my lights, switches and recepticles and run my interior wiring. Once all that is done I can call the county for the final inspection.
Old February 26th, 2007, 03:06 PM   #78
57Drag
57Drag's Avatar
Great news Charlie,I need to swing over and weld on my W lid
Here is a link to them pics....
http://albums.photo.epson.com/j/Albu...1&showall=true
57Drag is offline   Reply With Quote
Old February 26th, 2007, 03:41 PM   #79
Donald if you weld on your W lid you'll never be able to get into the engine compartment. I would keep the hinges.
Old February 26th, 2007, 03:46 PM   #80
57Drag
57Drag's Avatar
The part where the spring goes is cracked,And I'm tired of holding It up.I have a fluxcore welder here,But would rather use one with gas.I guess I could do It at Mike's
Old February 26th, 2007, 05:28 PM   #81
Mike who ? Not Panama ? He doesn't have a shop anymore.
I'd let you do it here with my 110 but by the time we arranged that you could aready have it done. Although i should be working on it this weekend unless some bullshit happens.
Old February 26th, 2007, 07:22 PM   #82
Donald, you're welcome to do it here but it will be a couple weeks before I get my final inspection and can use the Lincoln 255. I do have a little Linde 130EN with gas hooked up if you want to use it.
Old February 26th, 2007, 11:06 PM   #83
57Drag
57Drag's Avatar
No hurry,I'm off to go deep sea fishing.I hope we don't sink
Old March 4th, 2007, 03:52 PM   #84
erminger
erminger's Avatar
today I did a motor swap for Pedros 64 kombi. out with the tired OG motor and in with a fresh 1641. running great.
did it in my driveway with the floor jack. its easy with the bumper and rear pan removed. almost installs itself.
this should be the last one that the neighbors have to watch............the garage will be up on thursday.
life is too short to drive vanilla cars.
66 DC, 66 sedan, 32 Ford highboy, 40 Ford sedan, mini-winnie
erminger is offline   Reply With Quote
Old March 20th, 2007, 07:10 PM   #85
I finally got off my ass and finished wiring the shop. Well, enough to call for the inspection. I'll go back and add a ventilation fan, mnore lights and wire in my compressor after I have power to it. I'll call for the inspection tomorrow.
Old March 21st, 2007, 08:00 PM   #86
57Drag
57Drag's Avatar
Cool...
Old March 22nd, 2007, 01:52 AM   #87
Hey as far as a ventilation fan goes are you looking for a real one like an industrial type or just a fn to move the hot air out ?
I took a normal $7 box fan and built a plywood box around it and cleated it up side down over the vent and it does a great job of moving the hot air out. You get a slight breeze with it on but not enough to make everything blow around. Obviously could be a better with a stronger fan but it works alot better that expected as the hot air from the sealing goes away as well as fumes quickly.
Old March 23rd, 2007, 04:26 PM   #88
passed electrical & final inspections today. I put the covers on the panel and all the switch boxes, lights, etc. I also started back-filling the trench and low area around the shop but I had to stop 'cuz the hydraulics were low. Made a trip to Napa and I'll finish that tomorrow or Sunday.
I have to wait for the electric company to run the wire to the meter now. While I wait for that I'll figure out how to set the tension on the doors, clean the floor and put down the epoxy coating, build some sort of work bench, pour a concrete pad outside for my compressor (and a lean-to to cover it)and....whatever else I think of. Then, I get to start moving all my tools and junk in.
A couple steps closer.
Old March 24th, 2007, 04:48 PM   #89
4'x4' pad poured today for the compressor to sit on.
I also did a lot of tractor work at a buddy's house after being up at 4am (bed at 1am), work at 5, home at 2, and got the tractor back home at 8:15. Where's the ass-draggin' emoticon?
Old March 24th, 2007, 07:16 PM   #90
57Drag
57Drag's Avatar
Last weekend I put a stroker motor in the daily.Today we put the 40 horse back in It. .Have some issues with the distributor drive .VWs are a pain In the ass
Old March 26th, 2007, 02:41 PM   #91
I have power!!!!! I flip the switch and the lights come on! WOOOHOOOOO!!!!
Old March 26th, 2007, 05:12 PM   #92
57Drag
57Drag's Avatar
I have a Brown dash .Damn It sure looks funny .I need to work some more on my fan shround I'm smoothing out.Going to have to think of a new name for the Oval
Old March 29th, 2007, 08:08 PM   #93
Kustom
Kustom's Avatar
Originally Posted by erminger
here are some pics from the Winter Jam event at Charlies lot in Holly Hill.
they cruised to Sonic from the party. great fun.
are there anymore local events/meets coming up like this?
I live in st. pete here is my car.
Kustom is offline   Reply With Quote
Old March 30th, 2007, 10:34 AM   #94
erminger
erminger's Avatar
57drag....... you still in need of the roof section? it might not match your brown dash.
i make you good deal. what about $6000 for it, delivered to jax show?
Old March 30th, 2007, 12:45 PM   #95
Whats with the brown dash thing anyway ?
$6000 for a roof section theres gotta be a joke in there somewhere.
Finally got my damn M18 tap in. 15 minutes after getting it out of the mail box I was done with it. Put it in the ool box where it will sit for ever. If anyone ever needs the frame hornthreads chased let me know I got the tap for it.
Old March 30th, 2007, 01:21 PM   #96
erminger
erminger's Avatar
its a reference to daytona charlies pricing methodology. the price for anything is initially set at what he needs to get the next car .....compared to how bad you need the part.......then negotiated down to next to nothing.
the section is for over the drivers side door. which I just happen to have left over.
Old March 30th, 2007, 02:06 PM   #97
57Drag
57Drag's Avatar
I'm sure Charlie(Bugdust)will give me a rag section for free .But just In case,I need the panel .As for the brown Dash,Most of the car is Brown now.And I'm real tired of sanding
Old March 30th, 2007, 05:23 PM   #98
Tired of sanding get out a chisel and start scraping. Seriouly I have done it before. Had a car with like 15 layers of paint or something. First layer on top of the factory one wasn't really stuck so a little scraping and it all just peeled up.
Donald,
Gonna get with you sometime soon about measuring for a roll cage I think. I should be pulling the body really soon, thinking about it this weekend but my parents are in town. Once the body is pulled I will give the chassis to Charlie, if he still wants it and be ftting it to the other chassis. So it won't long now.
Charlie,
the chassis and title will be yours really soon if you still want it.
Old March 30th, 2007, 05:54 PM   #99
Donald, I'd give you the rag clip if I didn't have plans for it. But, I'll let you have it now if you replace it with another one. No biggie if it'll help you get your jalopy done. I have a complete semaphore rag clip but no semaphores. It's still a whole body right now, haven't cut it yet.
Jon, yeah man, I still want that chassis. I still have those buggy lights and baja bumper if you still want them. Get with me whenever.
Old March 30th, 2007, 07:57 PM   #100
erminger
erminger's Avatar
Donald, you are losing it.
you asked me if I had the section at the kruezer show, answer is still yes, its still yours and its still free.
i just need to cut away the useless metal surrounding it. and salvage the oval windshield top. one of us will need that for sure.
southeast corner, southeast volksrodders
