Total Online: 552
Old November 8th, 2012, 12:02 PM   #176
Dutch VeeRod
Dutch VeeRod's Avatar
Default Re: De Konjel
Mounted a fender just to see how it looked.
Think I need to make them a little wider
About 18cm
Bart
"De Konjel" Beetle BAJA V6 4X4 Syncro project
http://www.facebook.com/index.php#!/...andenbosch.501
Dutch VeeRod is offline   Reply With Quote
Old November 10th, 2012, 01:37 AM   #177
Dutch VeeRod
I'm fitting the rear fenders but need to make sure the are sitting correct
Need some help from you guys
Can someone measure the width of a rear apron of a '72 standard beetle. Not sure if there is a difference.
I need the width at the lowest point of the fenders/rear apron.
Thanks............
Bart
Old November 11th, 2012, 03:29 AM   #178
Borneoben
Location: Qatar, for now. Houston TX 2013, Fingers Crossed
What a great Project!
in the last pics the front track doesnt seem too much wider than the rear track but in some of your ealier pics the front track width looked WAY wider than the rear.
Is there much of a difference?
Cheers
Ben
Von Dutch: "The easy thing in life is realizing that everybody else is full of bullshit. The hard thing in life is realizing you might be full of bullshit, too".
So true...
Borneoben is offline   Reply With Quote
Old November 11th, 2012, 08:39 AM   #179
Dutch VeeRod
In the "pre"-assembly stage the track at the rear is about 32mm (1.259") per side less then at the front . At the last picture there is a spacer mounted between the bearing housing and the suspension arm so now the track at the front and rear is the same
Total "track" outside-left tire to outside-right tire is 1880mm (740.15")
Bart
Old November 11th, 2012, 10:54 AM   #180
Not to pick, but I think that would be 74.015 inches. Decimal point just skipped over a notch . :)
Old November 11th, 2012, 01:27 PM   #181
Dutch VeeRod
Oh, eeuuuhhh sorry Should be 74.015 inches.
Bart
Old December 1st, 2012, 10:34 AM   #182
Dutch VeeRod
Today removed the body to finish the chassis/frame
A lot to do
Bart
Old December 1st, 2012, 11:53 AM   #183
Kinda makes me want to find a wrecked syncro and build something!!!!!
Old December 1st, 2012, 02:54 PM   #184
I always love seeing updates on this project!!
Old June 7th, 2017, 07:31 PM   #185
Any updates?
