Members: 17,640
Threads: 32,294
Total Online: 483
Newest Member: wbvwguy
- by Frank3
- by bugdust
- by Vrshack
- by bugwhat
Old April 11th, 2016, 09:29 AM   #1
stnkbg1
Default Finally starting the SFR shop car
I bought this car about 8 years ago with grand plans to build something stupid. Unfortunately when you build vehicles for a living your own projects tend to get set aside a lot. In the mean time I bought a house with some land, built a new shop, built a lot of off-road cars, did a bit of racing, and started working on a second career flying airplanes. I've also been collecting a lot of parts along the way. Now it's time to start actually building.
Here are the basic specs.
  • 1968 Beetle, body shell only
  • full custom cromoly tube chassis and roll cage
  • Custom A-Arm Front suspension with Cantilever mounted Coilovers
  • 4-Link Rear suspension with Fox Coilovers.
  • Chevy 4.3V6 bored and stroked to 4.7L, roughly 300hp, front mounted.
  • 700R4 Transmission
  • Ford Explorer 8.8 rear end. Limited slip, disc brakes, etc.
  • 17" Ford Police Interceptor wheels & tires
The idea is to build a road race car, with a bug body and some hot rod style. Goal is to be under 1800lbs, which should make for some ridiculous power characteristics.
Here's what I started with.
stnkbg1 is offline   Reply With Quote
Old April 11th, 2016, 09:44 AM   #2
stnkbg1
Default Re: Finally starting the SFR shop car
It's been sitting in the corner of my shop for years, and I've pretended to get started a few times now, but pretty much all I got done was removing the pan and chopping off the parts of the body I don't plan to re-use.
Old April 11th, 2016, 09:45 AM   #3
stnkbg1
Here is the planned general stance and wheel placement.
Old April 11th, 2016, 11:52 AM   #4
stnkbg1
The one part of this project that is the farthest from my normal skill set is the front end. I build 4 wheel drive off-road racers for a living, and most of them have solid front axles. I'm quite comfortable with various link suspension setups, but IFS is something I've never really toyed much with.
I'm using some aftermarket Mustang II parts in here, mainly because they are available everywhere and cheap, with lots of support. I'm using 2" drop spindles, disc brakes and a Mustang II steering rack. The rest I'll be building myself. I also want it to be very adjustable, and easily adjustable. To help with the design process I've been building a lot of the parts in solidworks before actually cutting them out. Step 1 was the lower control arms. They will be primarily machined from 7075 Aluminum, and will provide for very easy camber and caster adjustment.
Old April 11th, 2016, 06:42 PM   #5
stnkbg1
It's easier when you don't look at the AvGas receipts.
Old April 11th, 2016, 10:22 PM   #6
Color me interested
Old April 12th, 2016, 05:57 AM   #7
Yup, she looks good to me with her nice 'hot rod' stance. What does Avgas go for a gallon these days?
Old April 13th, 2016, 08:46 PM   #8
stnkbg1
Depends on the airport. My home base is near $6 a gallon. I can fly 10min in one direction and get it for $4.35, and 10 minutes in the other direction and it's over $8. Just depends on the size of the airport and how bad they want your business. If there are commercial jets coming in, you better get ready to bend over.
I got the outboard control arm ends cut out and welded together the other day then rough machined the aluminum adjusters. I'll come back once the car is getting closer to finished and add the wrench flats, taper the ends and polish them up nice. For now they are just gonna stay raw since they are gonna get tossed around a bit during the build.
Old April 14th, 2016, 06:00 AM   #9
moler
A V8 Volksrod is on my to do list, watching in anticipation
moler is offline   Reply With Quote
Old April 14th, 2016, 08:10 AM   #10
stnkbg1
I'm a big fan of modded 4.3s. V8 power in a significantly smaller package, and they are bulletproof.
I will say however, if I didn't already have this motor from one of our old race cars I probably would have done a supercharged 3800. Even smaller packaging with just as much power potential. And boost!
Old April 16th, 2016, 11:20 PM   #11
stnkbg1
I spent a bunch of time playing around in solidworks figuring out the front suspension dimensions, and getting an idea how I was gonna build things. The first major part of the chassis to design is the shock crossmember that fits between the lower control arms. It'll be cut and formed from 1/8" sheet steel.
Old April 17th, 2016, 01:50 PM   #12
Try this Suspension Dimension toy
Old April 17th, 2016, 10:31 PM   #13
stnkbg1
well that's a fun little time waster there. Thanks.
Old April 18th, 2016, 03:46 AM   #14
It sure helps with suspension characteristics though, huh?
Old April 18th, 2016, 05:40 PM   #15
stnkbg1
Oh yes. One could spend eons playing with setups there.
Old April 19th, 2016, 11:09 PM   #16
stnkbg1
Turning virtual into reality.
Old April 20th, 2016, 03:46 AM   #17
See... Now that shit right there is cheatin'!
I'm jealous of the machinery for sure. Great looking start.
Old April 20th, 2016, 08:32 AM   #18
What, no sabre saw and cut off wheel?
Old April 20th, 2016, 09:17 AM   #19
stnkbg1
Those are just for when I make mistakes with the drawings.
Old April 20th, 2016, 09:17 AM   #20
stnkbg1
Old April 20th, 2016, 12:22 PM   #21
Beautiful work!
Old April 20th, 2016, 12:22 PM   #22
nshaddox
nshaddox's Avatar
Looks great. How many years did it take to accumulate all the nice tooling?
nshaddox is offline   Reply With Quote
Old April 20th, 2016, 03:35 PM   #23
stnkbg1
Been doing custom stuff of the Off-road world for about 13 years now.
Old April 20th, 2016, 03:54 PM   #24
I'd like to say I'm jealous, but I can barely use a mill.
Old April 22nd, 2016, 03:41 AM   #25
nshaddox
nshaddox's Avatar
I wish I had a mill and lathe to play with. Miss the days of working in the machine shop and being able to make anything.
