Total Online: 641
Old April 23rd, 2006, 07:21 AM   #251
speedfreak
speedfreak's Avatar
Damn Jon, that's coming out great. [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
Larry
speedfreak is offline   Reply With Quote
Old April 23rd, 2006, 01:53 PM   #252
twistedstang
Wow. Looks great John. Cant wait to see this one in person. Any possibility of making it to the Bugout with it?
Justin
62 bug
?? manx clone project<---next summer
80 mustang pro street project<--needs a new home
01 excursion V10 pig
twistedstang is offline   Reply With Quote
Old April 23rd, 2006, 02:40 PM   #253
<div class='quotetop'>QUOTE(twistedstang @ Apr 23 2006, 05:53 PM) Quoted post</div><div class='quotemain'>
I don't think I will make the Bug-Out with the Lead Sled. I am not even sure I am going to make the Bug-Out this year. I think it is the same weekend that I am leaving for the Type 3 Invasion in Oregon. Unless the Bug-Out is on Saturday again this year. Might make it then, but not with the Sled.
My goal is to cruise Woodward with it in the middle of August during the Dream Cruise. It won't be done, but I hope to have it driveable.
You can always stop by the house in Dearborn and check it out.
Old April 24th, 2006, 09:00 AM   #254
twistedstang
I might have to make that trip! Im probably going to the Fathers day car show at Greenfield village. Its the only car show I can drag the wife too outta pure guilt.
Justin
62 bug
Old April 24th, 2006, 07:15 PM   #255
Bobnotch
Bobnotch's Avatar
Location: Kimball, Michigan (about an hour north of Detroit
WOW John, you've been very busy with your project (makes me feel like I've been slacking). Love what you're doing to it, and I can see you've been thinking ahead too. : ) Your cooling air intake set up is similar to how a Notch is laid out, except that I think you can set it up cleaner using parts of the old system (under the fenders), and build a duct under your grills for the air and water to enter. The bottom of the existing air boxes already have drains built into them. :O Have you figured out how you're going to "spring" the rear deck lid? You could use some donor parts from Jane1, and keep the VW torsion bars. Otherwise, you've got a little more work ahead of you.
Keep up the good work, and maybe I'll swing by after the VW Vintage Festival. : )
Bob 65 Notch S with Sunroof and IRS
71 Square-now a 2 seat Roadster under construction now a SquareVert.
64 T-34 Ghia just finished in 2012
Bobnotch is offline   Reply With Quote
Old April 25th, 2006, 07:59 AM   #256
rodderdan
<div class='quotetop'>QUOTE(jaransonT3 @ Apr 14 2006, 09:53 PM) Quoted post</div><div class='quotemain'>
More progress today. Was nice having the day off. Got lots done. Nothing real obvious, but important stuff to do.
I trimmed off the glass seal flange on the quarter window opening on the roof.
I also got the cross bracing for the rear of the roof and the package tray fit and welded in.
I also managed to add a dimmer switch to the line feeding my welder. Makes a noticeable difference with my little flux core welder. I blow through much less frequently at about a 75% setting. Thanks for the tip Scott Woodard. Only took me 6 months to get around to doing it. [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
Dimmer switches are not made to handle the amount of amperage that a welder uses and is a potential fire in the making.Go to a electrical supply place and tell them what yuo need.You are risking major problems by using a dimmer switch.Better safe than sorry.
Old April 29th, 2006, 11:29 PM   #257
Got most of the rear package tray welded in today. Only have a small section at the top rear to finish up and some more welding on the seams.
I also spent Friday night at my buddy Glenn's place finishing up the machine work on the engine case for my 2.0L Type 3 motor for Sophy. [img]style_emoticons/<#EMO_DIR#>/Dancing.gif[/img] It is nice having friends with Bridgeports and lathes. [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
<div class='quotetop'>QUOTE(rodderdan @ Apr 25 2006, 11:59 AM) Quoted post</div><div class='quotemain'>
I would have thought the same thing, but Scott Woodard did his whole radical rod with a dimmer switch on his cheapo welder without any problems. I used a metal electical box for the switch and it is welded to the cart I built for my welder. I don't expect any problems, but I will keep an eye on it. Thanks for the concern.
Old April 29th, 2006, 11:38 PM   #258
car looks awesome john! very, very cool
Old April 30th, 2006, 08:25 AM   #259
nice detail...
but why dont you ever work on this car... damn you are slow...j/k
Old May 1st, 2006, 12:55 AM   #260
notched
notched's Avatar
Ya! You're makin' us slacker look like, uh, slackers!
Very inspiring work John!! I look forward to more progress!
Phillip Bradfield
Old May 7th, 2006, 07:17 PM   #261
A little progress this weekend on the Lead Sled. I spent most of the weekend working on my Squareback, Sophy and getting my oldest son confirmed. Was a good weekend.
Here is the progress...
Get the last patch panel welded in on the package tray. A little more welding and grinding and it will be all set.
I also managed to shave the bump for the front license plate. Michigan doesn't require one.
And I started to fill in a little bit at the a-pillar. You can sort of see the filler panel/reinforcement at the back edge of the pillar on the lower 1/3. I will continue that shape all the way to the roof.
Old May 7th, 2006, 07:38 PM   #262
I'm diggin' this project big time, John. Way to go man... this is going to be one of those rides people will be talking about! [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
Old May 7th, 2006, 09:08 PM   #263
squareback_fiend
squareback_fiend's Avatar
man your verey talented
67 bug
58 sub hatch westy
i like to party with my pants on my head
squareback_fiend is offline   Reply With Quote
Old May 7th, 2006, 09:36 PM   #264
john, are you going to do the a-pillar reenforce like my speedster's? it is pretty stinking sturdy.
Old May 8th, 2006, 03:34 AM   #265
<div class='quotetop'>QUOTE(1slo3 @ May 8 2006, 01:36 AM) Quoted post</div><div class='quotemain'>
I am adding an extra "L" section to smooth out the back edge of the pillar. This will act as my reinforcement. I considered radiusing the bottom rear corner into the door, but it didn't look right when I mocked it up. I want to keep a sharp corner between the top of the door surface and the A-pillar.
Since I will have a roof attached to the top of the windshield (unlike some people I know [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] ), I will need less reinforcement than otherwise.
Old May 8th, 2006, 02:43 PM   #266
HotRodMatt
HotRodMatt's Avatar
Hi John, No pics of the guy in Sydney who has grafted the fasty roof to the notch and the Cusso bonnet yet, only pics on his phone... hopefully soon.
Just a question about the lights. Are you going to slide the stock trim ring under the eyebrows? Or french them further in?
-- If it's old or rare - cut it! --
HotRodMatt is offline   Reply With Quote
Old May 8th, 2006, 07:14 PM   #267
<div class='quotetop'>QUOTE(HotRodMatt @ May 8 2006, 06:43 PM) Quoted post</div><div class='quotemain'>
Stock headlights will be mounted recessed back a little bit from stock and then concave beauty rings wil be used to trim out between the headlight lenses and the fender.
Kind of like this.
Just Photoshop, but you get the idea.
Old May 9th, 2006, 12:29 AM   #268
HotRodMatt
HotRodMatt's Avatar
Thanks... kinda like what I was considering, just not having any joy finding rings to suit.
Old May 9th, 2006, 04:33 AM   #269
<div class='quotetop'>QUOTE(HotRodMatt @ May 9 2006, 01:29 AM) Quoted post</div><div class='quotemain'>
Hey Matt... what you want are '52-'54 Mercury headlight rings. That's what most customs are running for that frenched-in look. Most of the rod n kustom parts places sell them.
Headlight rings on Night Prowlers (look about halfway down on the right)
Old May 9th, 2006, 05:23 PM   #270
HotRodMatt
HotRodMatt's Avatar
Thanks Steve, been prowling the shops here but nothing really right yet. Might have to import something. Or fabricate something...
Old May 9th, 2006, 05:34 PM   #271
Late '70s Chrysler Cordoba(sp?) had nice chrome trim rings,
suitable for frenching headlights.
Old May 20th, 2006, 08:52 PM   #272
Finally got a break in the weather and got Sophy's new interior in, so I can get back to the Lead Sled. Made a little progress today. I got the outer filler panel welded into the roof rail area above the doors on both sides. Will add the inner pieces tomorrow after the Michigan Vintage VW show and I will be one step closer to getting the roof welded back on. [img]style_emoticons/<#EMO_DIR#>/Dancing.gif[/img] [img]style_emoticons/<#EMO_DIR#>/Dancing.gif[/img]
Here are a couple of pics.
You can see how much I moved the roof forward from these since the back of the filler patch is where the b-pillar used to be. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
Old May 20th, 2006, 09:04 PM   #273
FONZY
FONZY's Avatar
oh man that is such a freakin groovy car man!:)
love the idear. had a thaught for you.. I could totally see putting about a 30 degree rake on the taillightsn lean em forward a good bit ya know? then fill in the lower are below the taillights to continuue the longer angled rake, move the bumper out , and add a continental kit!:)
looooooong and low... :)
just somethin to ponder:)
keep it up man, I cant work on my heap for a while yet so It keeps me HARd watchin you cats do yer thing:)
Old May 20th, 2006, 09:37 PM   #274
Wow man, the lines of this car are really starting to come together! The roof looks awesome [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img] I think Fonzy is on to something with the tail lights too. They don't need much, just lay them down about an inch or so at the top to flow with the line of the c-pillar. Either way it's looking killer! I can't wait to see it lowered (photoshop anyone? [img]style_emoticons/<#EMO_DIR#>/unsure.gif[/img] ).
Old May 20th, 2006, 10:26 PM   #275
Slammed and skirted.
Not sure about the tailights yet. Definitely won't have a continental kit on it. Have never cared for them.
