Forum Stats |
Total Online: 602
February 25th, 2010, 01:25 PM
#151
Re: My concept for the general Vee
My guess would be diesel. My dodge red-lines at like 3500rpm.
February 25th, 2010, 02:44 PM
#152
Your green parts car isnt a 59, the under hood area is later
If it comes in a box, It's not custom !
Intro
February 25th, 2010, 03:21 PM
#153
Thanks spraybomb. I will reference the numbers tomorrow. Its going to be a bunch of sections soon. So I guess the year is unimportant. I was guessing the year from the fenders that had beeshive taillights on it.
February 25th, 2010, 07:18 PM
#154
Times a thousand. U/min is basically german for RPM but what would base line at 2k
[edit]
*blink*
Yay, Fail again. It's been one of those days
Originally Posted by Mikelrome
February 25th, 2010, 09:03 PM
#155
I have to tell ya Ace, I dunno on this one.
February 26th, 2010, 05:51 AM
#156
It's an oven timer...
February 26th, 2010, 06:34 AM
#157
I plead the 5th, or at least temporary stupidity. And on that note, I'm going to hide
February 26th, 2010, 10:37 AM
#158
interesting gauges...When I still had my 1965 Vw Fire bus (ex-German fire dept.)I had 3 VW powered water pumps(exGerman fire dept.) and a VW powered generator...all had vdo tachs with lower RPM readouts....just a thought, maybe yours is from an industrial engine?...
Aloha
February 26th, 2010, 04:17 PM
#159
Lookin good!! You couldnt resist not changing that windshield could ya! I'm glad I did mine!!
-Gary
February 26th, 2010, 07:47 PM
#160
You are right Gary,I have to. I am considering splitting the frame into two separate sections and peaking it in the middle if there is enough room to create a peak that is around 2 in offset from the end points. I have a bunch of measuring to do before I do any cutting at all. This way I could blend it into the existing cowling with out haveing to remove the entire cowl. I would just be building on top of it.
February 28th, 2010, 12:13 PM
#161
Spent the morning before Olympics Hockey finishing the upper door window frame. I removed the headliner attachment that is spot welded to the upper roof section. Then I took round stock and fit it in the gap between the door frame and roof. Then I tacked it in place. After that, I cut a filler piece for the old glass section in the upper door frame. I still have a bit more fill welding and grinding to do. Now on with some hockey!!!
I also spent some time today sizing up the early cowl section and windshield area. Here are a few pics.
March 1st, 2010, 04:13 PM
#162
There is something special about welding above your head. It is a sure way to get rid of back hair.
It is these mundane quite uncreative parts of a build that I think we all look forward to. I am methodically putting them between the fun stuff. You probably have noticed, but I am attacking the car one side at a time after I finished the chop. I get frustrated tripping over all the air lines and grounding cords.
I finished up the upper right front area. All the slices and relief cuts for the capella chop are now completely sewn up inside. If I feel that dam emergency brake and the seat tracks digging into my back side again........
I also got the preliminary cut made for the rear inner sail panel. The plasma cutter was used with a cardboard template for a quick pattern cut.
March 2nd, 2010, 06:04 PM
#163
March 3rd, 2010, 04:18 PM
#164
March 4th, 2010, 06:10 AM
#165
Here are some pics of the tank and rack. I am going to paint it up when the time comes, perhaps a little airbrushing on it.
Also the rack in progress.
March 6th, 2010, 08:20 PM
#166
Today I only got about an hour in on the rod before my buddy came over with his motorcycle that needed some hacking and welding. Spent most of the day looking over at my car making a plan of attack for Sunday.
I did get some drawing time in this evening sitting down and came up with this Ratfink inspired drawing. I have some shading and stuff to do on it, but am done for the eve.
March 6th, 2010, 09:38 PM
#167
THAT'S RAD! Always the art critic(kinda my job)...since it's the "General" Vee...how's about some General's Stars on his helmet.....think Patton...2cents..
Aloha!
March 7th, 2010, 05:24 AM
#168
Cool pic Mike! I like the 'bars' on the helmet now
March 7th, 2010, 05:54 AM
#169
 That has to become a Tee Shirt!!!
freaking awesome man I love it !!!!!
life is short make fun of it!
March 7th, 2010, 08:29 AM
#170
TEE-SHIRT!!! Hell YESSSSSSSS!......large long sleeve black please! That doug...he's always thinkin! I'm sure Steve'o would agree too....Steve?
March 7th, 2010, 04:57 PM
#171
I spent most of the morning fitting and welding up the inner sail panel on the passenger side. Then disassembling the entire dash getting ready for the mods to it. I am debating as to what guages I will be running. I am thinking of keeping them all down the center of the dash. I will make a center type of console to house the components.
I found a balljoint beam on Craigs in good shape. 30 smackers and it was in my truck. I am going to put the adjusters on this one then dump the one I have. I also finished up under the hood. It had a huge gaping hole from the heater that needed dealt with.
I am just about done with the passenger side, time to flip the car around after I finish up dash. Still sizing up the early windshield frame.
March 7th, 2010, 05:07 PM
#172
Oh ya, I got this off The Samba. I am using alot of wood on the inside. I will be blasting it with all kinds of fun designs.
March 9th, 2010, 07:32 PM
#173
Got a few items in today for the beam rebuild. Bushings, adjusters...etc. Still waiting on the balljoints. I ordered a Scat Shifter. The same one I had in my old Notchback. I loved that thing. Had to have one for the General.
Tonight I made a plan of attack for my dash and side panels. It will be a mixture of wood, and Woodland BDU ripstop fabric, I am also considering a mix of powdercoated aluminum diamond plate for inserts here and there.
I head off to Cali for a business trip this week and am going to hit a few stores while I am in SoCal. Look out credit card. :)
March 10th, 2010, 03:46 AM
#174
That dash concept looks awesome..after seeing your remodeling woodworking, I'm sure your interior w/ some lumber is gonna look sweet. I also freaking love a hinged 'shield. I would love to do that...kinda tuff with a curved Super shield I would imagine though
March 16th, 2010, 06:43 PM
#175
I just got back from 5 days in Kaleeeyaforneeeya working on guitars. Good to be home.
So with an hour of extra daylight...Weeeee!!!! I am so happy about that. I went forward with the gas tank. It worked out just the way I had hoped. I had to space it up to get it through the hood just right. Took a bit of messing around but very happy with the results and should get plenty of miles out of it. I am going to see about getting a stock fuel guage sending unit in there. If not, it has a rubber tube on the side of it for a quick visual.
I also sanded down and made the wood repairs on the Superior 500 steering wheel I got of the The Samba. The rivets got sandblasted to determine how badly they had deteriorated. They were not presentable, so I filled the front holes with black epoxy and then sanded it down and followed everything up with a shitload of Danish Oil. I am going to paint the chrome section of the wheel that was badly rusted. The Horn section needs springs, should be easy to adapt some.
Thread Tools |
Display Modes |
