Total Online: 595
Old January 29th, 2008, 04:19 PM   #1
bugfink
bugfink's Avatar
Default l.e.d. tail light question
I want to run a set of led bullets for my tail lights. Any tips on wiring? I have them mounted on the bumper, and thats as far as I've got. Thanks.
bugfink is offline   Reply With Quote
Old January 29th, 2008, 05:30 PM   #2
sour-kraut
sour-kraut's Avatar
Default Re: l.e.d. tail light question
are they gonna be turn signals or just lights?
73ratrod, 72 bus,73 bug
sour-kraut is offline   Reply With Quote
Old January 29th, 2008, 05:30 PM   #3
sour-kraut
sour-kraut's Avatar
i got some bullet lights on the rear and i got them to work as the tail light, brake light and turn signal
Old January 29th, 2008, 05:32 PM   #4
erminger
erminger's Avatar
wiring would depend on them being single or double filement type.
lengthen the wires from the old taillamps, attach to the new taillights.
make sure there is a good ground to the light.
you will likely find that the LEDs dont draw enough power to trip the turn flasher.
two easy fixes 1) electronic flasher 2) wire in standard bulbs inside the car to add a load
I used standard bulbs in 4 harley duece turn signals for my stop and turn lights
life is too short to drive vanilla cars.
66 DC, 66 sedan, 32 Ford highboy, 40 Ford sedan, mini-winnie
erminger is offline   Reply With Quote
Old January 29th, 2008, 06:40 PM   #5
Haukola
Haukola's Avatar
You could also install a dummy load wired in parallel -- try Watson's Street Works.
Haukola is offline   Reply With Quote
Old January 29th, 2008, 10:51 PM   #6
bugfink
bugfink's Avatar
just running and brake. my turnsignal arm broke off and I may just be to lazy to replace it. my friend said the would work as running but not brake, so thats why i ask
Old January 30th, 2008, 04:35 AM   #7
purplepeopleeater
purplepeopleeater's Avatar
Get an early taillight housing and use one of these as a donor
only $10 at HF.
yeah, not my idea...but i'll take credit for it.
purplepeopleeater is offline   Reply With Quote
Old January 30th, 2008, 05:51 AM   #8
I might try that! Make my own custom taillight buckets and put those in them. Sweet!
Old January 30th, 2008, 12:40 PM   #9
sour-kraut
sour-kraut's Avatar
good idea!
Old January 31st, 2008, 06:00 AM   #10
I believe those just have one set of LEDS in them. So you can use them for tails or brakes, but you'll have to do some moddin' to make them do both in one housing.
Old January 31st, 2008, 06:16 AM   #11
purplepeopleeater
Here is where I got the Idea, Let me know if you need more...I know the guy that is done this
http://rbcdunebuggy.yuku.com/topic/1...s-sort-of.html
Old January 31st, 2008, 06:18 AM   #12
purplepeopleeater
" The stock VW lens seems to pass the light just fine, but the picture should show more. Don't forget to tie the green and yellow wires together to get the brake light (brighter) to work. The brown wire is for the lights (dimmer). "
Old January 31st, 2008, 07:37 AM   #13
I stand corrected. Those look great and cheap!
Old January 31st, 2008, 08:31 AM   #14
purplepeopleeater
yep, HF had them onsale for $7.99
Old January 31st, 2008, 04:21 PM   #15
SHARK
For anyone looking to run LEDs as turn signals... The kit set ups I've used just came with in line resistors when they are for use with a standard flasher switch. If you measure the amount of draw the bulb you are replacing has you can match it with a resistor from an electronics store.
SHARK is offline   Reply With Quote
Old January 31st, 2008, 04:28 PM   #16
SHARK
I put these in Terry Arfons 34 sedan about five years ago at a shop I worked at. The kits were not the best quality and I had to modify most of the wiring for them to work correctly...
Old February 1st, 2008, 10:01 PM   #17
gravguy
gravguy's Avatar
instead of a load on the wiring you can change to a digital turn signal relay about 9.00 at pepboys auto parts
IM BACK ok now scream and run in fear
FACEBOOK VERY WILD CAR COMPANY
gravguy is offline   Reply With Quote
Old February 2nd, 2008, 09:23 PM   #18
bugfink
bugfink's Avatar
So I hooked them up today (not as complicated as I thought (I'm just dumb)) only to find out that they were not that bright! I used the digital relay that I had. Plus when the brake was on it was hardly noticeable. Any thoughts on making those fuckers shine?! Cuz they look so clean.
Old February 2nd, 2008, 10:34 PM   #19
Social_Joe
Social_Joe's Avatar
I just read through the linked forum post, seems the guy had to mod his wiring to run 2-filament instead of three for these to work. I guess he used the trailer harness adapter trick, either way, this is a slick as hell mod, for dirt cheap.
Nice find!
Social_Joe is offline   Reply With Quote
Old February 2nd, 2008, 11:15 PM   #20
bugfink
bugfink's Avatar
I want to put a pic up of the lights. Is there another way other than using a web link? or should I just do a "photobucket" type account?
Old February 3rd, 2008, 08:15 AM   #21
purplepeopleeater
the trailer relay is the only "easy" way to get these to get bright, go get one at napa and you'll see!
Also, its about the only way to go getting your blinkers/running lights/brakelights all working on the same bulbs
Old February 3rd, 2008, 09:18 AM   #22
I must be an idiot.... haha
Unless they're all hidden behind the firewall and i have to yank my engine to see em, i cannot find the wires i need to connect my "taillight converter"...
everyone here says it's easy and every shop I ask says it's impossible....
Old February 3rd, 2008, 01:43 PM   #23
Social_Joe
Social_Joe's Avatar
Should be able to get to them where they come down by the sides of the engine before they go through the inner fenders to the tailights.
Old February 3rd, 2008, 02:06 PM   #24
I've got dual webers... they take up a lot of space and limit what i can reach.. :(
Old February 3rd, 2008, 02:10 PM   #25
Social_Joe
Social_Joe's Avatar
likewise, those duals eat up all that space. You could install it behind the dash. The tails and blinker wires are all right there and you can just cut the brake light wires at the master cylinder and run them up to the magic trailer box.
