Total Online: 669
Old July 30th, 2007, 05:03 AM   #401
Default Re: Type 3 VolksRod
looking pretty sweet john!
Old July 30th, 2007, 01:18 PM   #402
PAPA_SMURF
PAPA_SMURF's Avatar
great work man...
can you still take the tire off the drum where you lowered the fender line? I know it gets really tight on the buses whe lowered.
...Joey
66 schwinn, 04 Jetta
vwclubofhawaii.ning.com
Old July 30th, 2007, 01:40 PM   #403
Originally Posted by PAPA_SMURF
great work man...
With the way it is right now...no way!
I started noodling around with a couple of ideas to address this issue after see some of the Lead Sled pics that were posted today. I am going to do a few sketches. WIll post them up later.
If they don't end up working for me.....there is always fix-a-flat.
Old July 30th, 2007, 02:00 PM   #404
john, put a piano hinge on the belt line of the rear fender, then hide it with early wide trim!
65 Sunroof Notchback
Old July 30th, 2007, 02:38 PM   #405
notched
notched's Avatar
Piano hinges only work if they're flat...
Phillip Bradfield
Old July 30th, 2007, 05:46 PM   #406
OK...here is my concept to fix the rear tire/wheel access and clearance issue. Cut a curved wedge out of the lower half of the fender in front of the wheel arch. Hammer form a filler panel that has a radius on the outside so that the lower rear portion of the fender blends into the filler panel. The inner forward edge of the filler panel meets the fender at close to a 90 degree angle. Kind of hard to explain.
This will move the lower rear of the fender out a couple of inches at the bottom giving me some clearance. It will also give me an additional bodyline detail that I can accent with the chrome trim.
Something like this......
Yes? No? Let me know what you think.
Old July 30th, 2007, 05:48 PM   #407
Top one with the trim.
Is it done yet?
Old July 30th, 2007, 06:01 PM   #408
They are all just views of the same idea. Just didn't add the trim to the bottom two. You will have to use a little imagination.
Old July 30th, 2007, 06:02 PM   #409
yes
Old July 30th, 2007, 06:03 PM   #410
i like the top one too.... killer
Old July 30th, 2007, 06:04 PM   #411
Hotrodpez
Hotrodpez's Avatar
Location: Mission Viejo, Orange County, Kalifornia, USA, Earth, Sol System, Milky Way.
Mmmmmm. *drool*
- Luke
__________________________________________
Originally Posted by bugdust
If you can't measure your own floor then this project may be too much for you...just my opinion.
People who say im hard to shop for must not know where to buy beer...
Common parking lot conversation...
Its a volksrod...
Yes, it runs...
Yeah I drive it...
No, I'm not crazy.
Here's to living single, seeing double, and sleeping triple!
Myspace: http://www.myspace.com/lukepezanoski
Hotrodpez is offline   Reply With Quote
Old July 30th, 2007, 06:16 PM   #412
Will it just be a "bump" ala '54 Chevy style,
or will it have functional venting? Either way I'm feeling them.
Old July 30th, 2007, 06:39 PM   #413
Just a bodyline/bump. The functional vents will be on the cowl between the rear window and the decklid.
Old July 30th, 2007, 10:54 PM   #414
spraypaintspecial
spraypaintspecial's Avatar
A quick fix if you want to leave the Fender skirt..... Unbolt the fender when the time comes to remove the Wheel!
PANHANDLE PANSCRAPERS
http://img.photobucket.com/albums/v2...69/BlogSig.jpg
spraypaintspecial is offline   Reply With Quote
Old July 31st, 2007, 07:36 PM   #415
Only if the fender still unbolts. I am not sure that it will when I am all done with the mods. Maybe.
Anyway......I really liked the concept drawing I did last night so I thought I would play around tonight with making a patch panel for the extra bodyline.
I started out with a flat piece cut out of an old hood. After laying out the shape of the bump I started hammering it over a couple of different body dollies clamped in my vice. A few relief cuts and lots of hammering later, I ended up with this...
I was liking it and it didn't take as long to form as I thought it would, so I laid out some cuts on the fender and got out the cut-off wheel...
then I clamped the patch panel in place...
I have lots of triming and fitting to still do before I weld it in place, but I am liking the look of it. And it really does help with my fender to tire clearance issue...
Before this change, the back of the fender opening was tight against the tire. Now I have a couple of inches of clearance.
Old July 31st, 2007, 07:48 PM   #416
schweeet!
Old July 31st, 2007, 08:28 PM   #417
Absolutely killer, John!!!
Old August 1st, 2007, 06:04 AM   #418
jkien65
jkien65's Avatar
Now you need to get it done so you can DRIVE it to Steve Meet IV next year. That would be cool.
Old August 1st, 2007, 06:08 AM   #419
purplepeopleeater
purplepeopleeater's Avatar
Nice
purplepeopleeater is offline   Reply With Quote
Old August 1st, 2007, 06:28 AM   #420
NightScreams
NightScreams's Avatar
The mods work. I like it better with the "bump out" than I did before, removes it further from the T3 look and more traditional sled. Nice!!
Yeh, another Scott.
Intro
Project: The Freak
Are you good at something technical?
My RideSpace
Page
My little voices are having conversations with your imaginary friends and it is starting to piss me off.
NightScreams is offline   Reply With Quote
Old August 1st, 2007, 06:33 AM   #421
Actually, my goal is to be able to drive it to the 2008 Type 3 Invasion a year from now.
Lots to do to make that goal, especially since I keep coming up with more modifications to do. ...... a year from now.
Old August 1st, 2007, 03:59 PM   #422
carcentric
Grateful Member #484
carcentric's Avatar
What would you think of leaning the bubble forward more at the top - so it's closer to parallel with the roofline - like this (or even more so)? Might need to be longer then, maybe even extending over the rear of the door a bit . . . .
M D "Doc" Nugent
Old August 1st, 2007, 04:04 PM   #423
It's probably easier to see the shape in person.
In the pics,the different colors throw the eye.
Old August 1st, 2007, 09:39 PM   #424
welshj
welshj's Avatar
I was gonna ask, but I didn't get to it in time....
What about going real traditional "slead" and going with fenderskirts? Fab up some skirts that cover pretty much your whole area there... trim out the fender well around your wheelwell and cover it with the removable skirts...
You could even make the "bubble" area into the skirts.
Just form them a little more convex in the front and in the wheel well area.?
I'll search for a few pics to give you an idea of what I mean.
joel
welshj is offline   Reply With Quote
Old August 1st, 2007, 09:56 PM   #425
welshj
welshj's Avatar
The last one's pretty wild... but you get the idea?
joel
