Forum Stats |
Threads: 32,433
Total Online: 221
April 3rd, 2021, 01:17 PM
#151
Re: The Roach
Case studs are out. Next... clean again and reinstall the case savers that came out with the studes. New CBPerformance mil-spec studs go in!
65 Sunroof Notchback
April 3rd, 2021, 01:18 PM
#152
Re: The Roach
Originally Posted by V8Transporter
Wow, your engine is looking like a slick ‘metal sculpture. Nice work!
Has to... car will look like crap ;)
April 3rd, 2021, 06:55 PM
#153
Re: The Roach
You mean it will show off a ‘heavy patina?’🤔😀😀
April 3rd, 2021, 07:41 PM
#154
Re: The Roach
Haha... sure ;)
April 17th, 2021, 05:26 PM
#155
Re: The Roach
I think there’s a five gallon of ‘patina‘ somewhere around here. Want me to see what UPS would charge to ship it?
May 5th, 2021, 09:56 PM
#156
Re: The Roach
House remodel is almost complete. 4 weeks until graduation and then vw time again
May 6th, 2021, 05:38 AM
#157
Re: The Roach
Everything of mine is stalled too. Gotta find the time.
May 22nd, 2021, 07:16 PM
#158
Re: The Roach
Long overdue modification today.
Since the speedster's beginning, the large engine cover has been held on by bolts. This made removal for servicing slow and replacemenf slow. It worked well, but was annoying. Fast forward 25 years or so and now it is held by hood pins. 30 seconds to remove! The sad part is... I have had a set of hood pins hanging on a hook for more than a decade. Doh!
June 30th, 2021, 03:14 PM
#159
Re: The Roach
Well, I bought some used fiberglass notch fenders to sort the twisted up/torn metal issues I have on the original rear fenders. They finally arrived and someone had cut them to fit to a fasty/square. So, plan B!
Start pounding on metal!!! There was a significant push on the RR between the light base and trunk lid. It was twisted, bent opposite the correct curve and basically a complete mess. When I started this a couple hours ago, the inside edge if the lamp base was 3/8" to 1/2" away from the metal. Now, the complex lower curve is all I still have to move. Woot!
Any suggestions on how to close the remaining gap wpuld be awesome! I am a complete novice with my hammer and 2 dollies.
June 30th, 2021, 05:18 PM
#160
Re: The Roach
I’m a ‘novice also, but you’re doing a great job.
June 30th, 2021, 05:19 PM
#161
Re: The Roach
This thing must have been hit hard. Between the push and the big dent in the trunk lid... oh boy.
August 20th, 2021, 02:01 PM
#162
Re: The Roach
Rear body wiring in, less license light
The right rear lamp housing isn't a perect fit, but compared to before I beat on the fender, it is awesome.
August 20th, 2021, 11:02 PM
#163
Re: The Roach
I started fitting the flush mount rear window tonight, but I need to buy a new drill bit. Only the center upper and lower holes are drilled so far.
August 21st, 2021, 12:15 PM
#164
Re: The Roach
August 22nd, 2021, 06:14 AM
#165
Re: The Roach
Looking good! I have no progress in my garage. That has to change.
August 22nd, 2021, 09:10 AM
#166
Re: The Roach
Yeah, great to see your progress. I love the ‘stance and those very cool wheels. Nice work at the rear fender.
August 27th, 2021, 01:34 PM
#167
Re: The Roach
I’m not familiar with a ‘poly’ rear window. Do they install like a ‘stock one?
August 27th, 2021, 01:58 PM
#168
Re: The Roach
No, racing window. Flush mounted with rivots, screws, dzues fittings...
September 1st, 2021, 10:06 PM
#169
Re: The Roach
The day I brought it home:
Now:
Done? No... but much closer to being something!
September 2nd, 2021, 06:28 PM
#170
Re: The Roach
Lookin’ good! Are you thinking a set of ‘nerf bars for bumpers?
September 2nd, 2021, 06:29 PM
#171
Re: The Roach
Nope, I will get some stock, shiny bumpers and trims to contrast the paint.
September 2nd, 2021, 09:51 PM
#172
Re: The Roach
Next is adding a tab where circled to keep the fender off the rear of the 8 inch wide slicks.
September 3rd, 2021, 02:14 PM
#173
Re: The Roach
I was having tire rub issues backing the red car up. Thought it was both sides...come to find out, the right side was almost 1.5" inboard! This is the same side that I had to reshape the rear fender around the light. Just got it all squarish again. No more rub!
I am very glad I happened to start on that side. Also, that car had negative camber and was rubbing. I raised the rear about an inch to lesson this a bit and still no rub. It was a good day!
September 5th, 2021, 03:13 AM
#174
Re: The Roach
Looking good.
May 2nd, 2022, 10:24 PM
#175
Re: The Roach
Well, after a major step back from damage on one of the heads, I am finally moving forward again.
Last night, the case savers, mil spec headstuds, pistons, barrels, heads, exhaust and manifolds were all installed. I like where it is. Now to tear it all back down and clean evreything again! But, it will work! The fk-8 cam, the Comp Eliminator heads, the 11.7:1 compression, the 1.5 rockers, the dry sump, the 1 3/4 header... all happy sharing the same space!
The only new parts on this engine are the bearings and the oil pump. And, the intake manifolds if I keep it n/a for a time.
Thread Tools |
Display Modes |
