Threads: 32,397
Total Online: 606
Old October 4th, 2011, 07:23 PM   #1276
OB'S Customs
OB'S Customs's Avatar
Default Re: Type 3 VolksRod
Thanks Scott. I am really liking what you are doing with your Square. I would love to see some overall pics of your Square without all the camera effects.
HAHA I need to check my auto correct on the phone next time...John sorry about that.
Spencer
OB'S Customs is offline   Reply With Quote
Old October 5th, 2011, 07:53 AM   #1277
Spencer
I have been called worse.
Old October 30th, 2011, 07:00 PM   #1278
Spent some time in the garage today working on the Sled. Got the both rear fenders mounted with a couple of bolts and the passenger side starting to be patched in. I am going to get the bolt on locations good and solid and then take the fenders off, do metal work to get them fully welded and a s smooth as possible and then bolt them back on and get them welded on so I can start the bodywork.
Old October 30th, 2011, 07:25 PM   #1279
OB'S Customs
Nice I like the way they look!
Old November 13th, 2011, 08:07 PM   #1280
Spent a few hours in the garage this afternoon working on fitting up the rear fenders on the Sled. Made a couple of pieces to fit on the bottom front of the rear fenders...
Got one of them bolted up and tacked in place....
and got some more filler pieces tacked in...
I also started noodling on the possibility of changing up the dash. I scored this very cool early 60's Rambler dash from Unkl Ian last weekend.
I really like the shape and lines of the instrument cluster. I think it fits the lines of the Sled a bit better than the early Ford Dash I have in there now. Not sure I am ready to do that much tear-up at this point...
Decisions, decisions.....
Which ever one I decide to go with, the other will end up in the next project....the Track V!
Old November 13th, 2011, 08:19 PM   #1281
Old November 13th, 2011, 08:22 PM   #1282
What if you spliced the Rambler speedo, into the Ford dash ?
Then you could use the Ford, or T3 speedo, in the Rambler dash.
It would save a little work, instead of changing the whole dash.
A nobody would know exactly what it started as.
Old November 25th, 2011, 02:23 PM   #1283
OK...The Rambler dash option has been bugging me lately so today I decided to strip the dash down to just the sheetmetal and do a little mock-up. I had to cut the dash in half in order to get it to sit close to correctly in the car. Will ultimately need to remove about 8" from the center if I go this route.
Anyway...here are some comparison pictures between the new proposed Rambler Dash and the current 49-50 Ford Dash.
So which do you like better? Any and all opinions welcome. I think I want to change it out to the new proposed dash. I think the lines fit the car better....
Decisions....decisions....decisions...:pani c:
Old November 25th, 2011, 02:45 PM   #1284
new one flows better but old one is less work
Old November 25th, 2011, 02:47 PM   #1285
Less work???.....:fu nny:
I laugh at your less work.
Old November 25th, 2011, 02:51 PM   #1286
lol. Hey someone needs to poke fun.
Old November 25th, 2011, 04:39 PM   #1287
shok
I vote current.
shok is offline   Reply With Quote
Old November 25th, 2011, 04:56 PM   #1288
I like the horizontal speedo, over the round one.
Not sure if I would swap the whole dash, or just the speedo.
Old November 25th, 2011, 05:15 PM   #1289
Man, all that work you did to make the Ford dash work! But yeah, I like the Rambler dash. It seems to kind of fit the type III style.
Old November 25th, 2011, 05:36 PM   #1290
grumpy
Mr. Asshole Moderator
grumpy's Avatar
Rambler
Old November 25th, 2011, 06:24 PM   #1291
Budreaux
Budreaux's Avatar
I'd say your proposed dash does flow better, but only because I personally do not like the way you shortened the current dash. I'd do something different to the center bottom line of the current and go with that personally, but I'm biased as to it;s the same dash I'm fitting in my project. I don't really like the squared look of the proposed dash, but I do like the speedo section.
Old November 25th, 2011, 06:35 PM   #1292
sandfreaks
sandfreaks's Avatar
I think Current unless you end up filling allot of those
switch holes in the proposed.
I think the proposed speedo looks better though.
Old November 25th, 2011, 09:17 PM   #1293
I think the proposed Rambler dash looks like a better fit for a Kustom like this one and the current dash will look great in the track roadster!
Old November 25th, 2011, 11:32 PM   #1294
notched
notched's Avatar
Undoubtedly, the Rambler dash.
Phillip Bradfield
Old November 26th, 2011, 12:43 AM   #1295
Rambler.............
Old November 26th, 2011, 05:15 AM   #1296
StickerDick
StickerDick's Avatar
proposed dash. Or just sell the whole car!
Old November 26th, 2011, 06:51 AM   #1297
Thanks for all the input. I am still undecided. Did a little Photoshop work this morning to clean-up the proposed dash concept.
Still not quite sure.....
Old November 26th, 2011, 01:44 PM   #1298
baja1978
baja1978's Avatar
i think the rambler.
The Fat Bastard of Volksrods
'72 VW Super Beetle
'06 Chrysler 300C Hemi
baja1978 is offline   Reply With Quote
Old November 26th, 2011, 03:36 PM   #1299
StickerDick
with the overall look you're going for, it would be really cool.
Old November 26th, 2011, 04:51 PM   #1300
I like the ford dash, it has a hooded headlight feel to it. I think the feature works better contrasting with the rest of the dash. Although, either will work with the car as cool as it is.
