Threads: 32,421
Total Online: 375
- by f4u5t
Old February 22nd, 2011, 08:47 AM   #101
Default Re: homemade
It runs like new, I hooked it up at my friends who gave it to me and it runs very nice and smooth.
Thanks for the switch idea, I will just relocate it to the front of the saw.
Old February 22nd, 2011, 09:32 AM   #102
Pop
Default homemake tools
I thought that some of you might be interested in ideas for some homemade tools. The 8 foot brake was built from plans. I built the 30" brake to fold up 1/2" sq. and up, channel. I also built the 12" shear. The last picture is the fuselage jig for a Bearhawk, ( homebuilt airplane,4 seat, for bush flying). Built 4 fuselages from the jig. Pops
Pop
Old February 27th, 2011, 05:13 PM   #103
NONYA
Default Cheap home made crank pulley puller
Cut 3" off an old steering wheel puller I had so I could pull the crank pulley in the car,Im sure some have already come up with red neck solutions to not having the proper tool but I thought I would post mine.
NONYA is offline   Reply With Quote
Old March 1st, 2011, 03:43 AM   #104
My "redneck" version uf pulley puller inolves a piece of wood and tapping opposite side with a mallet. They come off really easy.
I guess yours was stuck ?
Old March 1st, 2011, 09:37 AM   #105
NONYA
BIG TIME
Old March 3rd, 2011, 05:12 AM   #106
Grayhair
Grayhair's Avatar
Default Re: homemade, weld buggy
This has been in process for awhile.
Pulled 220v power to the cart with 20 amp end fro the plasma and tig boxes, then split into a 110v quad box. The 110 is used for a dedicated grinder for the tig machine and the wire welder. Also added a air manifold so that I can hook up to the shop air for the plasma box and have a couple of extra ends for die grinders or a blow gun. Welded old used up air fittings to the top of the frame for places to store air tools when not in use.
Grayhair is offline   Reply With Quote
Old April 3rd, 2011, 06:16 PM   #107
VWMan#30
VWMan#30's Avatar
for a body-lift-off-the-pan tool (other than our backs) we have a comealong hooked to the rafters of the shop and some straps tied to body.
to all the pricks that buy their cars....
VWMan#30 is offline   Reply With Quote
Old April 3rd, 2011, 07:17 PM   #108
Did that too.
Old April 4th, 2011, 04:18 PM   #109
I have done that as well as used my engine crane to lift the V8 Bug body up so I could roll the chassis out from under it. I have also used both the engine crane and come-a-long to raise the Bug body up.
Old April 4th, 2011, 04:46 PM   #110
I use my engine hoist to take the top part of the Manta body off.
Old April 4th, 2011, 11:00 PM   #111
Jeff (or Jill ) posted a picture, I think the world just wobbled a little bit
Old April 5th, 2011, 04:19 AM   #112
norville
norville's Avatar
I'm sure, it's not new to most folks but, I used my 225 Arc welder as a frame cutter last night. Cranked it all the way up and grabbed a big fat rod. Once it struck it zipped right through the metal. I felt like a Jedi Knight.
I cut this wire times and it's still too short.
bob
norville is offline   Reply With Quote
Old April 5th, 2011, 06:52 AM   #113
Yes, I posted a picture. I do that a lot.
It' JiI (Jeff in Illinois)
The wobble was just because of the pork sandwich I had last night.
Old April 5th, 2011, 07:43 AM   #114
Pop
norville-- You can buy a rod holder that compressed air hooks up to and use a carbon rod for that purpose. Works good. Pops
Pop
Old April 5th, 2011, 07:51 AM   #115
norville
norville's Avatar
spill it Pops, I was just thinking that would be a great idea..
bob
Old April 5th, 2011, 09:03 AM   #116
Works excellent, on thick stuff.
Also very loud.
Old April 11th, 2011, 08:17 AM   #117
Double D
Double D's Avatar
My simple tool for removing or installing the rear hub nut.....also works well for tourqing the flywheel gland nut.
Old April 11th, 2011, 09:07 AM   #118
Stray Catalyst
Stray Catalyst's Avatar
Making the form.
Metal, cut to shape.
In process...
And, finished! I still need to curve it, but it's close to done now. Thank you, Hotrodheb!
Stray
Old April 12th, 2011, 12:09 AM   #119
dt113
dt113's Avatar
I work by myself, most of the time.
I built this to lift floorpans and bodies.
I also added a small winch to it.
Old April 12th, 2011, 08:45 AM   #120
I work by myself 99.9% of the time too. Makes you be extra careful!
Old April 12th, 2011, 10:13 AM   #121
dt113
dt113's Avatar
YES IT DOES!! Learned that the hard way!
I built the A frame extra wide, but used a pipe inside the cross over pipe. Then added the bridge over it. I picked up the front of my Chevy p/u with it, with no problem.
Everyone says I overkill, everything that I build.
I added 8" rubber tire casters to the A frame, plus a tow bar attachment. I can hook the 4 wheeler to it, and use it outside now.
Old June 19th, 2011, 07:14 PM   #122
I can move it later if you want to add more?
Old June 20th, 2011, 10:57 AM   #123
busguy71
busguy71's Avatar
To un-seize a seized engine:
soak the cylinders with ATF or whatever oil you choose. Then take a spark plug, remove everything from it but the threaded part, weld a grease fitting to it, and pump grease into the motor until it moves. Nothin like hydraulic pressure to get things moving! Only downside is you have to remove the head to clean the grease out, but if the motor was seized its probably going to happen anyway
Everyone sucks but me
X- GT40 builder
busguy71 is offline   Reply With Quote
Old June 25th, 2011, 11:16 AM   #124
I'm not sure this counts.....
PoorBoy Paint booth?????
Sorry, didn't get a pic of the fan I installed at that filter. There is another 24"x24" filter that allows fresh air into the PoorBoy Paint booth.
And it works well as many of you know.
Old June 25th, 2011, 01:37 PM   #125
If it works, it works!
home made tools
