Go Back   Cut-Weld-Drive Forums > The VolksRodders Forum > SH*T For Sale/Wanted > SH*T For Sale
Threads: 32,379
Total Online: 864
Old March 19th, 2011, 05:45 PM   #1
kjwalters
kjwalters's Avatar
Default Badd ass Ghia for sale
Price: Neg   Location: Peru IL
Hi guys
Most of you know me by my car. The V10 Ghia that was awarded CBOTM here a little while ago.
Long story short, becasue of heath problems the car will not be completed. After 3 years of intense work that has been called Top shelf fabrication the project will end. I will sell the whole project or will part it out. There has been over $125,000 spent on this project. If you check my thread you can see I am not exaggeratring. Here is a quick list:
-Fresh never run V10 Built right with the best parts well over 650+ HP and over 600 FT lbs reliable day after day. Comes with a custom "stand alone wiring harness" and custom tuned engine computer allowing you to drop this in any vehical -$30,000+ to build.
-Transilla JR T-56 6 speed race trans close ratio Quicktime SFI bell scatter sheild, Ram dual disc race clutch, Ram flywheel, B&M short shifter (1000HP capable)-$5,900 invested.
-Air Ride Tech Modified Air Pod with (4) 8000 series double adjustable shockwave airshocks-No controller- $3400 invested.
-20" and 22" KCM Nova Whells with Vredstien Rubber Never used mustang bolt pattern- $2637 invested
-Cyberdynes digital gauges- Full set Digital Blue with memory and warning. Fuel level,Oil PRessure, Oil Temp, Water temp,Volts,O2,Abient air temp,Dakota Digital speedo, fuel pressure. $645 invested
-G-Tech Pro EGS Tachometer (full set)- Awesome tach never used.
OBDII upgrade, Progessive shift light, Acclerometer, wide Band 02 Invested $1000
-Flaming river Chrome Steering column with tilt and GM plug. Waterfall Billet steering WHeel, billet adapter, horn kit and billet signal arm kit. Never used. Invested $975
-Flaming River Billet Steering Rack Nice , Never used- $700 Invested
-67 Ghia All steel Body, Cages, flip front, new tin work, hand formed dash, complete tube chassis set up for V10 but can easily put in a small or big block. Comes with custom CNC Independant front suspension (not shocks) and secondary cross slide steeing, All new rubber, all new glass, all new chrome, lights and baddging... To much work to list $37,000 + invested.
Makes me offers. Or request pics of items and I will send them your way. Thanks
kjwalters4510@yahoo.com
Jamie
kjwalters is offline   Reply With Quote
