Members: 17,473
Threads: 32,275
Total Online: 477
Newest Member: JBCustoms
- by yimbo
Old January 21st, 2010, 09:14 PM   #1
ratrog64
Default Deck Lid Hinge Ideas
I'm looking for ideas on how to mount or hinge my motor cover. I have done a tranny raise and the stock hinge mounts won't work. I could use stand off but i prefer the look of the normal position better. I'm sure some of you have done some pretty cool things and i'm hoping you won't mind sharing!
Thanks
ratrog64 is offline   Reply With Quote
Old January 21st, 2010, 09:46 PM   #2
Default Re: Deck Lid Hinge Ideas
Seems to me I have seen a raised engine/tranny using the stock hinge mounts before. The fan shroud had notches cut into it.
If your normal brackets won't work, but what if you made custom brackets that meet up with the stock decklid hinges. Then you could pop the pins out of the decklid hinge and replace them with cut off dipsticks. Same diameter as the pins and make a quick easy pull out removeable lid, since you might not be able to open the lid all the way.
Just open 3/4 the way and pop it off.
Old January 21st, 2010, 09:57 PM   #3
ratrog64
cool, i like the dip stick idea!
Old January 22nd, 2010, 06:48 PM   #4
KQQL66
KQQL66's Avatar
or instead of a dipstick (which sounds a little Dodgy to me) you could use an R clip, I use them in my decklid and they work great no hope of them rattling out either and very easy to use.
KQQL66 is offline   Reply With Quote
Old January 22nd, 2010, 08:07 PM   #5
Double D
Double D's Avatar
Ahhhh,,, now that's "Thinking with your dipstick Jimmy"
Old January 22nd, 2010, 09:19 PM   #6
KQQL66
KQQL66's Avatar
I just You tubed the Castrol advertisement, Thats thinkin with your dipstick" Very Funny Indeed we dont have that one on Air Down here in OZ
Old January 23rd, 2010, 06:31 AM   #7
rodderdan
Some 30's-40's cars used external hinges.Some were pretty cool looking.Iv'e seen some used on Volksrods with good results.Most were pot metal but some were stainless and can polish up nicely.You can always paint the pot metal ones or use them as is for a rat look.
Old January 23rd, 2010, 06:53 AM   #8
ratlook63
ratlook63's Avatar
http://images.thesamba.com/vw/classi...ix/2475651.jpg idea for the hinge pin... seller on the samba. I'm sure you can rig up something like that for cheap.
Wanted:
Split tail lights. Repop ok!
My Band
Old January 23rd, 2010, 11:38 AM   #9
That would so hurt like hell to get swatted with a dipstick!
Old January 23rd, 2010, 01:42 PM   #10
ClassicGMJunkie
ClassicGMJunkie's Avatar
bugroadster (coalition vendor) has some latch/hinge kits that might do the job.
62 Impala 2dr HT build
70 Cabrio build
Intro thread
Old January 25th, 2010, 01:36 PM   #11
Dodgy ? Its the same diamter and sprung. It fits in there tight and doesn't slide out unless you yank on it. It's perfect as though it was made for it. Trust me it works better then a R clip unless you have come across a metric one and then it will still rub on the hinge.
It's not big and bulky like the hitch clips either.
Old January 29th, 2014, 06:41 AM   #12
holy old thread batman!
So I'm at the point now with my 1776 that it's about ready to go back in the car and hopefully run again..
I've got to figure out how I'm reattaching the rear apron and put the decklid back on.. I have te D-clips for this, but I've never figured out how to get the old hinges apart.. The decklid itself curves in such a way that it's difficult to get a good angle with a punch and hammer to tap it out, what have you all done in the past?
Old January 29th, 2014, 11:33 AM   #13
I used a smaller then the size of the pin punch. Drives right out. Just back up the back side so you don't tweak the hinge.
