Members: 17,639
Threads: 32,294
Total Online: 471
Newest Member: 87cortez
- by Frank3
- by bugdust
- by Vrshack
- by bugwhat
Old February 25th, 2014, 04:00 PM   #51
OHenry
OHenry's Avatar
Default Re: Body between rear wheels
I made a set of drop plates for my V-Rod, it lowered it down about 4 inches, I still need to flip my trailing arms & drop the lower shock mounts so there is enough travel, at the moment I only have a few inches of travel, but it's stiff enough that it only hits the spring plates upper limit on big pot holes
I'll fix all that once it warms up, I'll be sure to take a few pictures when done
Cool, how did you design the drop plates? I was looking tonight and it doesn't look like there's room. I'm tempted to cut the mounts on the spring plate and sliding them up and re welding them.
OHenry is offline   Reply With Quote
Old February 26th, 2014, 09:13 AM   #52
OHenry
OHenry's Avatar
So here's what I came up with, figured out the angle that the mounting points need to be at and made a masonite templete. Now I'm going to cut and re weld the mounting holes at the proper location. Should get me in the neighborhood of 3" drop.
Untitled by redrumvw3, on Flickr
Old February 26th, 2014, 11:08 AM   #53
jkien65
jkien65's Avatar
Photobucket is being a bitch right now or I would upload the pics I have. These aren't mine, but I did them the same way.
File Type: jpg 198372_316860608406040_1835759324_n.jpg (83.0 KB, 2 views)
Old February 26th, 2014, 04:46 PM   #54
OHenry
OHenry's Avatar
Good deal, at least I know I'm on the right track now
Old March 1st, 2014, 11:28 AM   #55
OHenry
OHenry's Avatar
One down, one more to go!
Old March 1st, 2014, 09:46 PM   #56
I like how you did yours, but you have a swing axle correct??
I have an IRS & it's not the same, I had to move mine in a slight arch so it all bolted together, I'll look for pics of it & try to post them in the next few days
Old March 2nd, 2014, 03:10 AM   #57
OHenry
OHenry's Avatar
Thanks, no I have Irs that's why I put the angle in so it didn't bind when I bolt it up.
Old March 2nd, 2014, 12:05 PM   #58
Ok, at first I looked at the pictures that jkien65 posted thinking those spring plates were yours, but after reviewing all the pics again I see yours are from an IRS
I just need to grind away some metal here & there so it stops hitting the spring plate stops as I mentioned earlier, as well as lower the bottom shock mounts so the shocks don't get ruined from bottoming out all the time
Old March 3rd, 2014, 02:18 AM   #59
OHenry
OHenry's Avatar
Ohhhhhh that makes sense now!
I think I might actually cut the stops off completely and do a mini C channel or something along those lines so the rear control arms have some where to go. Otherwise I'll never get the pan to the ground and the body between the wheels. That seems easier than doing a torsion bar raise, but time will tell.
