Members: 17,639
Threads: 32,294
Total Online: 470
Newest Member: 87cortez
- by Frank3
- by bugdust
- by Vrshack
- by bugwhat
Old February 15th, 2014, 07:23 PM   #1
Default Wiring question
Re:: Grounding on a Dune Buggy
Ok so I am wiring my Buggy and I have to ground certain things that ordinarily be grounded on a steel car. No big deal, except when it comes to the Speedo.
The warning lights and fuel gauge ground out through the circuit at the senders or flasher... etc.
But the actual lights that light up the speedo I am not sure how that circuit works, it looks like I gotta ground it.
So my question is: Do I have to ground the Speedometer ? If I do will it throw anything else off ?
I figure I could ground it at one of the mounting bolts if I have to. This is the first time I have done a full wiring job so I am learning alot so far.
Old February 15th, 2014, 09:25 PM   #2
johnny27030
johnny27030's Avatar
Default Re: Wiring question
The best I can remember, the speedo has to be grounded out. So yea just running a wire to one of the mounting bolts should be fine.
johnny27030 is offline   Reply With Quote
Old February 16th, 2014, 04:11 AM   #3
Most run a ground strip bar and then run all grounds to it for lights and such.
Old February 16th, 2014, 07:21 PM   #4
big-guy is right. A ground buss bar is the best way to go!
Old February 17th, 2014, 02:57 PM   #5
I have only the Speedo , 2 Relays and a Flasher to ground under the dash so I am just gonna run ground wire running from those to the chassis.
All those components are with in a few inches of each other and then only like 2 feet max to ground.
Everything else will ground right at where they mount, so its easy enough.
