Total Online: 581
Old August 31st, 2011, 02:09 PM   #1
rick huckins
Default vw choptop roadster
Re:: it aint a custom till ya cut it up
hello
the bug started its life as a 1967 boreing, 34 yrs later its in the hands of a father son team with a sawsall grinders and welders shits about to change . first chop the top 4 in, use the rear fenders as the rear roof section,window track frames welded to the body,rear section still in the works alot ofgoing on here trying to decide what to do with it ,34 coupe desine or just add a hood dont know yet your help here would be nice so give me your in put .
thanks
rick huckins from hempstead texas
and noyet
rick huckins is offline   Reply With Quote
Old August 31st, 2011, 02:33 PM   #2
Default Re: vw choptop roadster
Sweet idea using the fenders! Drag that ass end out into a pickup and you've got one of my extended cab truck ideas.
gonna be a challenge to open and close the doors with the windows up if you're gonna be runnig door glass
Old August 31st, 2011, 02:58 PM   #3
There ya go fellas! Off to a good start.
Old August 31st, 2011, 03:42 PM   #4
rick huckins
going to use electric window mtrs and a remote,also thought about a pick up bed
Old August 31st, 2011, 03:58 PM   #5
I'm pretty sure he means because of the door frames tacked to the roof. A bed would give it that cool Aussie Ute look.
Old August 31st, 2011, 05:01 PM   #6
Sounds like the remote idea will definitely work, but a bit of a pita and maybe even a bit of a safety issue you might want to think about. Definitely the elCamino/ UTE look I was thinking!
Old August 31st, 2011, 05:23 PM   #7
rick huckins
ok windows will be down more then up becouse of this texas heat so should be ok now about the bed design do you have any picks i have owned several caminos so i can see it as part of the vw and would be easy to do i dont want the ass end to be to heavy so please give me all your input thanks for the help.
Old August 31st, 2011, 06:17 PM   #8
That's a very good idea using the fenders like that
One day I'd like to build a truck style Bug and make it an extended cab, but what is the cheapest way to go from the normal upright fan shroud to the flat ones they put in the type 3's and/or type 4's
If that cost to much I'll just build a flat stake side bed so they are removable if need be
Well maybe I should do a search and see how others have done it, I know I have sen a few pictures on here, so I'll do a search in the morning
Old August 31st, 2011, 06:49 PM   #9
Very Cool, one question you gonna fill in those Qtr.s ?
Old September 1st, 2011, 02:29 AM   #10
rick huckins
thats the plan but dont know wich way im gona go , headed more toward the truck idea the oragenal plan was to go like the 34 ford rear end but you know how that shit goes you start with a plan in your head and on paper then ya look at the pile of metal on the floor and you say to your self well lookie here those rear fenders cut up would make good roof coners and it starts all over agine so give me your input good or bad and we will see what comes up next .
Old September 1st, 2011, 03:11 AM   #11
it's been done several ways. My favorite is the silver one that's been on the net for years.
this is a photochop but bitchin'
real deal and one of my fav's
interesting idea. pretty cool actually but not "camino-ish"
Old September 1st, 2011, 10:49 AM   #12
71super
nice! i like that fender idea! gonna steal that one if its ok with the big guy rick huckins. looks bitchin already!
71super is offline   Reply With Quote
Old September 1st, 2011, 11:28 AM   #13
38Chevy454
38Chevy454's Avatar
Good idea on the fenders, but how are you going to do the rear quarter windows with flange on bottom and front and no flange on the rest?
You can also split the window frame on the body so the front door glass sets against it, rather than up into it. Look at the way convertibles or any hardtop type car has the side window rubber for ideas. I realize it messes up your window frame portion connected to the door, this would also require modification.
Last, a small technicality - a roadster has no top or a removeable top. Your car is a chopped top, but not a roadster.
Old September 1st, 2011, 01:10 PM   #14
radiotrib
radiotrib's Avatar
Take a look at what Mouldy is doing in the UK
http://z13.invisionfree.com/VolksRod...ic=4372&st=180
Old September 1st, 2011, 01:46 PM   #15
rick huckins
the roll of the rear fender will hold the glass im going to use the black window urathane to put all the glass back in no rubbers
Old September 1st, 2011, 02:27 PM   #16
rick huckins
71 super steal away i used the rear and cut them on the running board side cut off 2 " and went from their.
38chevy454 you are correct its not a roadster its a coupe my fault sorry .you are some what like my wife correcting me but thats ok if i can put up with her i can take it from you no hard feelings .
Old September 1st, 2011, 05:43 PM   #17
71super
nice! I can't wait to see it when it's done!
Old September 3rd, 2011, 05:00 PM   #18
rick huckins
i called a junk dealer i know asking about a short wheel base truck bed and when i arrived at the shop this morning sitting out side the gate were 3 truck beds a nissan,toyota and a chevy s 10 now wich one to cut up and make fit. im glade my junk dealer is also the chife of police brother or id be worried.
Old September 6th, 2011, 07:50 AM   #19
38Chevy454
38Chevy454's Avatar
All will need some modification, so I would just use the best condition one. It will need to be cut down in length a lot, width some, maybe in height too. A lot of the VW pickups use an older bed, Model A is popular; but you can use almost anything dpending on what final appearance you want. You really just need the sides, front panel and tailgate. The floor will be cut out for engine clearance.
Old September 6th, 2011, 08:49 AM   #20
drscope
drscope's Avatar
If it has a fixed top it ain't a roadster.
Just saying. A roadster is an open car.
Nice!
drscope is offline   Reply With Quote
Old September 6th, 2011, 04:41 PM   #21
Coupe.
You could call it Gary Couper. That would be Super Duper.
Its still looking good regardless .
Old September 6th, 2011, 06:27 PM   #22
rick huckins
thanks for the input i know its alot of mods but if ya look real hard you can see a chevy SSR coming out in the vw so may be thats the way to go .
Old September 6th, 2011, 07:02 PM   #23
Except less Gay.
Old September 6th, 2011, 08:06 PM   #24
"cashthepainter
something to keep inmind , most of your new rag tops have a auto window , how it works is when you push or pull the door handle it lowers the window about a inch, to keep the glass from getting hung up on the top. that may help you on the windows. you can get this regulator out of a 2006 pt cruser rag top. as far as what yall have dunn it looks bad a** , if you have a donor car you can cut the section between the winsheld and hood and graft that on the rear and modifiy a front hood and you will have the look you going for.
"cashthepainter is offline   Reply With Quote
Old September 11th, 2011, 03:08 PM   #25
rick huckins
Default Re: vw choptop coupe
Hey guys
scored a set of s/10 blazer rear quarters tail gate and rear doors for the bug going to cut them down so i can use the skins that way i can cover up the old wheel well openings and still have a truck bed , the other beds are to good to cut up and it will be less fab work. traded a set of sucide door kit and bear claws for all the parts and the rear quarters are just the rirgt fit so off to lowes to buy new drill bits and sawall blades pics coming soon
File Type: jpg 3m73pc3lb5Y25Q65X2b94c0b7f8a5d55f1d3d.jpg (8.1 KB, 739 views)
File Type: jpg 3n53m63o35Y25V15X3b947dcf4c1bbc9e117c.jpg (6.8 KB, 736 views)
chop top, coupe, pickup, truck
