Threads: 32,418
Total Online: 211
- by f4u5t
Old November 4th, 2010, 08:52 PM   #1
Default My Newest Project, the "Fire Bug"
So this is my newest VW project, I need to get a running car as soon as possible.
It's a 69 Bug which has been stripped of the front and rear fenders, the passengers side has a new floor pan and heater channel welded in, I cut the drivers side out over the past few days and I am in need of my grinder so I can finish cutting part out and then grind the lip so I can weld the new floor pan and heater channel in. Only thing is I looked for about 2 hours today looking for the grinder.
Plans for the car after I get another car running (I already put together an engine for the 69 so it does run). next fall or winter I plan on chopping the top and raising the rear torsion housing as well as the front bulkhead so I can lower it as low as I can and keep the suspension as close to stock as I can.
I have another rear torsion housing and I also have a complete 66 floor pan from my V-8 Bug AKA the 'BitchN Bug'.
I could build a custom floor pan using the front bulkhead from the 66 pan and the rear torsion housing I have. I could start as soon as I get this pan in and out of the garage and then start on a nice 1-1/2 inch tube chassis over the next buncha months, then put the body on and cut away what needs be, add onto where it needs it, with a full roll cage as well.
Now it may take me a while but I also work very slow (think I mentioned that a few times before.
Here it is the day after I brought it home -
I'll keep this thread here as my criticism and comment page.
http://www.volksrods.com/forum/showt...306#post482306
That's all for now, y'all come back now, ya hear, take ya shooos off N sit a spell
Old January 26th, 2011, 02:37 PM   #2
Default Re: My newest VW, the "Fire Bug"
Well gosh darn, I took those pictures in the 1st post the day after I got the 69 home, which was October 18th 2010, I had hoped to be driving it by the end of October.
What was I thinking, I'm not as young as I once was, I'm not has healthy as I once was, matter-o-fact, I'm just flat slow.
Most of you all work a job, and some how seem to get a lot of work done either on weekends, or week nights after you get home from work. I haven't worked now for almost 10 years and 4 months (if ya wanna know how many day's I can tell ya, even counting leap years, which should be an off day each year it falls on a Monday thru Friday, that's a whole other topic I won't get into) Anyhow I'd love to go back to work, but I settle for working on my cars and all my other projects. I also dislike cold weather and the snow and ice which go along with super cold weather, see I get cold anywhere below 60 degrees F unless the sun is shining nice and bright, I can even tolerate as low as 30 degrees as long as the sun is shining, anything below that, or the sun hiding I can do without.
So here it is almost the end of Jan 2011 and I almost have this 69 read to drive. I still need to get the headlights wired up along with the turn signals up front, then get the brake lights and turn signals wired up in the rear, the tail lights are already wired up.
I have bit of welding to finish up around the front of the heater channels and the front firewall (why do they call it a fire wall when the engine is in the rear? is it because the fuel tank is up front? ).
I just finished putting all the glass in except the rear oval, I have a seal for it, I just need to get a piece of Lexan and cut me out an oval window. I also put the disc brake setup I had on my Dune Buggy, next is to check the rear brakes and if they look good I'll get them bled and she's ready to drive.
I still need to fab up some front shock mounts for it as the P/O turned the bean as far down as it could go and I don't wanna cut and turn it back up any just yet. I do have a set of short shocks off an old motorcycle that seen to have the right amount of travel for the suspension, I just need to make some new mounts as well as make some new head light mounts, I believe they are a bit to low as per the ORC, I'll need to go back and reread it again then measure and see.
I don't wanna set a time as to when I plan to have it drivable by like I did when I got it, (I needed to get a 2nd car that was drivable at the time, but we made due when I didn't succeed in making my dead line) I just plan to have it ready to drive sometime this year, hopefully before the 1st 6 months pass.
Well enough of my talking (typing).
Here are some pic's to show all my activities since the last post.....
floor pan and heater channel -
Big hole behind rear seat -
the start of covering the hole -
with rear seat in place -
behind the rear seat -
Well that's all for now as for pictures, the rest of the work didn't need pictures, it was just rewire behind the dash (don't know what happened behind there, but it just ain't right) and the addition of disc brakes I put on the front, still need to get the rear drums off and then check them and make sure it doesn't need them.
Then it's just some odds and ends and it's ready to drive.
I'll most likely drive it all summer while I get another car fixed, then next winter I hope to chop the top and possibly put suicide doors on as well as few other things I wanna do to it.
I just can't wait till it get's back up into the mid to hi 90's, it just never gets here fast enough, and before I know it, it's gone
Old April 12th, 2011, 08:42 PM   #3
Well gosh dern, all this time and energy I spent on this car and I haven't updated my build page.
Not to much to say other than what fun it is to drive a Bug again
I'll just add some pictures and type less, or just type when I feel it needs an explanation to something I did.
This next picture shows how far the front beam was cut and turned by the P/O
This is an uncut beam which I did go ahead and put on, raised it up by almost 6 inches
After the uncut beam was installed
Before switching the front beam with a pop can to show how low it is
After switching the beams
It has settled down a bit and I took off the coil-over shocks as well which lowered it another inch or more.
Rear fenders added because the Law pulled up next to my Bug while I was in the store, he told me that he has seen me driving it more and more so I should put some kind of fenders on it unless it is just a weekend nice day driving car, so since it's gonna be my daily driver I added the rear fenders
I still need to do something to fill in the apron gap, not sure just how I'm gonna do it yet
I also put a front bumper on it,I still need to build some brackets so I can put the matching rear bumper on
I have also started to put a disc brake setup on the rear of the Bug, it already has front disc brakes and I have the entire rear disc brake setup off 1 of my oldest son's 92 Honda Accords which has disc brakes on all 4 corners.
I had to use some old not so good rear VW drums and cut them to fit in the rotors, I just turned them on my lathe until they were the right size
I think this is a picture of the modified VW drum on a rear bearing housing I cut out of the rear trailing arms
I got the bracket cut out but still need to bore a hole in it so it fits over the bearing housing flange and bearing cap, I also need to drill the 4 screw holes so the bearing cap will bolt on thru the brackets.
I will get started on the caliper brackets tomorrow if I get the spark plug holes all heli-coiled so my plugs don't shoot out while driving, once I get the center bore cut to size and the 4 screw holes drilled so it will bolt on, then I need to get a new set of brake pads so I can make sure the brackets don't need any bending so the calipers are in the correct position, then I'll need to find the parking brake cable from the Honda so I can connect the ends to the calipers and make them work with the parking brake cable on the car now.
Then my work will go towards the front end, 1st is a set of front fenders which I'm gonna try to make myself from scratch by pounding them out of sheet metal, then fill in the original wheel wells up front so it looks a bit cleaner.
So I have plenty of time, very little energy, but I try to do something to it a few days a week unless I'm having a bad day, then either I do nothing but rest, or I just work 3 times slower than I already do, which by the way is usually 15 minutes of working, then 15 minutes of rest, so that's 30 minutes of work every hour, but it is all a part of my physical therapy. I hope to be able to get 40 minutes of work done in an hours time by the end of the summer.
We shall see how that works out, I just wish I had more iron in my body, I have been getting iron infusions once a week for 5 weeks, it was only once a year but now it is probly gonna be 2 times a year. I'm also anemic which makes you tired and energy-less, but I fight it all the time by pushing myself all the time, now I wish I had built my garage/workshop 84 feet closer to the back of my house, it is 85 feet from the back of the house now and it's up hill, not really that steep until you get about 30 feet from the garage door.
Enough talk, time to go to bed soon so I can get my engine's spark plug holes all heli-coiled and put back together, then work on adjusting my dual carbs so they are in sync better than they are at the moment.
Old April 23rd, 2011, 12:10 AM   #4
I reassembled the engine after putting on another set of heads, I also checked the carbs and the float levels were difference by an 1/8 an inch, so I got them within 0.020 of an inch, now I just need my manometer to synchronize them.
So early in the morning I'm gonna finish boring the hole in my disc brake caliper bracket,then drill the 4 boles which the bearing cap goes on and the bracket goes between the bearing cap and the rear bearing housing where the stub axles go, then put them on and make sure I get them where they go and mark them So the calipers are in the correct position.
I was worried about the bracket needing an offset bend to make the calipers with pads centered where they need to be.
Hope to get them on Monday unless I need to make a bend so they are in the correct position.
Wish me luck
Old June 14th, 2011, 04:26 AM   #5
Lot's happened since I last updated this build page
So here goes,
Once the heads went on I get it in and everything set, start it up and everything seems ok for about 2 days
Let it sit because of rain for 3 days straight, go out to start it up and the blow-by issue kept me from driving it.
I replace the P/C's with a used set, has good compression
So I have been driving it since, adding this and that and slowly getting things how I want them
I added front sheet metal to replace the missing parts along with the front apron, now maybe I can seal it off so I don't have the wind coming thru the dash, when you get hot, you just drive faster (turn the fan on hi, it's a variable speed fan operated with the accelerator pedal, push and it goes faster )
Got my hands on a uni-sync and hope to get the carbs set as good as they are gonna get. I fooled with them yesterday for about 20 minutes and it did stop the popping, but after driving up the street and back the idle dropped down and wouldn't stay running
It did seem to have much more power then before, I hope this helps my mileage
I never did get the rear disc brakes finished, I just need to modify the caliper brackets, gonna weld a piece on so the calipers will bolt on in the right location so the caliper moves as the pads wear
Here are some pictures
Right front sheet metal
Front apron
Beam bracing and front body mount, still in the works
Front wheel wells with cardboard patterns, hope to have enough sheet metal to do both sides (I may hafta use the 2 Honda Accord hoods my son has sitting here), if not I can just enclose the front section so it's much more rigid, I can do the fender wells later
Plenty more to come, it's slowly coming together, but then again I'm slow as well
So it's ALL Good, C'ya
Old July 3rd, 2011, 08:14 AM   #6
So I have almost gotten all the front sheet metal welded into place, still have a few holes I need to fill, but other than that it is slowly coming together
I'm planning to mount the fenders once the Holiday weekend is over
Here are a few pictures with the fenders just resting in place, I will be cutting the ends of the fenders so they aren't so straight, kinda round them up a bit
I was lucky enough to pick these up for $0.00 which makes them the "Best" fenders around <--thinks that looks funny, MR. Big Ear
