Total Online: 826
Old December 16th, 2012, 03:40 PM   #1
hendrick
Default Hi there...new guy/TDI bug project
Just checking in, saying Hi making my first intro post.
I'm new to this site but not the VW scene.
I recently began work on my first "fenderless" bug which started life from the frame of a baja project I had started.
the frame was stetched for a longer wheel base...so perfect for the "pushed out front look" only problem , i designed it with the suspension raised 3"...so it was time to cut an re-weld.
Heres some pics.
P.S this project will powered by a 2002 VW TDI water cooled engine so I'll included a pic. of another of my veedubs with a similar TD set up.
hendrick is offline   Reply With Quote
Old January 3rd, 2013, 04:31 PM   #2
hendrick
Default Re: Hi there...new guy/TDI bug project
Found time to mock a test trans and engine.
Began rebuild of TDI engine , starting with the head that will receive new valves,guides,seals, and lifters.
Old January 3rd, 2013, 04:44 PM   #3
hendrick
Here's my donor roof that I will be using for the roof chop.
Old January 7th, 2013, 04:57 PM   #4
hendrick
I originally drilled the frame head for K&L front beam because of its superior strength, ideal for a Baja and off road abuse.
I intended the beam to be bolted directly to this frame head. To extend the wheel base for this application I drilled another plate and welded a stock BJ frame head to it. I intend to build a tube frame support brackets that will extend back to the firewall .... Like a mini roll cage.
Old January 7th, 2013, 05:01 PM   #5
hendrick
Old January 7th, 2013, 05:02 PM   #6
hendrick
Old January 8th, 2013, 05:11 PM   #7
hendrick
Separated body from the pan so I can reinforce frame, now that I am happy with stance.
Old January 11th, 2013, 09:09 AM   #8
hendrick
Began the process of fitting the two pan halves, I will leave the centre section of the frame which is 4" wide uncovered so I can tuck my coolant pipes in there.
Cutting this aluminium sucks!... So I think I'll drag the cut sheet to my buddies shop and shear it!
Old January 13th, 2013, 03:37 PM   #9
hendrick
In the meantime, prepping these arms for some new ball joints
Old January 14th, 2013, 06:30 PM   #10
hendrick
Pans trimmed
Old January 14th, 2013, 06:33 PM   #11
hendrick
Got the body placed back on the frame ... See how I did with my measurements?
Old January 14th, 2013, 06:35 PM   #12
hendrick
Not too shabby.
Old January 15th, 2013, 03:09 PM   #13
hendrick
Finishing up some welding inside, firewall and heater channels.
Old January 15th, 2013, 03:10 PM   #14
hendrick
Old January 16th, 2013, 02:48 PM   #15
hendrick
Test fit of my hydraulic pedal assembly.
I plan to cut firewall so I can locate pedals in stock location.
Old February 5th, 2013, 04:04 AM   #16
hendrick
Front wheels back from powder coater!
Old February 11th, 2013, 05:15 PM   #17
hendrick
I decided I must modify the firewall and install pedal assembly in order to lay out the front beam support frame and radiator.
Old February 11th, 2013, 05:24 PM   #18
hendrick
Test fit
Old February 11th, 2013, 05:25 PM   #19
hendrick
Old February 13th, 2013, 12:41 PM   #20
hendrick
Now that I have the body situated on the frame where I want it, I now plan to mock- up my steering so that I am sure that when the front beam support frame is made, it will clear.
Digging around in my parts supply.... Found this 1998 VW jetta power steering rack and column... I can salvage the parts I need from it.
Old February 13th, 2013, 01:03 PM   #21
hendrick
Old February 13th, 2013, 01:30 PM   #22
hendrick
Old February 13th, 2013, 01:34 PM   #23
hendrick
I will leave the bearing support shaft un-cut until I mock this assembly up in the car to get the proper length
Old February 13th, 2013, 01:35 PM   #24
hendrick
Test fit bearing, and length of shaft.
Old February 16th, 2013, 12:22 PM   #25
hendrick
Salvaged these front beam brackets from an old baja kit.
