Total Online: 625
Old July 30th, 2006, 02:32 PM   #1
skarabajo
Default what angine should i geT?
im no0b here...
i m planing on making a hot rod of a vw..
i m in argentina and i never ever seen these type of scene goin on here..
so i will be the first....
i want my vw to look kinda like these....
i m not saying that i m gonna copy it.. just an insipartion
my plan is first do all the metal work and then engine...
what type of engine should i get?
money is important
so cheaper is better
any suggestion?
skarabajo is offline   Reply With Quote
Old July 30th, 2006, 02:38 PM   #2
blacktruck
blacktruck's Avatar
Default Re: what angine should i geT?
if cheap is the word then build up a dual relief case,anykind of exotic
engine is gonna cost you
welcome
nut up or shut up
Old July 30th, 2006, 02:40 PM   #3
skarabajo
thanx for the quick answer!
what to you mean "dual relief case" i have difficulties in learning english :P
just addons to the engine is has?
_______
Social distortion - born to loose
Old July 30th, 2006, 02:45 PM   #4
Well, if cheaper is better... you won't come anywhere near the monster engine that's in that car.
If you're trying to stay budget minded, but still want a little "more than stock" power under the decklid... I'd suggest a 1776 or maybe even a 1904. I'm a big fan of the 1776 due to it's decent power and the dependability you get from it, giving you MANY miles ahead.
How "cheap" are you talkin'??
Like they say... "Cheap, dependable, fast... pick 2"
Old July 30th, 2006, 02:46 PM   #5
If money is an issue, then a stock 1600cc engine should be fine. You can dress them up nice with duel carbs, paint and/or chrome and it won't rape your wallet. Or you could always step it up to a mild performance with something like a 1776cc but generally the bigger you go, the more it costs.
Welcome to the site and keep us updated on your project. Please feel free to ask more questions, that's what we're here for.
Old July 30th, 2006, 03:28 PM   #6
skarabajo
man these forums ROCKS!!!!
i will restore the engine and work with it..
what mods do you suggest?
air intake? longetube headers? what should be on my
first TO DO list?
Old July 30th, 2006, 03:30 PM   #7
GrantH
first to do is a beam extender, and makeing sure your body is solid.
GrantH is offline   Reply With Quote
Old July 30th, 2006, 03:37 PM   #8
My first suggestion as far as the entire car goes, is to make sure that you go through your brakes and make sure they match whatever engine you decide to go with. If you're going with a bigger engine and a lighter body (after removing fenders, aprons, etc)... you're going to want to make sure those are up to par before hitting the road.
Old July 30th, 2006, 04:11 PM   #9
skarabajo
theres a lot to do....
and not to much cash :S
is there a list of things to do to the engine to make it a little faster?
not big mods.. (turbo)
Old July 30th, 2006, 04:21 PM   #10
GrantH
dual carbs, engle 110 is where ive been told to start for a little better performance, and the 049 heads i believe it is.
Old July 30th, 2006, 04:37 PM   #11
Take it from me, a turbo system can be expensive. Fully balanced engine, turbo prepped carb(s), special grind (mild) cam, then the turbo system.
Not really thae way to go if you're on a budget.
Old July 30th, 2006, 05:34 PM   #12
FONZY
FONZY's Avatar
You don't ask much do you?:)
First rebuild all (ALL!) of the mechanicals of the car.
Brakes.
suspension.
Bearings.
1932 ford front suspension? thats expensive. Try one of the 'beam extenders' mentioned in this site, or build your own. it's not terribly difficult if you have the skillz.
Big tires. white walls maybe?
Transmission?
Motor? a STOCK 1600 with single or dual port heads? Stock is cheap. factory VW dual port engines will produce 40+HP when rebuilt correctly. Stock carb, cam etc. You can always build a bigger engine later.
Then start on the body.
Chop top.
Maybe suicide doors (open backwards)?
Smooth the fender well areas (all the chrome holes and fender bolts)
slap on some bondo and flat black paint.
VIOLA!
should take you about 6 months of spare time and around 3-5000 US to do it right:)
good luck! and make sure to show us pictures of your progress!
Old July 30th, 2006, 05:35 PM   #13
skarabajo
yeah i dont really want a turbo kit cuz its too expensive for me...
i will do some minor engine work.. maybe polish the port and intake...
longe tube headers..to let the engine breath a little!
and the doble carb..
any other suggest?
___________-
MAN THESE FORUMS ROCKS ..FOR REAL!!!!
Old July 30th, 2006, 07:22 PM   #14
purplepeopleeater
purplepeopleeater's Avatar
skarabajo:
PM Steve, He has a custom air intake system that will make your car the fastest on the steet and best of all you can buy all the hardware at homedepot
Steve i love you man
purplepeopleeater is offline   Reply With Quote
Old July 30th, 2006, 08:18 PM   #15
: funny:
Old July 31st, 2006, 07:48 AM   #16
JMPVW73
JMPVW73's Avatar
Well I'm glad the KCW car brought new people to this style of VW even though I dont like the car. To those of you giving smartass replies get a map and see how far away Argentina is.
I hope this dosent burst your bubble. What does it say?
http://www.flickr.com/photos/noryjp/.../pool-vwsedan/
Are you new to VW's and do you have a car yet?
I think the earlier the car the better but I dont like chops on '57 and earlier cars partly because they already look choped and the windshield never looks right if you chop it. I know you probably wont have any big window cars('65 and later in USA) around there. Those are my favorite chops. Look for the Goldfather if you have this months HotVW's.
Most people put an early hood and deck lid on their car because they dont square off at the bottom so you may want to start w/ '66 and earlier but it wont be hard to put them on a later car because only the apron is different and you wont have them.
It would be good to let us know what your budget is. Look through old post for answers to most of your questions.
drinking fountains are shorter than they used to be
swings on the playground dont even reach me any more
Originally Posted by matthewsuckerpunch
u just have to hook the fuckers up right and they work.
james
JMPVW73 is offline   Reply With Quote
Old July 31st, 2006, 07:56 AM   #17
purplepeopleeater
knowing how far away someone is wouldn't stop me from giving smarty replies
