Members: 17,513
Threads: 32,311
Total Online: 449
Newest Member: txdy201929
- by Zee
Old September 12th, 2006, 10:50 AM   #1
Lightbulb Domestic tierods ?
The old Ford's used oddball threads on their tie rods etc.
You can buy the correct size tap,or threaded bungs,
from the Butt Pirates at Speedway.
Or substitute easier to find parts with more common threads.
Any decent parts store can get any of these tie rods,
and any decent industrial supplier will have taps.
Some of the tapers might be different sizes,so investigate before you buy.
Moog/TRW# - thread - Application
ES150R 3/4"x16 RH '61-66 Chevy 1/2 & 3/4 ton 4x4, 48-76 Ford 1/2 ton 4x4 w/ DANA
ES150L 3/4"x16 LH '61-66 Chevy 1/2 & 3/4 ton 4x4, 48-76 Ford 1/2 ton 4x4 w/ DANA
ES2847R 3/4"x16 RH '86-96 Dodge 1/2, 3/4, 1 ton 4x4 w/ 3500lb. axle (DANA 44)
ES2848L 3/4"x16 LH '86-96 Dodge 1/2, 3/4, 1 ton 4x4 w/ 3500lb. axle (DANA 44)
ES361R 11/16"x18 RH '66-78 Eldorado & Toronado
ES370L 5/8"x18 LH '65-68 Bel Air, Biscayne, Caprice, Impala
ES370R 5/8"x18 RH '65-68 Bel Air, Biscayne, Caprice, Impala
All this info came from Howe Racing Ent:
http://www.howeracing.com/Steering/I...-Precision.htm
Old September 12th, 2006, 11:59 AM   #2
Default Re: Domestic tierods ?
NOW YA TELL US!!!!
I just pais the "Butt" Pirates at Speedway for a set of heim joints and removed the taper.
Good info though.
Old September 13th, 2006, 01:24 AM   #3
Hotrodpez
Hotrodpez's Avatar
Location: Mission Viejo, Orange County, Kalifornia, USA, Earth, Sol System, Milky Way.
tech bin this shit!
- Luke
__________________________________________
Originally Posted by bugdust
If you can't measure your own floor then this project may be too much for you...just my opinion.
People who say im hard to shop for must not know where to buy beer...
Common parking lot conversation...
Its a volksrod...
Yes, it runs...
Yeah I drive it...
No, I'm not crazy.
Here's to living single, seeing double, and sleeping triple!
Myspace: http://www.myspace.com/lukepezanoski
Hotrodpez is offline   Reply With Quote
Old December 30th, 2008, 08:12 PM   #4
I found some killer charts, with detailed
tierod dimensions, in PDF format.
Part numbers are Moog/TRW::
Dead link EDIT.
Old June 8th, 2009, 08:44 PM   #5
I've got those dimension charts, on my site now.
Look towards the bottom of the Links page.
tierods
