Members: 17,688
Threads: 32,298
Total Online: 90
Newest Member: gstong
- by Frank3
Old November 19th, 2006, 08:01 AM   #1
kalle_cage
kalle_cage's Avatar
Default Smooth. the tutorial!
making a tutorial about the smooth front wings as requested!
1: cut along the line where the fender touch the body.
2: make a template out of cardboard or something similar.
3: transfer the templet to the sheetmetal.
4: cut! use a anglegrinder or a nibbler or someting.
5: roll the sheet over the wheel (jacked up). or use a english wheel if you got one!
6: trial fit the sheetmetal and trim the edges to meet upp properly.
7: tack weld the piece in place.
8: grind the welds down and youīr good to go!
You have no choice. itīs either or!
kalle_cage is offline   Reply With Quote
Old November 19th, 2006, 08:17 AM   #2
Default Re: Smooth. the tutorial!
Very cool! Simple and looks great!
Old November 19th, 2006, 08:22 AM   #3
Looks good,thanks.
What's with cutting the side out of the foot box ?
Did you have to "adjust" the edge of the Pan for clearance ?
Old November 19th, 2006, 08:41 AM   #4
kalle_cage
kalle_cage's Avatar
Originally Posted by Unkl Ian
Looks good,thanks.
major rust have to build it up from scratch!
thanks for the crit.
Old November 19th, 2006, 08:42 AM   #5
kalle_cage
kalle_cage's Avatar
no modification to the pan!
Old November 19th, 2006, 09:03 AM   #6
blacktruck
blacktruck's Avatar
that looks sweet
nut up or shut up
Old March 10th, 2014, 12:50 PM   #7
Dakota Dave
Dakota Dave's Avatar
Damn it! Now what do I do with this 10 gallons of bondo?
Dakota Dave is offline   Reply With Quote
ALL text, images, graphics and content herein are Copyright Đ2002 - 2013 Three Pugs Design - Cut Weld Drive Forums
