| Stuff to check out... |
| Forum Stats |
Members: 14,775
Threads: 30,818
Total Online: 58
Newest Member: MoeBoy
March 16th, 2010, 10:19 PM
#176
Re: My concept for the general Vee
Making progress is always nice. My boss has a wood wheel sorta like yours, only there's no dish to it at all.
March 17th, 2010, 04:26 AM
#177
HAPPY BIRTHDAY MIKE!
Now, grab a green drink and get back to work
 1,2,.............. . Like it, Click it, support it.
March 17th, 2010, 06:39 PM
#178
Thanks Carlene. I actually started drinking Guiness about 3pm and decided it was good motivation to install adjusters into my beam. That was fun. If they made those the exact diameter as the beam, it would be so much simpler.
March 17th, 2010, 07:08 PM
#179
If I'm not mistaken I belive you have the adjusters mounted incorrectly. The flat plate part of the adjuster (with the jam nut welded to it) should be square to the bottom of the beam.
March 17th, 2010, 07:36 PM
#180
The directions I had stated that the pinch bolt inside the spring retainer should be at center with the stock location of the beams original pinch bolt. It would lower it from that position.
If I am incorrect, fortunately, it is just tacked. I will blame in on the Guiness. Love these instructions. Right now I have it set so that when the spring collar is at its normal height, it all the way against the set screw. Then It is adjusted to lower from there. But I can see where it would work the other way.....Ugh.. I see now that under weight, it needs to be the other way. But at the position you suggest it appears that it would be lower than stock to begin with, making it exceptionally low, which I do not want. I want stock height beam and then lower from there. I have seen guys advance the rotation so their car is really in the weeds.
March 17th, 2010, 08:03 PM
#181
I am having a difficult time finding that type of adjuster installed on the beam. Anyone have a shot of their beam with this type of mech on it?
March 17th, 2010, 08:19 PM
#182
They look to be upside down, the aluminum adjustment block goes to the top side of the tube.
Look in my photo album for a photo of them installed.
March 17th, 2010, 08:26 PM
#183
Thank!! I can see that now. Fortunately I didn't weld them all the way in. EHHEHEHE. Is the rotation relationship the same on a balljoint and linkpin beam? Now if I can find the relative position to weld them in at. I marked the center of the pinch on the old beam section. I will have to read the damn directions for the 50th time....
March 17th, 2010, 08:37 PM
#184
Found one.
March 17th, 2010, 08:41 PM
#185
Found one.
Those adjustment slots look like they are longer thus giving more adjustment both ways...you mentioned you didn't want it really low so take your time and make sure that's what you want before it's all welded shut..... JMO
March 17th, 2010, 08:51 PM
#186
Ya, I want it to ride at stock height and the lowered from there, I am not wanting to set it up to have a drop by rotating it before i weld it up.
Thanks!
March 18th, 2010, 03:59 PM
#187
Maybe with the adjusters lose you can reinstall the spring pack and trailing arms to get an idea of how you want it to sit. Then weld the adjusters in. I know that the trailing arms will not have any weight on them but it still might give you an idea. Maybe compare this one to a stock unladen beam?
March 18th, 2010, 04:57 PM
#188
For a reference, cutting and turning the stock grub screw a 1/2" will give you about 2-2 1/2" of drop or raise depending on which way you turn it.
March 18th, 2010, 05:47 PM
#189
Thanks for the ideas guys.
March 18th, 2010, 09:56 PM
#190
Yeah I bought a new beam with adjuster factory installed. The way you have em welded is upside down. No worries though they just tacked in. My beam will be finished tomorrow I can take some pics if ya want reference shots...
March 19th, 2010, 06:20 AM
#191
Thanks Glowstick,
I had some help from Double D. I have them all welded in now. I am presently disassembling the beam that came off car and assembling the pieces.
March 19th, 2010, 03:53 PM
#192
Thanks Glowstick,
No problem man. Get ready to get dirty. It is way easy to get it all apart but getting it back together is a bitch. Have some vice grips and some zip ties ready hahaha
March 19th, 2010, 05:48 PM
#193
I got things tore down and am fitting things back together prior to powdercoating everything. Weeee. I pulled the inner beam bearings and installed the urethane bushings. I put the arms in the blaster and cleaned them up. I will attack the other side tomorrow. I will separate the backing plates and brakes and get them ready too.
March 21st, 2010, 04:29 PM
#194
March 21st, 2010, 04:47 PM
#195
Wow Mike, you been a busy guy!
Gittin er dun !
(is it just me or do your pics all run off the screen?  )
March 21st, 2010, 04:57 PM
#196
They are only 800x600 Carlene. I didn't think they would be a prob that size. I can make them smaller in the future if it is an issue. I have my monitor set for hi res.
March 21st, 2010, 05:37 PM
#197
no, its not the size, you have all the links side by side lol!
I fix~
March 21st, 2010, 05:39 PM
#198
Dunno how the hell I did that. I will be sure to double check it next time. Thanks for you assistance there.
March 21st, 2010, 05:45 PM
#199
nah, no problem , I see links only, but dbl check in another window, I think ya was just in a hurry and forgot to hit space lol!
800x600 is good too
the dash looking good!
so is it dun yet?
March 22nd, 2010, 05:37 PM
#200
| Thread Tools |
| Display Modes |
