Total Online: 830
Old July 30th, 2007, 12:49 PM   #1
Fl@pper
Fl@pper's Avatar
Default Fl@pper's Volksrodded 27T roadster
Hi all - Fl@pper from the UK part time worker madman and BIG hammer wielder
love the bugs i see on these pages the last few weeks so finally decided to register as i have a wierd idea but more to come later
I'm a big eared Pikey hot rodding Iron Maiden Fan who usually haunts seatcupra.net but have my own project on the go that the show n shine tintops just dont get
apologies to purists in advance on both bug and hotrod but hey a hotrod is individual in my eyes so i always do things the hard and wrong way
enough of the intro - i have a 1927 model T Ford roadster body (replica) mounting on a Reliant Scimitar (chopped) chassis with Ford rear end and an adapted beetle front end with a Rover V8 with twin superchargers going in on an auto box
all self drawn and built so far (long time) due to time an money but hey we learn more that way huh ?
the front uprights are now gone (almost) and that chassis tube has a lower tube from a beetle frame inside it now
makes a change from volksrods with ford fronts - told you i do things differently
will be adding mounts and plates for the upper soon with castor sat back as i'm widening the front by 5" and running the arms facing forwards
this place so far has enlightened my Vdub repsect loads - thank you and look forward to posting crazy plans ideas for ridicule in the future
heres my original idea but that was too easy as will be explained in full over time sorry about the dog he loves grease and grinder sparks - nutter
Fl@pper is offline   Reply With Quote
Old July 31st, 2007, 11:59 AM   #2
Fl@pper
Fl@pper's Avatar
Default Re: Fl@pper's Volksrodded 27T roadster
well its now upside down and the grinder is out
see after pic can you tell where the beetle beam is going ?:)
towers are coming off next
Progress Thread
Fl@pper
Southern UK Pikey Big Eared Hot rodding Iron Maiden Fan
Old August 4th, 2007, 06:25 AM   #3
Fl@pper
Fl@pper's Avatar
well the towers are off now so i can start measuring the plates for laser cutting properly
there was me worried this chassis was going to be a tad heavy until i tried to move it - light as a feather :)
Progress Thread
Fl@pper
Old September 11th, 2007, 11:38 AM   #4
Fl@pper
Fl@pper's Avatar
not done an update for a while - oops
chassis has been cleaned up a bit more and engine block then full unit installed to line it all up
sorting front suspension ideas so have done a mock up on my favourite so far and by hell it almost looks like a car
Progress Thread
Fl@pper
Old September 15th, 2007, 05:48 AM   #5
Fl@pper
Fl@pper's Avatar
looks like i ended up full circle back at my original idea that i dont think has been done before ??
old frame has been plasma'd and started to smooth it out a bit so decided to check it for fitting and see what room i have for the adjusters - works out that the bottom is standard width and the top is equivalent to a 10" narrowing albeit left in 2 pieces
each spring set has been cut 5" shortand tempered softer and are within 1.5lb of pull of the original full size set held in the standard beam so looking good so far and not as stiff as i first feared
wooden plates are currently being laser cut as a favour and end brackets are to be ground off smooth and replaced with a bolt one made of 2 conrods :) as its going to welded to the plates and gusseted
should make a 3 part front beam assy that slides in the bottom and 2 sections that drop from the top and are bolted on
mrs reckons it might be done for my 40th Bday - im 35 :) lol
heres a couple of pics
Progress Thread
Fl@pper
Old January 20th, 2008, 06:37 AM   #6
Fl@pper
Fl@pper's Avatar
quick update - been away a while with major illness but back home now and building strength to work on it a bit now
will be getting stuck in as soon as doc says im clear
look out soon for some catch up
Progress Thread
Fl@pper
