Threads: 32,414
Total Online: 558
- by f4u5t
Old October 3rd, 2007, 05:06 AM   #1
Guss
Guss's Avatar
Default lil' rodder
Hello. My name is Guss, and I figured that I would get this intro thing out of the way early. I'm from Bristow, Ok where I live with my parents and two younger brothers. My dad and I are going to be building me a volksrod over the winter and into next year. Hopefully it will be finished by early summer '08. I've been into volksrods for about three years now, which is kind of cool as I'm only four years old.
Here is what I have to start with. It's a '70 that is in rough shape and was fromerly named "The Nasty" by it's previous owner. With any luck, we will be changing that real soon. Anyway, onto the first pics...
So there's what we have to start with. We will update as progress goes along. Hopefully it won't be to long.
Third grade, where all the honeys are!
my intro
Guss is offline   Reply With Quote
Old November 20th, 2007, 07:41 AM   #2
Guss
Guss's Avatar
Default Re: lil' rodder
Well, dad finally got his truck taken apart and set to the side of the shop. Now it's my turn. We still have a little clean up o do, but we should be ready to start on my hot rod by the end of this week.
Dad needs to get a new regulator for the air compressor so we can work longer b/t cycle times. And it will also allow us to paint it in the shop. I'll get dad to post up some pics later because I'm not allowed to touch the camera.
See ya,
Guss.
my intro
Old November 21st, 2007, 03:53 AM   #3
Guss
Guss's Avatar
Last night dad had some friends come over to get a starter so we didn't get much done in the shop. We did get it cleaned a little, but not much. Hopefully the shop will be clean enough to start on my hot rod this weekend.
my intro
Old November 21st, 2007, 08:24 PM   #4
Guss
Guss's Avatar
Shop's clean! Got the two broken windows on the north side fixed too. Then we fired up the heaters. all that's left to do is go get the bug out of the boneyard and do a little
Gonna be a good Thanksgiving!
my intro
Old November 22nd, 2007, 06:01 PM   #5
Guss
Guss's Avatar
Today, me, dad, and papa Harry went out and got my bug. Now it's sitting in the driveway and ready to go into the shop for a little and a whole lot of
my intro
Old November 25th, 2007, 02:58 PM   #6
Guss
Guss's Avatar
Well, we finally got the bug in the shop and got some work done.
First we pulled the front tires off, then the front brake drums. Then I got the front fenders off. I know it's not much progress to some of you, but hey! I'M FOUR!!!
my intro
Old November 26th, 2007, 04:09 PM   #7
Guss
Guss's Avatar
The glass is out and the cut lines are laid out. Dad is still taking measurments to make everythin come out right. I wish we could just cut it, but he won't let me.
my intro
Old December 1st, 2007, 03:50 AM   #8
Guss
Guss's Avatar
Welp.... Take a good look at the bug because that is the last time that you will see in like this. today it goes under the blade.
my intro
Old December 1st, 2007, 08:31 AM   #9
Guss
Guss's Avatar
Got all the wiring harness out (completye), and stripped everything else out. The cut lines have been laid out, and right after lunch it'll be time to
my intro
Old December 19th, 2007, 07:01 PM   #10
Guss
Guss's Avatar
Just updating this with pics since it's been a long time.
First we sectioned the body 12" by taking 3 4" pieces out of the colw area, and checked to see how it fit.
Then daddy built a body dolly that is 30" from the floor so he wouldn't have to bend over so much.
Next we sectioned 12.5" out of the door length, and retested the fit.
With the door length right, it was time to section the heigth. Here we sectioned it by 9.5". Once that was done, we retested the fit. This time with me sitting on the sawzall box as a make shift bench seat.
And tonight we cleaned up the cuts from the section job and made the flange weld places in the doors. I'll have to get some pics and load them up tomorrow.
my intro
Old December 22nd, 2007, 05:40 AM   #11
Guss
Guss's Avatar
Today we are going to papa Harry's to have Christmas. So we are only going to work on the hot rod for a little bit. I'll get you all some pics. of the progress.
my intro
Old January 1st, 2008, 11:53 AM   #12
Guss
Guss's Avatar
just updating my intro thingy with all the progress pics...
my intro
Old January 1st, 2008, 12:07 PM   #13
Guss
Guss's Avatar
Todays pics so far:
my intro
Old January 25th, 2008, 08:09 PM   #14
Guss
Guss's Avatar
Just updating the pics again...
Got the engine:
Checked over all height:
Installed the door top:
Cut the rag top opening:
testing engine placement:
Cut the bed sides:
Installed the bed tops:
Installed the rolls for the bed tops:
Started making the stake pockets:
More to come.
my intro
Old February 24th, 2008, 07:37 PM   #15
Guss
Guss's Avatar
Once again, just updating the pics.
Here is the frame daddy made:
The bed test fit to the frame:
And this is what will be seen of the rear kick and frame when finished:
Then we started working on the trany placement:
We shortened the front wheel wells:
And welded the engine mount plate in place:
Then it was time to start working on the dash:
Reinstalled the lower, center section:
We then removed the old dash recesses:
Filled them:
and finally we cut out the center and welded in the factory speedo mount and speedo:
my intro
Old March 1st, 2008, 08:48 AM   #16
Guss
Guss's Avatar
We didn't have a lot of time to work on my hot rod this week. today is really sunny and nice outside, but soon as momma gets back from school (about 30 more min.) daddy has to go work on a Focus for a guy. Tomorrow it is going to get cold again, so who knows when we'll get back to work on my hot rod.
But we were able to get the frame for the floor of the cab fully welded in place. we also centered the cab on the main frame and started making the cab mounts. They will be just like real cab mounts on big trucks. There will be six of them (three per side) with a 1/2" rubber bushing and a 3/8" grade 8 thru bolt. The blots will go in from the top and be hidden from view for a cleaner look.
If we make any real progress this weekend, I'll be sure to update with pics.
my intro
Old March 2nd, 2008, 06:03 PM   #17
Guss
Guss's Avatar
Storms are moving in fast so we had to leave the shop and turn the weather on.
We have the cab mounts all made and welded in place on the frame and the other 1/2 on the cab "floor frame". With the cab mounts finished off, it was time to grind down a few welds, and remove a little remaining heater channel material. We needed all this done so we could start putting in the floor. Well, we have the floor on the drivers side fully welded in place, and the pieces for the other side are cut out and ready to be welded in. That's when we learned about the chance of having tornados tonight.
Needless to say, we didn't take any pics. We just turned everything off and got ready for bad weather. Well post pics tomorrow. Sorry.
my intro
Old March 4th, 2008, 09:39 AM   #18
Guss
Guss's Avatar
Last night daddy got me some 4" headlights.
FREEBEE!!!
They are "utillity lights" from a 1941 JohnDeere tractor. Because of how old they are they are real rusted. Daddy had to clean them up really good with the bench grinder wire wheel, but after all that time out side they are not pitted at all. The glass is still good and all the wires are good too. We have to get new bulbs that are 12 volt so they will work, but two new bulbs are on the way.
I have pics of one before and after cleaning. We are going to get them primered and work on the new mounts sometime this week or next.
my intro
Old March 4th, 2008, 06:42 PM   #19
Guss
Guss's Avatar
Lightbulb Re: lil' rodder
Here's the pics of the lights daddy got for my hot rod.
The glass is all good, but really dirty.
and this this is what the outside looked like.
Then daddy took them apart and hit the metal parts with the wire wheel.
He also cleaned the glass the best he could.
Then he shot a coat of primer on them, but it's still to early to handle them. We get better pics inside than in the shop, so I'll add pics of the primer pieces later.
my intro
Old March 28th, 2008, 04:55 AM   #20
Guss
Guss's Avatar
It's not been a good week for daddy in the shop. He's been working on other stuff. Monday momma had class. Tuesday, he cut out letters for a friend at work and on Wednesday he welded them into signs for the guys driveway. Last night he took the night of. And early this morning, he started working on a pump mount plate for one of the oil wells. He has to have it finished by tomorrow morning. Then he has to rebuild a steering column from a '73 Bronco for another guy. So there may not be a whole lot of progress on my hot rod for a few days. But daddy says sometimes ya have to work in crooked lines to make sure everything comes out straight. I have no idea what that means, but that's why he's the daddy man and I'm Guss.
my intro
Old March 28th, 2008, 11:28 AM   #21
Guss
Guss's Avatar
Daddy just said not to worry. He has the stuff to finish the pump plate, and the stuff to make a little more progress on my hot rod.
Now we just need to find the time to get everything else done so we can work on it again.
my intro
Old April 12th, 2008, 06:29 PM   #22
Guss
Guss's Avatar
It's been a while, so this might take some time. We don't have any pics as we haven't really been working on my hot rod the last week or so. Daddy did get the pieces for the radius rods cut and bent. We still need to weld them together, but he wants to have the radius rod mounts cut out before we weld them so they fit right. We are also waiting for the clevises and rod ends to show up.
We played around with bending the front axle, and feel that we can get it done right doing it our selfs. Might work on that tomorrow. Momma is going for a "ride along" with an OHP tomorrow, so it will just be us guys.
The cut lines for the front hood are also laid out. Daddy has been worried about this part. If it isn't right, the whole thing will look bad, so it has to be perfect.
As most of you know, daddy got the new rear wheels and tires from Rumblewagen this week. The clock daddy painted for him was cool too. Tomorrow he said we might get to paint on one of the walls of his new office. Painting on the walls without getting in trouble!
Back to the hot rod... We also have the pieces for the exhaust all cut and ready to be welded together. It will look good I think. I'll see if daddy will take a few pics tomorrow after we check the wells.
my intro
Old April 18th, 2008, 07:58 AM   #23
Guss
Guss's Avatar
Daddy just called and said that the spring pivots and shackles got here today. So we may be putting the front axle together this weekend.
We have a lot of other things to do also though, so no promises.
my intro
Old July 30th, 2008, 04:56 AM   #24
Guss
Guss's Avatar
Daddy finished my front axle last night. I came in here to post an update, but saw that I hadn't updated it in a while. so here is an update for May, June, and July...
Worked on the axle...
We also worked on the hood.....
I have some other pictures, but daddy hasn't put them on the computer yet. I'll see if he will do it tonight.
my intro
Old August 19th, 2008, 07:38 PM   #25
Guss
Guss's Avatar
Time to update the pics in this thread...
Test fit of the hood, and front tires. Found out that the tires are not going to work...
We reworked the hood and ground down the welds....
Then we installed the finished spindles, and roughed out the radius rods on the front....
And we roughed in the front quarter panels.....
After that, daddy took the old tires off the rims and painted them two tone Mint Green and Ivory, and installed the new front and rear tires....
Then we began working on the rear of the cab.....
my intro
