Forum Stats |
Threads: 32,402
Total Online: 634
January 29th, 2008, 05:19 PM
#1
l.e.d. tail light question
I want to run a set of led bullets for my tail lights. Any tips on wiring? I have them mounted on the bumper, and thats as far as I've got. Thanks.
January 29th, 2008, 06:30 PM
#2
Re: l.e.d. tail light question
are they gonna be turn signals or just lights?
73ratrod, 72 bus,73 bug
#3
i got some bullet lights on the rear and i got them to work as the tail light, brake light and turn signal
January 29th, 2008, 06:32 PM
#4
wiring would depend on them being single or double filement type.
lengthen the wires from the old taillamps, attach to the new taillights.
make sure there is a good ground to the light.
you will likely find that the LEDs dont draw enough power to trip the turn flasher.
two easy fixes 1) electronic flasher 2) wire in standard bulbs inside the car to add a load
I used standard bulbs in 4 harley duece turn signals for my stop and turn lights
life is too short to drive vanilla cars.
66 DC, 66 sedan, 32 Ford highboy, 40 Ford sedan, mini-winnie
January 29th, 2008, 07:40 PM
#5
You could also install a dummy load wired in parallel -- try Watson's Street Works.
January 29th, 2008, 11:51 PM
#6
just running and brake. my turnsignal arm broke off and I may just be to lazy to replace it. my friend said the would work as running but not brake, so thats why i ask
January 30th, 2008, 05:35 AM
#7
Get an early taillight housing and use one of these as a donor
only $10 at HF.
yeah, not my idea...but i'll take credit for it.
January 30th, 2008, 06:51 AM
#8
I might try that! Make my own custom taillight buckets and put those in them. Sweet!
January 30th, 2008, 01:40 PM
#9
good idea!
January 31st, 2008, 07:00 AM
#10
I believe those just have one set of LEDS in them. So you can use them for tails or brakes, but you'll have to do some moddin' to make them do both in one housing.
January 31st, 2008, 07:16 AM
#11
Here is where I got the Idea, Let me know if you need more...I know the guy that is done this
http://rbcdunebuggy.yuku.com/topic/1...s-sort-of.html
January 31st, 2008, 07:18 AM
#12
" The stock VW lens seems to pass the light just fine, but the picture should show more. Don't forget to tie the green and yellow wires together to get the brake light (brighter) to work. The brown wire is for the lights (dimmer). "
January 31st, 2008, 08:37 AM
#13
I stand corrected. Those look great and cheap!
January 31st, 2008, 09:31 AM
#14
yep, HF had them onsale for $7.99
January 31st, 2008, 05:21 PM
#15
For anyone looking to run LEDs as turn signals... The kit set ups I've used just came with in line resistors when they are for use with a standard flasher switch. If you measure the amount of draw the bulb you are replacing has you can match it with a resistor from an electronics store.
January 31st, 2008, 05:28 PM
#16
I put these in Terry Arfons 34 sedan about five years ago at a shop I worked at. The kits were not the best quality and I had to modify most of the wiring for them to work correctly...
February 1st, 2008, 11:01 PM
#17
instead of a load on the wiring you can change to a digital turn signal relay about 9.00 at pepboys auto parts
February 2nd, 2008, 10:23 PM
#18
So I hooked them up today (not as complicated as I thought (I'm just dumb)) only to find out that they were not that bright! I used the digital relay that I had. Plus when the brake was on it was hardly noticeable. Any thoughts on making those fuckers shine?! Cuz they look so clean.
February 2nd, 2008, 11:34 PM
#19
I just read through the linked forum post, seems the guy had to mod his wiring to run 2-filament instead of three for these to work. I guess he used the trailer harness adapter trick, either way, this is a slick as hell mod, for dirt cheap.
Nice find!
February 3rd, 2008, 12:15 AM
#20
I want to put a pic up of the lights. Is there another way other than using a web link? or should I just do a "photobucket" type account?
February 3rd, 2008, 09:15 AM
#21
the trailer relay is the only "easy" way to get these to get bright, go get one at napa and you'll see!
Also, its about the only way to go getting your blinkers/running lights/brakelights all working on the same bulbs
February 3rd, 2008, 10:18 AM
#22
I must be an idiot.... haha
Unless they're all hidden behind the firewall and i have to yank my engine to see em, i cannot find the wires i need to connect my "taillight converter"...
everyone here says it's easy and every shop I ask says it's impossible....
February 3rd, 2008, 02:43 PM
#23
Should be able to get to them where they come down by the sides of the engine before they go through the inner fenders to the tailights.
February 3rd, 2008, 03:06 PM
#24
I've got dual webers... they take up a lot of space and limit what i can reach.. :(
February 3rd, 2008, 03:10 PM
#25
likewise, those duals eat up all that space. You could install it behind the dash. The tails and blinker wires are all right there and you can just cut the brake light wires at the master cylinder and run them up to the magic trailer box.
Thread Tools |
Display Modes |
