Members: 17,340
Threads: 32,252
Total Online: 517
Newest Member: vw67
Old April 6th, 2008, 08:27 PM   #1
Texasbuggys
Texasbuggys's Avatar
Default Suicide door hinges and latches
Hey gathering parts for the 67 project. Just wanted to see what everyone has used when adding suicide doors to their bugz? I am looking at the Rocky Hinge Co. setup as the hinges are already aligned and sure seems like it would make life easier. I have done some searching and ready but want to hear some rear world experience from you guys that have done it and what setup you used and the good and bad from it. Thanks guys
Get ur new Manx Style Fiberglass Buggy Bodies, Chassis and Accessories in Texas
www.texasbuggys.com
67 Chop Top - http://s9.photobucket.com/albums/a60...t=e8a0e41b.pbr
5 window VW pickup - http://s9.photobucket.com/albums/a60...t=bc9c8583.pbw
Texasbuggys is offline   Reply With Quote
Old April 6th, 2008, 09:47 PM   #2
welshj
welshj's Avatar
Default Re: Suicide door hinges and latches
I used hidden style hinges from an iraqi army truck for mine.
I built pockets for them out of two inch square stock.
Mid to '66 ford f150 pu's had very similiar hinges.
They even have bolt in pockets, if you can find one in a junkyard, get the pockets and just weld 'em in. Then you can unbolt your doors easily.
As far as latches go, i wouldn't suggest anything but the bearclaw setup. I used the mini hinges that the have, as the size of the regular setup is too big for the bug doors.
I also went for thier install kit, was a great setup went in smooth and clean.
The first pic (link) is the third time round doing my doors. Take note of the location of the hinges. The first go 'round I used an old Hot VW's article on doing suicides with the OG stock hinges, and a set of early bus latches. I tried it, didn't like it at all as th stock hinges flexed alot for some reason.
There's a guy with a pink bug come to the classic all the time. His is done with stock hinges, and if you walk up to it, you can see the paint cracked on them from ten feet away.
The second go round was with the iraqi hinges, but in the "stock" location on the rear door post. Worked great up until I tried to open my doors. They would open up to about halfway before the center of the door hit the rear quarter panel in the middle of the arc on the side of the body... no good.
So the third time round, moved the hinges in farther toward the center of the arc, and bingo.... perfect clearance. My doors open just slightly farther than ninety degrees from the car. And, the hinge pockets create their own door stops.
Hope this gives you some ideas...
I have some more in progress pics, shot me a PM with an email addy if'n ya want 'em.!
joel
There are days when you feel like a rat in trap... But, I prefer the days when I feel like the cat watching the rat!
'72/62/67/65/63/? bug on bags, hairless....(shaved) http://www.aircoolers.org
Originally Posted by Reaper View Post
It's "Cut, Weld, Drive"....not "Moan, Whine, Bitch.
welshj is offline   Reply With Quote
Old April 13th, 2008, 01:21 AM   #3
bustedknuckles
bustedknuckles's Avatar
I have heard nothing but good things about the bearclaw setup.
bustedknuckles is offline   Reply With Quote
Old April 13th, 2008, 05:47 AM   #4
bugroadster
bugroadster's Avatar
I use Rocky Hinges and his bear claw setup, ive had nothing but good luck with his product and he is in my back yard.
Old April 13th, 2008, 07:26 AM   #5
Texasbuggys
I talked to Rocky himself on Friday and he set me up with all the part numbers I need to get everything. Super nice guy and very familiar with VW's so if anyone is thinking of going this direction he is the man at Rocky Hinge Co. and no they are not in Colorado.
www.texasbuggys.com
Old April 13th, 2008, 07:35 AM   #6
jkien65
jkien65's Avatar
Could you give us a list of part numbers that you are going to use?
Old April 13th, 2008, 09:57 AM   #7
i used rocky mt hinges. I highly recommend you getting a pre-alligned kit. I know of a few seasoned car body guys that installed stock hinges and took them at least 3 tries before it was perfectly alligned. If not aligned it will bind and won't open/close properly...and paint may flex and chip as mentioned earlier.
The drawback with getting most kits are they are alot thicker than normal hinges, so you'll have to cut into below the rear 1/4 window area, which will interfere with the rear 1/4 panel upholstery
Old April 13th, 2008, 03:44 PM   #8
bustedknuckles
Does anyone have any pictures of the upholstery with the suicide hinges
Old April 14th, 2008, 10:31 AM   #9
Texasbuggys
Default Re: Suicide door hinges and latches part numbers from Rocky Hinge Co
Rocky part numbers listed as requested!
HK 003 and comes with pre-aligned hinges, bear claw latches
This kit is about $300 + shipping
MSL 001 Safety Pin locks with LED indicator. $59 + shippiing These are the manual locks but they also offer automatic locks for a little more $.
www.texasbuggys.com
Old April 14th, 2008, 11:23 AM   #10
jkien65
jkien65's Avatar
Thanks for the part #'s!
Old April 14th, 2008, 12:56 PM   #11
Not with uphostery, but you can see where it will have to go.
