Members: 17,527
Threads: 32,242
Total Online: 386
Newest Member: lds8c33c
Old February 17th, 2009, 10:07 AM   #101
Cutman
Cutman's Avatar
Default Re: Fernons Chop
Just read the entire thread.... I am hooked! The "wiat and see" stuff is killin' me!!!
Old February 18th, 2009, 07:44 AM   #102
Looks great!! Thanks for the pics.
I'll probably build my own hinge set-up when I do mine because I have a little different requirement for what I want. I'll design it in 3D, build a fixture, then the hinges.
Old February 18th, 2009, 08:47 AM   #103
No prob Bugdust, always glad to help you out...
Old February 18th, 2009, 12:53 PM   #104
purplepeopleeater
purplepeopleeater's Avatar
wow, makes me kinda want a volksrod...i have that summer itch now.
purplepeopleeater is offline   Reply With Quote
Old February 18th, 2009, 12:56 PM   #105
Are those hinges adjustable at all. I mean after it's all adjusted & welded in, is there any way to "fine tune" them afterward if you need to?
Old February 18th, 2009, 01:06 PM   #106
With a sawsall and a welder you can adjust anything!!!
Yes there is some adjustment in them, we also slotted the brackets so that we can adjust them more if needed. Like everything else, if it's Kustom you just can't bolt it on.
Old February 18th, 2009, 01:09 PM   #107
If you have an itch a V-Rod will definatly make you scratch. (either your head or your ass...)
Old February 24th, 2009, 12:20 PM   #108
kremy5
kremy5's Avatar
you got that right ,hey the car looks great ,ive been gone for awhile
home of the p-40 rathawk volksrod :[SIGPIC][/SIGPIC]
kremy5 is offline   Reply With Quote
Old February 28th, 2009, 12:18 PM   #109
bluelabel1927
good work fernon. lookin sick. Way better than my heap!
bluelabel1927 is offline   Reply With Quote
Old March 1st, 2009, 12:53 PM   #110
c1run1
c1run1's Avatar
Looking great!
I also see your working in shorts , and i'm shoveling snow ..
Old March 1st, 2009, 06:19 PM   #111
Holy Shite
Another wait and see is being revealed, it's funny we have spent so much time getting rid of all the holes in this car and now we are putting holes back in the car on purpose. We wanted to address the issue of the lower rocker panel or lack there of since the car has no fenders or running boards the bottom looks unfinished so we decided that it would look better with a rocker panel rolled in the bottom and then drill lightening holes in it for that nostalgia look. This is just our test piece, the finished piece will have the holes dimpled and the spacing will change a little. It does add to the stance of the car though.
Back to work on the door. We wanted to get the door latch in and working, first we had to figure out where we wanted the latching mechanism so it wouldn't interfere with anything.
Once we figured out the location it was time to cut the opening in the door
Latch tacked in.
We also wanted to start filling in all the holes around the hinge openings.
Welding in the brackets and grinding them down so that they are flush with the door.
Door back on the car for test fit.
Now it's time to install the latch pin, this is where you really have to measure.
Our test template for the latch pin assembly.
Cutting through the first of several layers.
The first layer cut away.
After cutting all the inner layers away the pin is tacked in place.
After cutting up the original door mechanism and re-welding it to the size that we wanted it doesn't look to bad, considering we are using a window crank to open it.
Now it's on to the top of the door, first we had to cut the insides so that we could lean them in.
Then tack on the back.
Then it was on to the front.
Making the missing section in the middle
Tack it all into place.
One door actually has a top on now and it opens, not bad for a Sunday afternoon.
Also my steering wheel finally came in, it's a custom billet banjo wheel with a half wrap leather grip.
And I also was able to pick up a W-Lid at the Daytona Show, after sand blasting the rust in the bad areas the lid is in pretty good shape, a little work and it will look good as new.
Old March 2nd, 2009, 12:53 PM   #112
Originally Posted by c1run1 View Post
Looking great!
Thanks, actually we are working in our winter shorts, it droped down to 60 BRRRRRR...
Old March 2nd, 2009, 01:07 PM   #113
Boom
Boom's Avatar
this thing is coming along very nicely
www.dlkweb.org
Boom is offline   Reply With Quote
Old March 2nd, 2009, 01:08 PM   #114
Looking good!
Is your dash pod off center or is it just the pic?
Old March 2nd, 2009, 01:13 PM   #115
Originally Posted by bugdust View Post
Looking good!
Just the pic... you can also see a lot more of the right side A pillar than the left pillar. The photographer was off to the left of center when taking the pic.
But I agree, the whole thing is looking great!
Old March 2nd, 2009, 01:19 PM   #116
Yes I am off to the left of center but the dash is definately centered.
Old March 2nd, 2009, 01:53 PM   #117
BullDog
BullDog's Avatar
Hope you dont plan on running glass in the doors. with the hinge pockets so deep in the doors your in the same place I was trying to make it work.
[SIGPIC][/SIGPIC]Frankenstein T1
Project Progress Gallery
BullDog is offline   Reply With Quote
Old March 2nd, 2009, 02:13 PM   #118
Yeah, we knew about the window issue long before we started with the doors but traditional roll-ups were never in the plans from the get go, we have a couple of ideas in our heads on what we are going to do, it's just a question of how radical we want to get. I have to say it though, your build has been a great help for us along with several others in this forum. Thanks Bulldog...
Old March 2nd, 2009, 02:15 PM   #119
Flipper_1938
Flipper_1938's Avatar
Looking good!
It may be centered, but it is upside down. It needs to follow the point in the decklid.
Old March 2nd, 2009, 02:20 PM   #120
WTF, Lay off the pipe there son.
Old March 7th, 2009, 11:32 AM   #121
ok, 6 days, and I know you have nice weather down there~ some of us can't go that long without updates~~~~
btw~ nice new avatar
Old March 7th, 2009, 06:07 PM   #122
crack monkey
crack monkey's Avatar
as the CBOM, it is law that you have to stop working on your ride for at least a year
Old March 7th, 2009, 07:31 PM   #123
Thanks Guys. We are actually totally shocked about the CBOM Nomination considering we haven't even started to do all the cool mods to it yet (Yeah I know, the wait and see is killing me ). There are no new updates this week since we are at the Super Chevy Show selling this weekend, but the good news is I was able to score a bunch of parts for the V-Rod including a set of BLC Headlight buckets that just look too Frickin' Cool and also a nice set of door handles for the inside. I will try and get photos of the score and the car show up later on I am just way too tired right now and I still have to go load up more stuff to sell.
Once again Thank You guys for the CBOM nomination and also all the help and good harassment from everyone on this site. This place is my sanity for an insane world.
P.S. I saw the best t-shirt ever today
Nitrous is Like a SLUT
You know you want to HIT IT
but you're afraid of the consequences!!!
Old March 7th, 2009, 07:57 PM   #124
Charlie Mosh
Charlie Mosh's Avatar
congrats dude!!!
Cap'n Mosh.
Originally Posted by hal View Post
she's cute ... but she's still blond
Ran like a raped ape.
Originally Posted by notched View Post
Pinstriping by the World-Famous Pepe Pistolas!!
"as i sit here broken hearted, tried to shit but only farted." R. Peek
Going Fenderless!
()o\_!_/o()
Charlie Mosh is offline   Reply With Quote
Old March 7th, 2009, 08:11 PM   #125
Congrats guys! Hurry up and finish yours so you can build mine.
capella chop, chop top, dimple die, lightening holes, speed holes, suicide doors
