Total Online: 1080
Old May 31st, 2008, 10:22 AM   #1
Default The Kommander!
Re:: Type-82e Replica.
Well as some of you old guys might remember I have had one -51 split laying around for awhile. Been collecting some parts etc. for it over the years. I also promised in one thread on Cutting Board that I would post some pix of it when I get something to show....
Here's the -51 body I bought in 2003.
A friend of mine who also is planning on building one just like the one I am had collected a couple of Barndoor transmissions and driveaxles and we have made deals that I make him some sheetmetal parts and he gives me other parts such as one crappy Barndoor transmission where the driveaxles and reductionboxes seemed OK.
I also bought a better floorpan for it last year.
Here's now some progress.
I started to open the reductionboxes back in last autumn but the one I started with didn't want to open then so I let it alone untill last month.
I then managed to finally open it and also open the other side as I need to remove the axle tubes if I want to take the driveaxle and ring and pinion from it and put into the split beetle transmission. The transmission cases in both are the split case type...
Old May 31st, 2008, 10:56 AM   #2
Default Re: The Kommander!
Today I took the 51 split craschbox and opened that to see if the Barndoor axle and ring and pinions would fit inside it...
After comparing them I noticed that I had to swap the ring gear, otherwise the parts are identical.
Here everything fitted to the leftside case.
And finally everything assembled and mounted on the -51 split floorpan...
The swap was a true Bolt-on as I was told by some Gurus years ago!!!
Old October 29th, 2008, 12:25 AM   #3
I have now compared Type-1 spindles with my barndoor spindles:
Linkpin c-c measurement:
Type-1 spindles, 132mm
BD spindles, 138mm
Beam tube c-c measurements so far:
Type-1, 120mm
Barndoor, appr. 139mm
Difference on linkpin distance is then 6mm and torsionbar pivotpoint distance is 29mm...
Strange geometry on the type-1.... Not parallell as stock either...?
The Barndoor seems to be parallell though..
Old October 10th, 2009, 11:46 AM   #4
Finally moved the body today,
Had been sitting here for the past 5 years... :)
Here it have joined the floorpan again.
Short vidclip from right after we got the body on the pan.
http://www.youtube.com/watch?v=0oYOkeDlJgE
