Members: 17,426
Threads: 32,269
Total Online: 504
Newest Member: alfonzo45
Old June 1st, 2008, 02:53 PM   #1
bugroadster
bugroadster's Avatar
Default how to widen fenders
Re:: do it myself
looking for the does and donts of widening my fenders 4 1/2 in the rear and 3 in the front a tech article our you exsperiance good or bad would be great and if you have pics of your post it please
Old June 2nd, 2008, 05:14 AM   #2
PJLOval
PJLOval's Avatar
Default Re: how to widen fenders
I think Nick has a magazine article that shows how it's done. I had that issue and when I do mine that will be the example I follow
Old June 2nd, 2008, 06:05 AM   #3
V8SuperBeetle
V8SuperBeetle's Avatar
For mine, late model fenders, I cut as close as I could to where they bolt up and just welded in so strips to widen them.
Here's the article PJLOval is talking about.
Old June 2nd, 2008, 06:30 AM   #4
PJLOval
PJLOval's Avatar
Bingo!
Old June 2nd, 2008, 05:11 PM   #5
bugroadster
nice info i will save that for referance thanks
Old June 2nd, 2008, 06:38 PM   #6
57Drag did his so you might check out his Intro or pics or whatever
Old June 3rd, 2008, 04:53 PM   #7
bugroadster
i tryed 57drags method today it will work nice if you want 2 to 2 1/2 inches i cant see it working on 4 1/2 inches so i will try to do it like the article maybe tomorrow
Old June 3rd, 2008, 05:42 PM   #8
staynedglass
staynedglass's Avatar
so anybody got any tips on doing the front fenders?
Originally Posted by staynedglass View Post
click for die cut vinyl decals Only $4.5shipped. PBR logos, Vw war eagle,lots more http://www.volksrods.com/forum/showt...339#post460339
staynedglass is offline   Reply With Quote
Old June 4th, 2008, 01:18 AM   #9
bugroadster
i will as soon as i try mine i dont mind being a test subject
Old June 4th, 2008, 01:43 AM   #10
Widening the fronts might be more tricky. If you widen all the 3 inches inside the headlights it will look odd, atleast in my opinion... Would look better if you would widen 1 inch on the inside and the other 1 inch on the outside of the headlight. Makes a lot more work but would look better. Or "simply widen the 3 inches on the inside and then cut out the headlight buckets and move them 1 inch in.
I guess I'm just blabbing again..
Old June 4th, 2008, 01:56 AM   #11
bugroadster
good thought if you do it in to sections it will flow better also
Old June 4th, 2008, 04:25 PM   #12
bugroadster
got one rear widened 4 and a half tryed the other option wasnt having luck so i used 2 fenders and releif cuts it kept a nice contor i need to do the welding it is just screwed together pics coming in a little while
Old June 4th, 2008, 04:38 PM   #13
bugroadster
image 1
Old June 4th, 2008, 04:45 PM   #14
onelowzuki
Looking great JackLooks like it will flow really well
onelowzuki is offline   Reply With Quote
Old June 6th, 2008, 05:24 PM   #15
bugroadster
not a lot of progress on the fenders the shop was 100 and then welding i was a pussy and went to my office in the ac hope to do more monday and tuesday trying to lay out the fronts 3 instead of 4 and a half any ideas
Old June 6th, 2008, 05:53 PM   #16
staynedglass
1.5 in strips on either side of the light? sounds like that's the route i may go when i widen the wifes fenders. so what are you gonna do about running boards?
Old June 7th, 2008, 03:35 PM   #17
bugroadster
i will be making my own running boards also the area at the fenders will be full width the center will be narrower
Old June 7th, 2008, 05:51 PM   #18
Texasbuggys
Texasbuggys's Avatar
Hey those are not wide enough, can ya send them directly to me!! Those look great man, wished mine we turning out as nice, mine are very wide and it really causes problems.
Get ur new Manx Style Fiberglass Buggy Bodies, Chassis and Accessories in Texas
www.texasbuggys.com
67 Chop Top - http://s9.photobucket.com/albums/a60...t=e8a0e41b.pbr
5 window VW pickup - http://s9.photobucket.com/albums/a60...t=bc9c8583.pbw
Texasbuggys is offline   Reply With Quote
Old June 8th, 2008, 03:28 AM   #19
bugroadster
what kind of problems did you run into with yours being wide
Old June 8th, 2008, 07:32 AM   #20
Texasbuggys
Compound curves and with them being so wide when you stay with the natual curve the area that mounts to the body side is way up there. Not really a problem on my truck I don't think. I need to get back on them and see if it is going to work out. I have one about 1/2 through. Fiberglass would have been way easier but not nearly as strong and would eventually crack and I am trying to stay all metal on the truck.
www.texasbuggys.com
Old June 8th, 2008, 01:47 PM   #21
robbie harder
robbie harder's Avatar
i widened my front fenders 2 in. by using another set of fenders. i cut them 2 in. from the bolt flange (while bolted on the car.) and took another pair that had some bad rust in the flange but otherwise were solid. split them right along the edge where they break over to the flange. lined them up as close as i could, tacked in place, and started working my way from the rear to the front. had to make a few relief cuts in the headlight area, and hammer alot along the way, but they turned out pretty good. i smoothed the bumper holes and left the headlight buckets in the stock location. was MUCH easier that i was expecting.
robbie
robbie harder is offline   Reply With Quote
Old June 8th, 2008, 03:57 PM   #22
raidmagic
raidmagic's Avatar
Contact Big hoov. I don't think there is a part on his car that hasn't been widened.
raidmagic is offline   Reply With Quote
Old June 10th, 2008, 01:55 PM   #23
trevorbrady
some good pics on flickr of widening fenders :)
trevorbrady is offline   Reply With Quote
Old June 10th, 2008, 04:41 PM   #24
bugroadster
nice pics anyidea why he wdened the cente 3 inches and the ends 1 1/2 inches
Old June 10th, 2008, 08:04 PM   #25
Bighoov
Bighoov's Avatar
Heres a couple shots of mine which are 4 inches wider, this is the only shot of front guess I didnt take any before it was done
heres one of the rears
The blue strips are the added part on the fenders
Think outside the box Bahh... cut the box in half and make it wider
WIDE69.COM
Bighoov is offline   Reply With Quote
wide fenders
