Members: 14,554
Threads: 30,737
Total Online: 61
Newest Member: etche
- by notched
- by Roddy
Old September 27th, 2008, 12:00 PM   #1
YelLowBug
YelLowBug's Avatar
Default ICE and car audio cutting flames..
i see you all choppin' & lowering and cutting and welding but does anybody have some ICE in the bug or some Car audio??
here in Belgium wa cant cut and weld to much
and the only thing that's not (yet?) been limited is Car Audio
so when i go cruizin' it's with a skull crushing BASS in the back..
but i got a little tired of what i got so i'm gonna rebuild everything..
so tell me what you think..
here some pics
a totall view of the back
radio built in with the midspeaker down in the kickpannel and the tweeters the dash
and some junk in the trunk..
and now i kicked everything out..
even the backseat and made a new base..
and i started to build everything up..
damn that wasn't simple.. after 10hours calculating i finaly found a (very daring) shape to fit al the woofers in the back
1 cube has a 55L volume and the other 2 a 33L volume but you have to meet the highte of the windows and the woofers, the overal space in the back and the volumes the woofers needed..
so it came out as an very complicated drawing witch leaded to this;
one box installed
3 boxes installed
and now it's back to prepare the bottom witch it stands on..
but i guess thats gonna be tomorrow..
but i also discovered an other problem..
how the hel am i gonna place one 2channelamplifier, two 2channelamps, a condensator an equalizer and a fusebox/splitter in the damn trunk??
so what do you guys think or ?
and who has an ICEd Bug?
greetzzzz
driving the YelLowBug;
Last edited by YelLowBug; October 20th, 2008 at 11:45 PM. Reason: a new side project
Old September 27th, 2008, 12:07 PM   #2
Default Re: ICE and car audio
Put the amps and stuff under the plywood platform.
Recently updated:
FlyingEyeballs.net
Old September 27th, 2008, 12:17 PM   #3
Driveway Jewelry
Driveway Jewelry's Avatar
They will probably get too hot in there. Unless he vents it and runs fans through it.
Driveway Jewelry is offline   Reply With Quote
Old September 27th, 2008, 01:13 PM   #4
Back in the day I had 2-12"'s and a 400W Kenwood in an enclosure built in behind the seat, then 2 pair of component kenwood sets 6"s and poly tweeters in the kicks and wedges in the rear deck with the subs. They ran off of another 400W Kenwood. Everything was hidden under acoustic cloth though. Everyone in town knew it was there, but you didn't dare pimp a system like they do now if you liked your ride to be in the driveway in the morning. My shepherd kept it company most nights.. I didn't listen to all the bass shit though. Sabbath, Ozzy, Priest, Van Halen, Maiden. Fuckin car made your ears bleed. I could pop the vent windows open if it was loud enough and even better set off all the car alarms on my street.!
Old September 27th, 2008, 01:23 PM   #5
Have all the amps and stuff exposed in a tastefull rat rod kinda way, on the boxes.
Old September 27th, 2008, 02:41 PM   #6
slow74
slow74's Avatar
id say lose the spare tire and put the small stuff down there. and mount the amps flipped 90 degrees from what you have now...you could always hide some stuff under the platform as long as you leave some airflow..maybe drill a couple tasteful port holes for it and what not
slow74 is offline   Reply With Quote
Old September 27th, 2008, 03:48 PM   #7
trikertroy
trikertroy's Avatar
Please be careful where and when you crank that thing up...Some people loose ALL control and will want to kick your ass... Its true that it can drive some truely crazy...and that makes them dangerous... Dont let your freedom to slop over on other folk`s freedom.. No to mention the new laws that can have your car impounded and huge fines.(around the Tampa Bay area)
Old September 27th, 2008, 06:20 PM   #8
Hapster
Hapster's Avatar
Ever read about resonant frequency? You know high notes breaks glass. Well the "right" low notes cause a person to really lose ALL control and I don't mean to make them dangerous. (Maybe to their clothing) They lose control of their biological functions. (So be sure to carry TP if you are playing really low frequency.)
Old September 27th, 2008, 07:26 PM   #9
Steve White
Steve White's Avatar
Originally Posted by Hapster View Post
Well the "right" low notes cause a person to really lose ALL control and I don't mean to make them dangerous. They lose control of their biological functions.
I'm sure you don't but I have to ask ... you don't actually believe that do you?
Old September 27th, 2008, 07:31 PM   #10
Steve White
that is going to be pretty impressive looking when its done.
I have a couple of 12's running off a 1000 watt D-class in a sealed inclosure in the bus. It pounds pretty good and reaches pretty deep but I'm going to tear it apart and build two tri-fold horns for the drivers. Should see a pretty substantial increase in speed and efficiency not to mention I might actually get to hear some of that low bass from inside of the vehicle.
Keep the pix coming :)
Old September 27th, 2008, 08:30 PM   #11
welshj
welshj's Avatar
The "brown note" is a myth debunked by the mythbusters!
They actually tried to get jamie to shit his pants with some extremely loud, extremely powerful subs and speaker setups... and varied the tone across the whole ound range.
no dice.
joel
There are days when you feel like a rat in trap... But, I prefer the days when I feel like the cat watching the rat!
'72/62/67/65/63/? bug on bags, hairless....(shaved) http://www.aircoolers.org
Originally Posted by Reaper View Post
It's "Cut, Weld, Drive"....not "Moan, Whine, Bitch.
welshj is offline   Reply With Quote
Old September 27th, 2008, 09:15 PM   #12
busguy71
busguy71's Avatar
am I alone here...... what the hell is ice? god damned new fangled ricer lingo
Everyone sucks but me
X- GT40 builder
busguy71 is offline   Reply With Quote
Old September 28th, 2008, 12:14 AM   #13
radiotrib
radiotrib's Avatar
no dice.
joel
Dunno about that, but we put all our satellites through a sonic test before they go to the shaker platform. We bombard them with enough Dbs to rattle things loose, and quite enough to make you do a lot more than crap yourself :) It simulates frequencies and amplitudes present during a launch.
there again - you won't get that kind of SPL from a car stereo, no matter how "phat" it is.
Old September 28th, 2008, 12:29 AM   #14
slow74
slow74's Avatar
haha ice is like fancy shit.....you know the bling bling factor
Old September 28th, 2008, 12:35 AM   #15
radiotrib
radiotrib's Avatar
In Car Entertainment
Old September 28th, 2008, 04:18 AM   #16
YelLowBug
YelLowBug's Avatar
wow these are a lot of reactions..
i cant put the amps under the plywood because i need room there for (you'll never guess) extra tweeters and a 2way speaker system...
i think i'm gonna build a second floor on top op the other amps to fit the thirth..
i dont think i'm gonna cruise around in that area (i'm from belgium) so no worry's and i dont think it's gonna play that loud
Old September 28th, 2008, 04:21 AM   #17
YelLowBug
YelLowBug's Avatar
damn that some funny (here it comes) shit
beter save up to buy me some seat covers
any testpersons available??
Old September 28th, 2008, 04:42 AM   #18
duct-tape
duct-tape's Avatar
you can have rich clarity and bass without all that extra shit in your car. it gets to a point where you're not improving your system, just adding stuff. you have about a cubic yard of space in the beetle.
The Duct-tape
duct-tape is offline   Reply With Quote
Old September 28th, 2008, 04:48 AM   #19
You could alwasy run the amps on top of the 2 at a angle. Basically inlay the top piece into the top of the side boxes and 2 more angle pieces of wood to the top of the center box. You would then inlay the amps into the top 2 angle pieces for a realy clean look. Plus all the wires could be hidden out of sight easy enough.
Old September 28th, 2008, 04:50 AM   #20
Why would I have to go along? What if I'm busy at the time?
Old September 28th, 2008, 05:41 AM   #21
smoker
i own a car audio shop and i dont recognize those brands, the green sub wants me to say fusion but not sure...anyway, unless your building it to look impressive more than maximize the output of the subs, you can get real loud with a single 12 or 15, building a correct ported enclosure tuned to the resonant frequency of the vehicle will yield higher decibals but sacrifice some sound quality. i usually (depending on the driver) tune my enclosures to about 40 hz. with a 3 db gain. that way my low end frequency response is louder by double (a 3 db increase is actually considered a doubling of sound) while above the tuning frequency the enclosure has a natural rolloff to the crossover point giving it sound quality similar to that of a sealed enclosure. die hard sound quality competitors wouldnt do this becasue of the gain in the lowest regions but in a daily driven car the ears percieve it to be better and the sq competitors use rta to measure frequency response. anyway my point being that you could use a single sub and still have room for your equimpment without cramming it all in.
smoker is offline   Reply With Quote
Old September 28th, 2008, 05:54 AM   #22
Steve White
in probably one of the most flawed mythbusters ever. The waveform to generate an open air free standing 60hz note is close to 20 ft long, a 20hz note is almost 60ft long.
Standing 2 ft from a bank of speakers with no reflective surfaces anywhere in the vicinity didn't test anything. At 2 ft you can generate a 550hz note. You will hear deeper bass but that is sympathtic energy radiating from the waveform as it moves away from you. Certainly not the same as having that waveform move though you.
Old September 28th, 2008, 09:46 AM   #23
radiotrib
radiotrib's Avatar
If you're installing tweeters remember they have to be directed at you. Best place for them is on the A pillars or in the dash as a second best, but either way, pointed at your face.
Old September 28th, 2008, 12:14 PM   #24
YelLowBug
YelLowBug's Avatar
i'll send you a mail and we'll pick a date...
Old September 28th, 2008, 12:19 PM   #25
YelLowBug
YelLowBug's Avatar
i've got me some supersweet tweeters..
but i'm still a little confused.. placing them in the angled board under the speakers or make some extra boxes and place them on top of the woofers..
i guess it's better for the sound but i'm afraid of how it would look... gonna need a night of sleep over that
