Members: 17,517
Threads: 32,252
Total Online: 506
Old December 27th, 2008, 05:49 PM   #1
Default Scat bus shifter into bug
Re:: How-to:
I was just looking in one of the old shifter threads and the question of putting a Scat bus shifter into a bug came up. There was no pics.
There's a couple of ways to put a Scat bus shifter into a late bug (68+). It may be the same for earlier cars as well. I put one in a 69 bug a few years ago. This is all from memory and a few pics so bear with me.
The Scat bus shifter is about 1" longer below the mounting plate than the bug but has a 3/8" spacer (two "horseshoes") tacked on there so it comes out to about 5/8" difference. You could just add a couple spacers under each bolt location or a stack of washers I suppose, but that's not how I did it. I made a 1" spacer.
Here's a pic of the difference after I knocked the spacers off.
Bug on top, bus below
spacers removed
I took a piece of 1" thick flatbar (1x3 maybe, about 6" or so long) and layed out the outline of the bottom of the Scat shifter on it. I cut it to shape, including the center hole. Make the hole bigger than the Scat hole to allow for the shaft angles or bevel the sides.
I cut it out by hand with a torch.
Then, I just drilled some slots into the plate to allow some adjustment and bolted it up with longer bolts.
I sold the car with the shifter & spacer in it so I can't get any actual dimensions for you. I still have the paper template somewhere.
Old December 27th, 2008, 06:18 PM   #2
jkien65
jkien65's Avatar
Default Re: Scat bus shifter into bug
Nice tech. Needs to be in the tech bin.
scat shifter
