Total Online: 625
Old May 18th, 2009, 09:04 PM   #1
63 hoody
63 hoody's Avatar
Default biggest engine displacement?
Re:: whats the biggest you can go?
just curious about whats the absolute biggest someone has gone on an engine , t1 case , i know ive heard of 2332's and stuff but whats the biggest someone has pumped one up too?
I finally found a substitute for ducttape ... JB WELD!!
63 hoody is offline   Reply With Quote
Old May 18th, 2009, 09:18 PM   #2
Reaper
Reaper's Avatar
Default Re: biggest engine displacement?
IIRC someone has done a 2700 or something around there. Aftermarket type 1 case though, with ALOT of welding and mods done to it. The WBX cases have been taken to 3000.
-Keith
Old May 19th, 2009, 02:16 AM   #3
All you ever wanted to know about VW engine displacement. well, almost
http://eswebs.com/VWEngineSizes.html
Old May 19th, 2009, 02:54 PM   #4
trikertroy
trikertroy's Avatar
I noticed that there was no 1800cc ... I hear and even see engines advertized as 1800...Lots of guys have told me that they had a 1800 in their car for sure... Iv told them, to my knowledge, there is no such thing.. I pulled apart a Trike Shop 1800 engine the other day,, stock crank and 90.5mm pistons=1775cc...Thats a big tad shy of 1800.. but call it what you want,, noone will know the difference...LOL
Old May 19th, 2009, 03:06 PM   #5
A lot of people round displacement up,
I'm guessing anything over 1750 would be called 1800.
Old May 19th, 2009, 04:03 PM   #6
Gravedigger
Gravedigger's Avatar
I built an 1800 once, what a sweethart of a motor, I had a SCAT 74mm crank, then I came apon some p&c, they were old, new in the box, Empi aluminum fined cyls, 88mm,very cool dp heads, a single 40IDF carb, one day I was @ the bank drive through, pulled out @ about 3000rpm I dropped a valve!! a CB ss ext valve that never should have broken, less than 5k on it, I still have 3 p&c, never found a replacement~
Denny Anderson
Gravedigger is offline   Reply With Quote
Old May 19th, 2009, 04:15 PM   #7
How bad did you hurt that one barrel ?
Darton can make sleeves in any size.
You could have that one bored, and a new sleeve pressed in, then bore and hone to size.
It would be as good as new.
Old May 19th, 2009, 05:05 PM   #8
Gravedigger
I think the cyl split, I shit canned it
Denny Anderson
Old May 19th, 2009, 05:32 PM   #9
I have an 1850cc in mine, 76x88. I have seen 90mm stroker cranks and 96.7 mm bore that has dowel pins on the case and the cylinder sits on the case and the cyl and case is honed together.
Old May 19th, 2009, 06:03 PM   #10
According to the chart. 74 stroke, 88 bore= 1800
Don't EVER ask me to verify ANY math.
2+2 doesn't always = 4 with my math skills.
Old August 3rd, 2017, 05:10 PM   #11
Humbug53
Running 5965cc here. :)
Humbug53 is offline   Reply With Quote
Old August 3rd, 2017, 07:50 PM   #12
I run a 2332cc in one of my cars. T1 block, no super exotic parts...
65 Sunroof Notchback
Old August 3rd, 2017, 09:01 PM   #13
I remember reading way back that Bernie Bergman was building 2500+ cc with Chevy 5.7 rods.
Old August 3rd, 2017, 10:48 PM   #14
70 Bug Mid Engine
70 Bug Mid Engine's Avatar
Mines got a 2307cc engine....
1970 Bug - For some reason there is a radiator up front...
70 Bug Mid Engine is offline   Reply With Quote
Old August 4th, 2017, 07:46 AM   #15
5754 cc. Nuts, Humbug53 has me beat.
Old August 4th, 2017, 05:42 PM   #16
marnat3
marnat3's Avatar
I gots 1835cc
Old August 11th, 2017, 05:54 PM   #17
lunatic_magnet
lunatic_magnet's Avatar
volksrods member #39
Old August 11th, 2017, 06:31 PM   #18
marnat3
marnat3's Avatar
