Members: 17,340
Threads: 32,252
Total Online: 517
Newest Member: vw67
Old March 2nd, 2010, 10:20 AM   #51
Default Re: The wife's new 66.
Originally Posted by Seanboy56 View Post
Nice car!! How about renting out the tool you made? I need it for my bugs drivers side!!
You could probably have one made for you for the price of shipping between Finland and Pennsylvania both ways...
Old March 3rd, 2010, 12:04 PM   #52
Seanboy56
Yes you are right....
Seanboy56 is offline   Reply With Quote
Old March 3rd, 2010, 01:38 PM   #53
This is a scan of the crappy original drawing I did for it.
I did make the gap 61-62mm as the hinges are but would recommend to rise the upper jaw some to make a 65mm gap. Easier to fit the different size pins into the lower jaw that way.
Old March 3rd, 2010, 03:46 PM   #54
Old March 3rd, 2010, 04:12 PM   #55
blacktruck
blacktruck's Avatar
so there needs to be some room for the pin and the pusher bits...right?
the red parts are where I think that would happen
nut up or shut up
Old March 4th, 2010, 08:42 AM   #56
The jaws are drilled like this.
12mm all through the upper to allow the hingepin to go through. and 7mm just about 5-8mm down so you can drop in different length pusherpins into that hole.
Old March 9th, 2010, 08:36 AM   #57
Recieved the aircleaners yesterday and mocked up their positions.
Repainted them later in the evening. And today I recieved new decals for them.
Old March 14th, 2010, 02:19 PM   #58
Now with 45mm necks under the aircleaners and 20mm bakelite spacers between the carbs and manifolds. Measures now 86cm from side to side at the top of the aircleaners.
Also cut some stainless steel tubes for the exhaust...
Old March 18th, 2010, 03:39 PM   #59
Added a 20mm spacer under both carbs and now also welded the necks for the aircleaners so they clear from the fanshroud and still fit inside the enginebay.
Just have to make the linkage now and then testrun it.
Old March 21st, 2010, 10:53 AM   #60
Mocking up the fuel lines.
Old March 21st, 2010, 12:26 PM   #61
vdubjim
Looks like the type of stuff people drag to Carools shop and he pays like 500E for it LOL.
Nice ride!
Jim Buys
Vintage Speedwerks
Vintage VW's and CUSTOM Vinyl Graphics
Oklahoma VW Club
www.oklahomavwcruisers.tk
vdubjim is offline   Reply With Quote
Old March 22nd, 2010, 03:21 PM   #62
Not sure what shop that is?
Hope it is'nt a bad place?
Here's the finished fuellines loosely fitted. Still need to tighten the joints and make a few supports to avoid the worst vibations.
Old March 22nd, 2010, 04:14 PM   #63
vdubjim
Nope its good place, i used to work there. In Konningsbosch near Roermond.
http://www.vwveteran.com/
Hope you have better luck with those carbs than bus people do, LOL.
Jim Buys
Vintage Speedwerks
Oklahoma VW Club
Old March 22nd, 2010, 04:26 PM   #64
I've thought about doing something like that on the vert! Now that I see it, I think I really want to!
Old March 22nd, 2010, 04:47 PM   #65
AirheadZim
AirheadZim's Avatar
Damn, Hebster that looks sweeet.
Zim
Old March 23rd, 2010, 01:59 AM   #66
I didn't end up using the Bus carbs but bought a set of type-4 carbs from a 411 instead...
Now go on and do it!
Old March 23rd, 2010, 05:59 AM   #67
vdubjim
LOL, there is a difference?
Jim Buys
Vintage Speedwerks
Oklahoma VW Club
Old March 23rd, 2010, 08:35 AM   #68
The problems the busguys are having is that the bus type-4 carbs have a lot of vacuum shutoff valves and hose etc. that are difficult to get to work properly without the knowledge where as the 411 carbs dont. They are more like pre-Kadron carbs. Basically the same carbs as the ones used on Type-3's with dualcarbs just 34mm instead of 32mm for type-3's.
Old March 27th, 2010, 02:12 PM   #69
Removed the frontseats and started dismantling the small parts in the dash etc. prior to repaint. Had to peak under the floormats to check the floorpans too..
Looks pretty rotten to me... ;)
I have never seen a beetle door that have had a plastic foil behind the doorpanels before either...
To top it all the PO had appearantly "sealed" the fenderbeading with vaseline!!!
Getting ready for repaint.
Old April 17th, 2010, 12:49 PM   #70
Transformation have begun!
Old April 17th, 2010, 01:08 PM   #71
hotrod
hotrod's Avatar
wow, it looked awesome already and making it even better, I like the hard fuel lines
hotrod is offline   Reply With Quote
Old April 17th, 2010, 02:16 PM   #72
Trebor13
Trebor13's Avatar
that looks great , good work
FENDERLAWS
Trebor13 is offline   Reply With Quote
Old April 18th, 2010, 02:37 PM   #73
Repainted the interiour today due to some grease spots yesterday...
Now it's better, not perfect but will be good enough for us..
Old April 19th, 2010, 01:51 PM   #74
notched
notched's Avatar
Score!!
Phillip Bradfield
Old April 27th, 2010, 07:27 AM   #75
callook, oldspeed, seasand, seesand
