Members: 17,604
Threads: 32,289
Total Online: 493
Newest Member: smoknjoe
- by bugwhat
Old September 23rd, 2009, 07:52 AM   #1
onelowzuki
Default Beam adjusters install and adjustment instructions
I see questions pop up every now and then about beam adjusters--Here is a pic of the instructions
onelowzuki is offline   Reply With Quote
Old January 22nd, 2011, 02:09 PM   #2
Default Re: Beam adjusters install instructions
I'm adding this for those it might help~ since the directions to install don't exactly tell you how to adjust.
Quoted from Don at chirco~
This should be fairly straight forward.
Jack up the front end a put it on two jack stands, one on each side.
On your adjusters, the bottom screw and nut is the adjustment and the upper puts tension on your leaf springs.
If you tighten your adjustment screws, you will be rotating the springs up, forcing your control arms down and that raises the stance of the car.
Do this adjustment a little at a time to both your upper and lower beam tube, until you get the stance you want.
Then lock down the jam nuts so it stays in place.
from this thread~
http://www.chircoestore.com/catalog/...26729#msg26729
Old January 26th, 2011, 03:43 PM   #3
69rat*tat2r
Default Re: Beam adjusters install and adjustment instructions
becareful that you pay attention so you don't have it turned the wrong way before you weld it in. Then it will raise it... ooops!!!!
69rat*tat2r is offline   Reply With Quote
