Members: 17,717
Threads: 32,305
Total Online: 415
Newest Member: greyeage9099
Old February 23rd, 2010, 09:38 PM   #51
Default Re: How To Tech:from Knucklebusterinc.com
These are from www.vintageprojects.com
but they fit here:
Low Speed Drillpress.
Shop Forge
Gas Fired Smelting Furnace
Bending brake
Sand Blaster
Screw Press
Electric Etching
Old February 24th, 2010, 09:19 AM   #52
Google Books now has Popular Mechanics back issues online:
Direct Drive Belt Sander
Casting with Rubber Molds
Adjustable Cone Mandrel
Using hand Punches
How to cut sheet metal
Knurling
Servicing Drill Chucks
Drilling Metal
Drill Press Speed Attachment
Old February 24th, 2010, 09:56 AM   #53
Metal Spinning
Buffing
Screw press
Machining Tubing
Expanding mandrel
Hand taps
Old February 24th, 2010, 10:17 AM   #54
Bandsawing Metal
Boring
Lost Wax Casting
Heavy Duty Boring Bar
Gauge Blocks
Ball Bearing Lathe Centers
Old February 24th, 2010, 10:36 AM   #55
Radius turning tool
Spark Testing Metal
Toolmaker's Buttons
Band Saw Circle Cutting
Turning a radius
Old February 24th, 2010, 10:49 AM   #56
Bending Brake
Tailstock Turret Head
Old February 24th, 2010, 02:17 PM   #57
Default Re: Vintage How To Techs
Acid Etching Metal
Friction Sawing
Plaster Casting (also works for resin)
Multiple Start Threads
Boring bar holder
Heat Forming Plastic
Simplified Sheet Metal layout
Sine Vice
Small fixtures
Thread Cutting
Boring Tapering and Facing
Turning Metal Accurately
Old February 24th, 2010, 02:29 PM   #58
Knurling
Hand Filing
Milling on a Lathe
Taps and Dies on the Lathe.
Milling with Compound Rest
Collet Chuck
Taps
Old February 24th, 2010, 05:19 PM   #59
Dial Indicators
Lathe Taper Attachment
10 Lathe hints
Working with Sheet Metal
Thread Cutting
Swing Away Pads for Drill Press.
Cut Off tool holder
Knurling with a mandrel
Low Buck Spindle Sander
Sand Casting at Home
Old February 25th, 2010, 12:40 PM   #60
Mill Keyways in a Lathe
Analyze Spark Plugs
Precision Measuring Tools
Dial Indicators on the Lathe
Heat Treating Steel
Sharpening twist drills
Vernier Calipers
Steel Wool
Steady Rest
Old March 1st, 2010, 08:32 AM   #61
Horizontal Milling Machine Practice.
Old March 3rd, 2010, 06:12 PM   #62
Filing on a Lathe
2 way clamp
Simplified set up for Steady Rest
Build a Buggy
Cutting Torch attachments
Boring Bars
Using a vacuum gauge
Knurling
Service front wheel bearings
Lost wax casting
Flat Turnings from Round Stock
Slip Roller
Old March 3rd, 2010, 07:40 PM   #64
Tapping fixture
Marking metal
Old March 4th, 2010, 09:39 AM   #65
Drill press fence
Simple Hydraulic Press
Rube Goldberg
Glue Chipping
Boonie Bug
Drilling angled holes
Old March 4th, 2010, 10:09 AM   #66
Reading spark plugs in color
Old March 4th, 2010, 10:46 AM   #67
Angle plates
Step Collet Chuck
Lathe Centering
Etching Glass and Metal
Coloring Metals
Model Makers Vice
Old March 4th, 2010, 07:40 PM   #68
Soldering Aluminum
Electroplating
Stenciling
Metal finishing
Metal Spinning
Heat Treating Brass, Copper, and Aluminum
Using your Hack Saw
How to use Cold Chisels
Heat treating Iron and Steel
Band Saw tune up
Old March 4th, 2010, 08:07 PM   #69
Electroplating with Lead, Zinc, and Cadmium.
Plating with Copper, Nickle, and Chromium
Tool Post Grinder
Old March 5th, 2010, 08:50 AM   #70
Vintage machine shop secrets
Click on the pages to make them bigger
Old March 5th, 2010, 05:32 PM   #71
Silver Solder
Plating Tricks
Lathe Speed reducer
T3 VW
Chucking Odd shapes in the lathe
Cold Forming
Photography Lighting
Accurate cross holes
Band Saw speed reducer
Marking meta for layoutsl
Removing broken screws
Waste oil heater
Using a Slide Rule
Machinist Short Cuts
Old March 5th, 2010, 06:19 PM   #72
Tool Post grinder
Loosen Rusted parts
Hand Riveting
Cutting Glass discs
Solder Aluminum
Soft Soldering
How to use a File
How to use a Hack Saw
Old March 6th, 2010, 02:16 PM   #73
Ellipse trammel
Cutting glass
1963 Notchback.
Old March 18th, 2010, 10:12 AM   #74
Milling Operations on the Lathe-
Chapter 1
Chapter 2
Old March 18th, 2010, 02:36 PM   #75
AirheadZim
AirheadZim's Avatar
Hey Ian, this months HotRod magazine has 2 great articles. One on making your own rollbars and cages, the other about shaping metal using the old stump method where you get a non sap type tree stump, sand a dip into it and use it to shape your stock. I thought that method was pretty damn cool.
Zim
diy, how to, knuckle*, popular thread, retro tech
