Members: 17,426
Threads: 32,269
Total Online: 509
Newest Member: alfonzo45
Old December 17th, 2009, 05:46 PM   #1
63 hoody
63 hoody's Avatar
Default parts washer tub
me and my buddy built a parts washer tub from a big steal drum cut in half and legs welded to it , i have a smaller parts washer im stealing the pump and stuff out of for it but the problem is that is has a few pin hole leaks , what can we use to seal it up?? gas tank sealer? jb weld ? fiberglass resin?
I finally found a substitute for ducttape ... JB WELD!!
63 hoody is offline   Reply With Quote
Old December 17th, 2009, 06:03 PM   #2
Default Re: parts washer tub
Masterseries!
Old December 18th, 2009, 06:14 AM   #3
I think I'd find a better drum to start with. You're gonna spend more time and money fixing a leaking barrel than what it would cost to do over.
Old December 18th, 2009, 06:15 AM   #4
UT-X
UT-X's Avatar
Old December 18th, 2009, 08:57 AM   #5
Hapster
Hapster's Avatar
pin holes can be filled with a sheet metal screw with either a rubber washer on it or some permatex on the threads screwed into the hole. Just grind the sharp points off before you reach into the barrel
quote from cdscowboy
I totally feel at home here.
project pics
Old December 18th, 2009, 09:09 AM   #6
ClassicGMJunkie
ClassicGMJunkie's Avatar
duct tape the outsides, masterseries it to fill those pinholes, and remove tape and paint it up. the masterseries will outlast the barrel....
62 Impala 2dr HT build
70 Cabrio build
Intro thread
Old December 18th, 2009, 11:57 AM   #7
drscope
drscope's Avatar
SOLDER! sheet metal screws will leak as the parts cleaner attacks the rubber. Same os most epoxies that would be in cantact with the solution.
But if you solder it up, the solder will withstand the parts washing solution.
drscope is offline   Reply With Quote
Old December 18th, 2009, 04:51 PM   #8
Hapster
Hapster's Avatar
sounds like a plan
project pics
Old December 18th, 2009, 04:54 PM   #9
Use a shop plastic sink build yourself a platform to set your part on above the solvant. Hook it to a big swan neck faucet and run the drain with a screen in it and then have a pump inline leading to the faucet.
But if the drum is leaking i might be able to send you some old pipe coating we have at work for you to coat the whole inside of it with.
Old December 19th, 2009, 04:54 AM   #10
Trebor13
Trebor13's Avatar
use the dishwasher, it works great.
FENDERLAWS
Trebor13 is offline   Reply With Quote
Old December 19th, 2009, 06:17 PM   #11
You guys are working way too hard at out smartin' each other to fix a leakin' drum, just replace it with something that doesn't leak!
Old December 21st, 2009, 05:43 PM   #12
vdubjim
I just bought some of this shizzzz, havent tried it yet. UNLIKE JB and all that other crap the list of stuff its resistant to is CRAZY!!
http://www.highsidechem.com/redepxy.html
Typical Tensile Shear Strengths of Metal,
*Aluminum alloy 4590 psi
*Steel (pretreated) 5040 psi
*Brass (pretreated) 2135 psi
*Brass (untreated) 1940 psi
*Copper (pretreated) 2950 psi
HYDRAULICALLY PRESSURE TESTED IN EXCESS OF 3000 psi ON 304 and 316 STAINLESS STEEL AND BLACK IRON PIPE.
EFRIGERANTS:
R-717 (ammonia)
R-744 (carbon Dioxide)
R-11 (trichlorofluoromethane)
R-12 (dichlorodifluoromethane)
R-21(dichlorofluoromethane)
R-22(chlorodifluoromethane)
R-113 (1,1,2-trichlorotrifluoroethane)
R-114 (1,2-dichlorotetrafluroethane)
R-40 (methyl chloride)
R-30 (methylene chloride)
R-290 (propane)
R-764 (sulfur dioxide)
R-134a (1,1,2-tetrafluoroethane)
R-13, R-13b1, R-500, R-502, R-503, R-123, R-124,R-401A, R-401B, R-402A, R-402B, R-403B, R-406A, R-408A, R-409A, R-23, R-236fa, R-404A, R-407A, R407B, R-407C, R-410A, R-507, R-508.
REFRIGERATION LUBRICANTS:
Mineral Oils, Napthenic
Mineral Oils, Paraffinic
Polyol Esters
Polyalkylene Glycols
Polyalphaolefins
Alkylbenzenes
FUEL GASES:
Natural Gas
LPG "Liquefiedl Petroleum Gas"
LNG "Liquefied Natural GAs"
Propane
n-Butane
Isobutane
SOLVENTS:
Water (soft; hard; potable), seawater, Pentane, Hexane, Cyclohexane, Heptane, Petroleum Napthas, Mineral Spirits, Toluene, Xylene, Perchloroethylene, D-Limonene, Turpentine, Pine Oil, Lacquer Diluent, Rubber Solvent, VM&P Naptha, Stoddard Solvent, Deodorized Kerosene, 140F Solvent, Medium-flash Aromatic Naptha, High-flash Aromatic Naptha, Dipentene, Chloroform, Orthodichlorobenzene, Acids-Dilute, Monochlorobenzene, Ethylene Dichloride, Trichlroethylene, Propylene Dichloride, Aliphatic Solvents, Caustics-Dilute, Aromatic Solvents, Glycerine, Chlorinated Solvents Alcohols
INDUSTRIAL GASES:
Acetylene, Air, Carbon Monoxide, Ammonia, Argon, Carbon Dioxide, Ethane, Ethylene Chloride, Fluorine, Hydrogen, Methane, Neon, Nitrogen, Nitrous Oxide, Propylene, Silane, Xenon, Tetrafluoromethane, Helium.
FUELS:
Gasoline (petrol, motor fuel), Aviation Gas (avgas, jet fuel), Fuel Oils, Diesel Fuel Oils, Gas Turbine Oils, Kerosene, Gas Oil.
OILS:
Mineral Oils, Soybean Oil, Coconut Oil, Tall Oil, Peanut Oil, Rapeseed Oil, Menhaden Oil, Vegetable Oil, Animal Oil
Jim Buys
Vintage Speedwerks
Vintage VW's and CUSTOM Vinyl Graphics
Oklahoma VW Club
www.oklahomavwcruisers.tk
vdubjim is offline   Reply With Quote
Old December 21st, 2009, 07:36 PM   #13
You can buy a big galvanized wash tub pretty cheap at Home Depot. Why bother with the cut in half barrel with holes. Or you can get a good condition barrel pretty damn cheap or free. Call up anyone who's usiness uses drums of solvents, such as acetone ask for an empty. They will likely be glad to give you one.
Old December 22nd, 2009, 05:10 AM   #14
trikertroy
trikertroy's Avatar
Check with your friendly neiborhood meth dealer. He may know someone that uses a lot of these chemicals...
Old December 22nd, 2009, 09:59 PM   #15
63 hoody
63 hoody's Avatar
heres a pic of the tub and of my 1600 so far thats goin in my bug , patched the tub with jb weld , metal patch and fill crapp from the hardware store and rtv silicone . seems to be fine now . ivw washed all my engine tins in it and my buddys washin his engine case in it .
Old December 23rd, 2009, 07:06 PM   #16
Meth Dealer ?? i was referring to paint shops and Fiberglass shops....
